t-royR Samba Member
Joined: April 19, 2012 Posts: 464 Location: Minnesota
Posted: Wed Mar 06, 2024 12:34 pm Post subject: Re: Type 3 engine build from type 1 case |
I realize I have a couple posts going on this engine build.
It is a type 1 case, and continuing the build.
I am shopping for used generator and cooling fan.
Will a generator and fan off of a 68 work on a 72 1600 dp? _________________ T-roy
75 Super
71 Super
71 Ghia coupe auto-stick
71 Ghia conv
69 Fasty
74 Ghia conv |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22439 Location: Kimball, Mi
Posted: Thu Mar 07, 2024 1:54 pm Post subject: Re: Type 3 engine build from type 1 case |
Yes, although you might have to change the push on spade terminals to bolt on ones. Of course your existing generator might have already been swapped. After 40+ years anything is possible.
I'd look in the Samba classifieds for the fan shroud or contact either Joel or ISP West for one. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
t-royR Samba Member
Posted: Thu Mar 21, 2024 5:06 pm Post subject: Re: Type 3 engine build from type 1 case |
I am getting ready to mount the air intake and carb.
On the intake ports in the head, do I use paper or metal gaskets? I have an engine gasket kit that has both.
Thanks
Troy _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13285 Location: Tejas!
Posted: Thu Mar 21, 2024 5:40 pm Post subject: Re: Type 3 engine build from type 1 case |
t-royR wrote: |
Thanks
Troy |
I use the paper, it's more forgiving and can be re-used. The metal ones are one time use. |
Posted: Fri Mar 22, 2024 12:44 pm Post subject: Re: Type 3 engine build from type 1 case |
Erik G wrote: |
t-royR wrote: |
Thanks
Troy |
Yup, I prefer thick paper ones, or use the metal ones for templates and cereal boxes for the gasket material. The metal gaskets cause a vacuum leak, due to the small hole in them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
t-royR Samba Member
Posted: Fri Mar 22, 2024 1:35 pm Post subject: Re: Type 3 engine build from type 1 case |
Thanks all! _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
t-royR Samba Member
Posted: Thu Apr 04, 2024 4:53 pm Post subject: Re: Type 3 engine build from type 1 case |
Hey,
I am closing in on the build completion. I am putting on tin and doghouse.
I'd like to get some recommendations on a good exhaust solution to go with. I don't have the heat exchangers or any other exhaust parts. There seem to be lots of options. Can I go with J tubes instead of the heat exchangers? Does that complicate things and/or drive me to a few distinct options of mufflers and other parts?
Thanks
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
Posted: Fri Apr 05, 2024 10:08 am Post subject: Re: Type 3 engine build from type 1 case |
t-royR wrote: |
Hey,
Thanks
Troy |
I wouldn't run a "Monza" muffler as those kill HP. Any good t-3 header should work fine though. Keep in mind you'll need type 3 "J" pipes as they're about 2 inches longer than bug/bus parts (BTDT and welded on some pipe to fake them). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
t-royR Samba Member
Posted: Sat Apr 06, 2024 11:09 am Post subject: Re: Type 3 engine build from type 1 case |
My Bad! To clarify, this is for a type 1.
With that said, any thing to add or some different recommendations?
Thanks _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
t-royR Samba Member
Posted: Sun Apr 07, 2024 6:37 am Post subject: Re: Type 3 engine build from type 1 case |
this piece of tin fell out from between the 1st and 3rd cylinders when I was feeding the cooling flap rod between the cylinders to connect to the thermostat while I installing the doghouse.
Can someone tell me where this piece belongs.
Thanks
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
FastyOrange Samba Member
Joined: November 15, 2012 Posts: 111 Location: Greenville, SC
Posted: Sun Apr 07, 2024 7:37 am Post subject: Re: Type 3 engine build from type 1 case |
Here is a shot from the samba gallery. You can see that piece of tin and how the cooling flap linkage passes through it. Those tabs simply press in the fins on the underside of the cylinder head.
Jon _________________ 72 FI Fastback
70 FI Fastback (Parts Car) |
t-royR Samba Member
Posted: Sun Apr 07, 2024 8:36 am Post subject: Re: Type 3 engine build from type 1 case |
thank you! _________________ T-roy
75 Super
71 Super
71 Ghia conv
69 Fasty
74 Ghia conv |
