timalan1 Samba Member
Joined: October 14, 2004 Posts: 10 Location: Redding Calif
Posted: Mon Sep 19, 2005 8:28 pm Post subject: lowering squareback |
Can anyone tell me how low you can lower a sq/back without having an adjustable beam, and how?Thanks. Mine is lowered but would like it lower. |
Spezialist Banned
Posted: Mon Sep 19, 2005 8:33 pm Post subject: Re: lowering squareback |
timalan1 wrote: |
your car already has "adjustable" front end, rear. _________________
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Sep 19, 2005 8:38 pm Post subject: |
T-3's have adjustable beam from the factory. It is called a spline torsion bars _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
hoss Samba Member
Joined: May 01, 2003 Posts: 788 Location: San Jose, CA
Posted: Mon Sep 19, 2005 10:32 pm Post subject: |
This is detailed in the Type3 FAQ... I think its in a large, bold typeface right when you load it.
http://www.thesamba.com/vw/forum/viewtopic.php?t=68736 _________________ '54 Kombi | '57 356 Coupe | '57 Samba | '62 Notchback | '63 Beetle (36k Original Miles) | '66 Pigalle Sunroof Squareback | '70 Westy |
EverettB Administrator
Joined: April 11, 2000 Posts: 69857 Location: Phoenix Metro
spoon Samba Penetrator
Joined: September 08, 2005 Posts: 1458 Location: Monterey, CA
Posted: Fri Sep 23, 2005 6:16 pm Post subject: |
Ok you guys. What does a spline look like anyways? I have a Bentley and I cannot even figure out where to start. Not only that, every thread about this I look at contain terms like "spline", "inner", "degrees". Wow, can someone post a picture?
Justin
Posted: Fri Sep 23, 2005 6:53 pm Post subject: |
Let me see what I have. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Fri Sep 23, 2005 7:15 pm Post subject: |
Thanks Russ.
I am about an hour into the passenger side front over here. People say to separate this bolt, but then there are like 3 bolts! I am uber confused but I hope to have my baby slammed by the nights end.
Justin |
Posted: Fri Sep 23, 2005 7:19 pm Post subject: |
I dont have any pic of the front end apart. Sorry. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Fri Sep 23, 2005 7:43 pm Post subject: |
Ok, heres what I did..Im not sure if im doing the right thing but this is where i ended up.
Posted: Fri Sep 23, 2005 7:55 pm Post subject: |
GREAT! I now know how to lower my squareback. But, Im now assed out because I put th3e reference marks in the wrong spot because i didnt know what the hell i was looking at. Now I have a problem. |
Posted: Fri Sep 23, 2005 10:21 pm Post subject: |
Yeah whatever... my passenger side is now "randomly" done... it looks friggin sweet. I just need to finish up the other side tomorrow in the morning, I am hoping I get the splines identical to the passenger side, which will be a low percentage considering I have no idea how many splines I turned
Justin |
Posted: Sat Sep 24, 2005 7:32 am Post subject: |
Now, grease the hell out of it when you are done. Those bearings in there are made from "unobtainium". _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22463 Location: Kimball, Mi
Posted: Sat Sep 24, 2005 8:54 am Post subject: |
Also, recheck the toe in. I've found if you lower it 2 or more splines, the toe in changes, and actually goes toe out. On average, they will go 1/2 inch toe out, which means you have to adjust both sides to get it back to 1/8th inch toe in. This can be done in about a 1/2 hour with a tape measure. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Sep 24, 2005 4:05 pm Post subject: |
I finally finished. The drivers side look less than 45 minutes, and I even had crappy hand tools that didn't work right. The hardest part here is getting the ball joints/spindles back into place, that pretty much sucked.
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Sat Sep 24, 2005 10:28 pm Post subject: |
Lookin' good! Funny how the first side takes forever, huh? The second side is sooooo much faster.
Man, I love lowered Squarebacks! _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
redbug74 Samba Member
Joined: June 15, 2004 Posts: 292 Location: Far West Texas
Posted: Wed Sep 28, 2005 1:04 pm Post subject: |
I was pretty skeered to try it, but using the instructions on this site me and 2 buddies did it in a couple of hours. Yeah, the first side does take longer than the second. I guess its the boost of confidance when you see how easy it was. Thanks just my .02 worth |
paul_fio Samba Member
Joined: January 02, 2009 Posts: 128 Location: Reno, NV
Posted: Tue Oct 05, 2010 10:02 pm Post subject: |
What size are those tires and wheels? It looks great. |
BKiller Samba Member
Posted: Wed Oct 06, 2010 6:44 am Post subject: |
Nice bump of a 5 year old thread! _________________ VW SP2 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Wed Oct 06, 2010 7:03 am Post subject: |
spoon is still around Here! (9/22/10) _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
