timing with a 009 distributor
fonz15
fonz15 is offline
PostPosted: Wed Nov 04, 2009 2:44 pm    Post subject: timing with a 009 distributor Reply with quote
so my stock distributor messed up after 39 years so i got a 009. But my timing is still off. I heard that its hard to get the timing right and i should get a degree pulley or a 009 with a vacuum advance and that either of those should fix the problem. I have a 70 beetle std. stock 1600 engine. thanks for the help guys but what should i do? can i time it right with out the other stuff? will that timing stick? advice??
mjenner
mjenner is offline
PostPosted: Wed Nov 04, 2009 2:47 pm    Post subject: Reply with quote
9 Degrees - and -009's don't work well with the 34 pict carb
Paul Windisch
Paul Windisch is offline
PostPosted: Wed Nov 04, 2009 2:49 pm    Post subject: Reply with quote
In my opinion, you would be better off getting the stock distributor fixed, or getting a replacement of your stock distributor. If you MUST use a 009, get a degreed pulley or a timing light with an advance dial so you can adjust the gun to read advance with the stock pulley, then set it for 32 degrees max advance with engine rpm at 3000+.
*ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer
Glenn Premium Member
Mr. 010
Glenn is offline
You time a OO9 to 30 degrees BTDC @ 3500rpm... you should not time it at idle.
They don't make a OO9 with vacuum advance. (and don't say the 0 231 137 009 that's not what he's asking)
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Nov 04, 2009 4:20 pm    Post subject: Reply with quote
Here is how to mark a stock pulley....from www.type2.com
Timing the Bosch OO9
by Ken Hooper
The thing about timing is that what matters most is what happens at cruising speed, maximum advance--that's where you can burn up an engine quickly if your timing is too far advanced.
But: The Bosch 009 does not have a predictable advance curve--the German ones are different from the Brazilian ones and the worn ones are different from the new ones and on it goes. The natural result of this is that just because you've timed the 009 properly at idle does not mean you have any way of knowing what's going on at highway speeds.
So while the stock vacuum advance distributors can safely be timed at idle (or even timed statically per Muir, although this is never optimal), the 009 has GOT to be timed to about 30 degrees TOTAL ADVANCE with a timing light. Which means you have to rev it up until the distributor stops advancing before you can dial it in.
It takes three hands and if the process isn't painful, you aren't doing it right. =^ ) It's okay to time it statically at around zero degrees in order to get the engine started, but you have to finish the process dynamically by making lotsa noise.
It is very easy to find 30 degrees without a degree wheel as long as you know where top dead center is. From TDC, measure an inch and three quarters (1 3/4") to the right around the diameter of a stock pulley. That's about 28 degrees, go a tinch further and mark it with fingernail polish or something.
If you don't know where TDC is, then you have to pull the #1 spark plug and push the eraser end of a pencil in the hole and rotate the engine and feel the piston until you figure it out.
A basic timing gun is ~$20, get one and carry it with you, it's an irreplacable tool.
ibjames
ibjames is offline
PostPosted: Wed Nov 04, 2009 4:29 pm    Post subject: Reply with quote
when you talk about the degreed pully you are talking about the big one with all the little marks on it right? Don't those run like $30 or so? I'd just get one
Max Welton
Max Welton is offline
PostPosted: Wed Nov 04, 2009 4:43 pm    Post subject: Reply with quote
$30 sounds like a lot more than a ruler.
Max
1967 Type-3 Fastback
Mr. 010
Glenn is offline
PostPosted: Wed Nov 04, 2009 4:52 pm    Post subject: Reply with quote
Or just print this.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
bookoojoe
bookoojoe is offline
PostPosted: Wed Nov 04, 2009 5:24 pm    Post subject: Reply with quote
Glenn wrote:
Or just print this.
Shocked THAT IS BAD ASS!
1991 Cabriolet. Black with white top. Sexy.
Why is abbreviation such a long word?... Did you know that the fear of long words is called hippopotomonstrosesquippedaliophobia? its true! look it up!
"We learn from history that we don't learn from history."
Max Welton
PostPosted: Wed Nov 04, 2009 6:04 pm    Post subject: Reply with quote
Oh, come on!
Isn't a steel ruler on a Berg pulley is a least a little bad-ass?
Laughing
Max
Mr. 010
Glenn is offline
PostPosted: Wed Nov 04, 2009 6:05 pm    Post subject: Reply with quote
Max Welton wrote:
Oh, come on!
Yes it is.... but it's better on a red car.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
ibjames
ibjames is offline
PostPosted: Wed Nov 04, 2009 6:51 pm    Post subject: Reply with quote
we should have that picture stickied?
Christofur
Christofur is offline
PostPosted: Thu Nov 05, 2009 1:25 am    Post subject: Reply with quote
wait wait wait.... i timed my 009 at idle.......should i go retime it at 3500 RPMS?
Randy in Maine
PostPosted: Thu Nov 05, 2009 5:07 am    Post subject: Reply with quote
What part of this did you miss?
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Thu Nov 05, 2009 7:42 am    Post subject: Reply with quote
It is.
http://www.thesamba.com/vw/forum/viewtopic.php?t=183060
"Timing marks on stock pulley"
http://www.thesamba.com/vw/forum/viewtopic.php?t=251672
Christofur
PostPosted: Thu Nov 05, 2009 9:09 am    Post subject: Reply with quote
mmhh i timed my bug to 28 or so at idle not at 3500 RPMS better go do that and that would explain the high rpm back fire.
Mr. 010
Glenn is offline
PostPosted: Thu Nov 05, 2009 9:15 am    Post subject: Reply with quote
28 at idle will result in 50 degrees advance when driving....
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
