70fasty ITMC Member
Joined: March 11, 2005 Posts: 578 Location: Jacksonville Florida
Posted: Fri Jun 23, 2006 8:32 pm Post subject: Brake problems again |
I had my MC rebuilt by Jim Adney and installed it today, I then bled all 4 wheels and my brakes are now only slightly better than they were before the rebuild (by slightly better I mean, still crappy) and now I can't get my brake lights to work, both plugs are plugged in... I need help fast, I'm trying to goto a car show tommorow morning. The MC is ATE brand. _________________ WRX Blue 1970 VW Fastback
ITMC |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34161 Location: Conejo Valley, CA
Posted: Fri Jun 23, 2006 9:25 pm Post subject: |
How are your flex hoses to each wheel? How old are the wheel cylinders/calipers? |
70fasty ITMC Member
Posted: Fri Jun 23, 2006 9:59 pm Post subject: |
the flex hoses are fine, the bentley manual said if i have to push the petal to the floor for brakes get new pads and shoes, which i did, then it said if problem persists replace master cylinder, which i did, and i still have to press petal to floor. _________________ WRX Blue 1970 VW Fastback
ITMC |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22764 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Jun 23, 2006 10:00 pm Post subject: |
Is the actuating rod on the brake pedal installed and adjusted properly? How is the rear brake adjustment? You should be just able to spin the wheels with some resistance in the back if they're adjusted properly. Check your front pads- if you have the thick anti rattle clip and the pad backing plates are bottomed out against it, you will get a low, weak pedal. If all that's OK, check to see if you are losing fluid anywhere. I'd check the front to rear line that runs under the carpet on the driver's side of the tunnel if I were you, especially if the fluid slowly goes away but there's no real apparent leak anywhere. Carpet and sound deadening can absorb a LOT of brake fluid.
Remember, even the best master cylinder is only as good as the rest of the system. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22516 Location: Kimball, Mi
Posted: Sat Jun 24, 2006 5:55 am Post subject: |
Does pulling up on the hand brake raise the pedal before it bottoms out? If so you still need to adjust the rear brakes tighter. Also if you have disc brakes, bleed them first, then do the rears (start with the right side on both ends). The hand brake should only need to be raised 3 or 4 clicks before locking the rear tires. If it's not doing this, then you need to adjust the rear brakes. I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
70fasty ITMC Member
Posted: Sat Jun 24, 2006 7:41 am Post subject: |
Well I'v been trying for the past 3 hours to figure out why my damn brake lights don't work, I guess the only thing it could be is both switches are bad, even though the brake lights worked before i sent it to ge rebuilt. It sucks though because now I can't drive to the show. Thanks for the input on fixing the brakes though, I'm going to work on that after I catch up on sleep _________________ WRX Blue 1970 VW Fastback
ITMC |
70fasty ITMC Member
Posted: Sun Jun 25, 2006 7:34 pm Post subject: |
Alright, I finnally got my brakes going plus the brake lights, we rebled it 3 times and finnally the lights kicked on, now all thats left to do is adjust the rear brakes and I'll be set. Thanks for the help guys _________________ WRX Blue 1970 VW Fastback
ITMC |
