Filipke Samba Member
Posted: Mon Apr 15, 2024 3:06 pm Post subject: How to determine bumper holes |
I installed a new nose and rear end. these are not provided with holes for the bumper supports. Does anyone have any measurements or tips on how to get the holes in the right place?
Disc Samba Member
Joined: September 24, 2009 Posts: 560 Location: Europe
Posted: Mon Apr 15, 2024 10:55 pm Post subject: Re: How to determine bumper holes |
Grab a piece of flat bar, dimentions close to bumper support - 30 x 4 cm. Slide it inside on the body where the bumper support mounts to the body and mark the points where it touch the body, drill 2 holes (upper and lower) from inside out. Now you have the position of the holes. The size can be determined by the rubber seals that slides over the bumper support and seal it against the body. _________________ The glory never gets old, just need new paint.
Nick |
Posted: Tue Apr 16, 2024 12:44 am Post subject: Re: How to determine bumper holes |
The bumper mounts in the front are also removed because new inside panels So that is not An option.
Also in the rear are new bumper mounts. But these positions are stock And Cannot bij placed at other positions… |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3918 Location: In Molinya Orbit
Loren Samba Member
Posted: Tue Apr 16, 2024 11:00 am Post subject: Re: How to determine bumper holes |
If you still need dimensions let me know and I can measure them on my 59 Ghia. |
Posted: Tue Apr 16, 2024 11:14 am Post subject: Re: How to determine bumper holes |
Loren wrote: |
Oohh yes please.
Is it possible to measure on the inside for the location of the mounts plz?
That would Be very helpfull! |
Legacy Samba Member
Joined: October 26, 2008 Posts: 219 Location: Charlotte Hall, MD
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Thu Apr 18, 2024 10:29 am Post subject: Re: How to determine bumper holes |
Filipke wrote: |
Loren wrote: |
Oohh yes please.
I need these too for my 65 that undergoing similar surgery. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Loren Samba Member
Posted: Mon Apr 22, 2024 1:23 pm Post subject: Re: How to determine bumper holes |
Hopefully these images help. I measured the width from the edge of the hole to the seam in the rear apron.
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13960 Location: Southampton U.K.
Posted: Fri Apr 26, 2024 2:47 pm Post subject: Re: How to determine bumper holes |
I already bought the rubbers that are around the openings and if I take these dimensions, they are indeed 2 cm wide and 7 cm high. thank you for the pictures!
for the height of the front bumper supports I found in these photos on my phone...
Posted: Fri Apr 26, 2024 2:50 pm Post subject: Re: How to determine bumper holes |
Does anyone have the dimensions and location of the front hole centrally in the front? where the horn is behind?
Thx |
