scvw Samba Member
Joined: September 02, 2006 Posts: 3553 Location: South Carolina
Posted: Fri Mar 05, 2010 6:48 pm Post subject: |
I used the same pic and measurements above when I drilled the fenders for my heart tail lights. If I'm not mistaken that is 25mm and not 26mm so the total vertical measurement is 60mm. _________________ 58 Coral Red ragtop(Diana's car)
63 Ruby Red SC
67 Pearl White SO42
SOUTHERN INTEGRITY AIRCOOLERS |
GermanRust52 Samba Member
Posted: Fri Mar 05, 2010 7:45 pm Post subject: Re: Heart tail light position |
| Shane wrote: |
Does anybody have the image posted sometime back about where to place heart tail lights? Yes, I did a number of searches and it didn't come up. Maybe someone will have better luck than I did.
Thanks,
Shane |
bwaz Samba Member
Posted: Fri Mar 05, 2010 11:43 pm Post subject: |
| great! thanks for the notes |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1930 Location: Finland, Jakobstad
59 dormi Samba Member
Joined: September 06, 2006 Posts: 626 Location: Ontario Canada
Posted: Sat Mar 06, 2010 12:09 am Post subject: |
Well I measured it out according to the metric diagram and they still sat too high so it's gotta be down to what brand of fender you are using as well _________________ 1959 Dormobile
Mini R53 bob the tomato
Range Rover L322 |
Egypt Classic Cars Samba Member
Posted: Fri Aug 13, 2010 1:02 am Post subject: |
For the zwitter taillight position is that the same for European cars also? and what is the diameters for the holes?
Ashraf |
jeffff Samba Member
Joined: February 23, 2006 Posts: 1044 Location: Alberta, Canada
Posted: Mon Aug 23, 2010 12:33 pm Post subject: |
| Egypt Classic Cars wrote: |
Ashraf |
I'll bump........yes, what are the diameters for the holes? |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1468 Location: Eastern WA
Posted: Mon Aug 23, 2010 12:44 pm Post subject: |
I'll throw this question onto the thread, I guess it's the appropriate place. Are the Heart and 55' Egg tail lights measurements the same? I have aftermarket fenders, and nothing to match up. Thanks!!
Scott |
jeffff Samba Member
Posted: Mon Aug 23, 2010 1:03 pm Post subject: |
| motofly196 wrote: |
Scott |
Yes they are the same.
Hebster mentioned that the above diagram is somewhat of a "rough" measurement. I disagree.
The most important measurement is "how high are the tailights"? The above diagram answers that. Regardless of what rear fenders you have (OG or aftermarket) as long as the top of the housing is in line with where the fender & apron curve outward you're good to go. Now with the height established, the outside of the housing is 5 1/8 inches outward from the beading......done. With those 2 measurments anyone should be able to correctly position pre-55 tailights.
All of those metric measurements help...no question, but once the position of the housing is established, everything else falls into place. |
Russ Samba Member
Joined: January 12, 2003 Posts: 1560 Location: Langley B.C.
Posted: Mon Aug 23, 2010 2:29 pm Post subject: |
that first template has been around for years i used it when i did my cars years ago now.
old but works great _________________ Cruiser pedals for sale (see my ad's)
55 hardtop finally finished
65 beetle done:) |
Oldnslow Samba Member
Posted: Mon Feb 28, 2011 11:22 pm Post subject: |
I found this in the "readers rides" forum and thought it shows the placement of the early oval tail lights. I know, they are eggs but the shape and placement are the same. They are really low like looking through the overrider bars. |
Posted: Tue Mar 01, 2011 6:16 pm Post subject: |
No wonder why there are so few Early 55's around! U.S. mandated the use of the over-riders and went ahead and hid the small tail lights!! I know when my 55' is road worthy, I will have the lights low, over-riders installed, but will definately add a 3rd brake light inconspicuously somewhere for MY protection!! Great Pic!
Scott |
janerick3 Samba Member
Posted: Tue Mar 01, 2011 10:40 pm Post subject: |
| motofly196 wrote: |
Scott |
I got pulled over by a state trooper a couple of years ago for having my lights blocked by the overriders--I got off with a verbal warning. My mistake for going through an area where the troopers were setting up for a DUI roadblock... _________________ Thanks,
Jan K. |
Posted: Sat Mar 05, 2011 9:42 am Post subject: |
The cops are the same way around here, that's why I need to figure a way to mount a 3rd brake light somewhere that it will only show when brakes are applied. I bought a vintage School Bus "STOP" light, but it's the bigger one, and looks really tacky.
Scott |
nick696 Samba Member
Posted: Sun Apr 08, 2012 1:40 am Post subject: |
| Anyone know the diameter of the holes? |
kdfwagon Samba Member
Joined: March 21, 2006 Posts: 290 Location: Thomasville, N.C.
Posted: Sun Apr 08, 2012 6:09 am Post subject: |
I don't know if this helps but I found this on an old file on my laptop.
_________________ Brianna's Grandpa |
Chick Iverson Samba Member
Posted: Sun Apr 08, 2012 9:58 am Post subject: |
| motofly196 wrote: |
Scott |
..... ...here is my solution for a third brake light... _________________ '59 Euro convertible--'56 type 2 double door panel w/Chick Iverson logo-....2 wrongs don't make a right, but 3 lefts do! |
Posted: Sun Apr 08, 2012 3:40 pm Post subject: |
| kdfwagon wrote: |
Thx but this is the one for past heart light
I need the diameters for the heart lights itself.
I guess I'll just measure my brackets and guess the other holes |
Posted: Sun Apr 08, 2012 7:38 pm Post subject: |
| nick696 wrote: |
for the gasket or seal 1/2 inch,and for the bracket 1/4. |
srm1956 Samba Member
Joined: February 18, 2008 Posts: 245 Location: Huntington Beach, CA.
Posted: Tue Apr 10, 2012 11:55 pm Post subject: |
These heart tail light aren't to high are they?
