INCAPPLES Samba Member
Posted: Wed Jul 23, 2014 6:51 am Post subject: Walk thru bus question--spare tire tub |
HI
1)Is the spare tire tub removable on the walk thru busses?
2)easy to replace/install a new one?
3) Is possible for a walk thru to not have a spare tire tub installed from factory?
Trying to figure out what happened to my bus(removed cleanly or never had it in)
Thanks
dubstar Samba Member
Joined: January 17, 2009 Posts: 1437 Location: New York
campingbox Samba Member
Joined: November 14, 2000 Posts: 10199 Location: Petaluma, CA
Posted: Wed Jul 23, 2014 7:01 am Post subject: |
Its spot welded in place, if you cut the spot welds and remove it you'll have a large hole needing patched.
I have never seen a walk through bus without a spare tire well. |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Posted: Wed Jul 23, 2014 7:03 am Post subject: |
thanks guys
what I feared
someone must have done quit the effort to add the walk thru portion |
Clara Samba Member
Posted: Wed Jul 23, 2014 7:12 am Post subject: |
EDragnDean wrote: |
Its welded to the body, it can be drilled out and replaced if its rusted.
Often they are removed for a gas heater system, do you have duct work and an extra hole for the intake? Pictures will help.
They are not removed for the gas heater system shown. That is Eberspacher and fits with the w/t spare tire well.
They are removed for the S-W gas heater. |
Posted: Wed Jul 23, 2014 7:36 am Post subject: |
that's why the 2 holes on the engine bay floor right people....maybe?
thanks for the help and sorry for the bad pic |
Posted: Wed Jul 23, 2014 7:42 am Post subject: |
Thanks for the help and replies! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69837 Location: Phoenix Metro
Posted: Wed Jul 23, 2014 8:36 am Post subject: |
Another Southwind heater photo:
Wow, didn't know there was an official block-off plate to use there.
My Bus has a piece of Sea Blue metal hacked out of another Bus...
My heater is missing so I blocked off those 2 holes with some expanding rubber stoppers from the hardware store - it seemed bad to have hot air being sucked in there.
You can see the Southwind ducting that goes into the passenger area here too _________________ How to Post Photos
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Jul 23, 2014 9:01 am Post subject: |
EverettB wrote: |
Posted: Wed Jul 23, 2014 9:04 am Post subject: |
Great thanks a lot.
And the hole has been patched to the left of the tank.
All these answers to all the questions! Relief!
Thanks for the tip on the hole patches Everett as well. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Wed Jul 23, 2014 9:11 am Post subject: |
Even without the Southwind conversion, those spare tire wells got monkeyed with regularly over the years. I had a '64 WT deluxe which had the well cut out for unknown reasons. Got a replacement well cut with a bit of the surrounding steel from a parts bus. I just put it in the hole, and it sat there just fine with a spare tire holding it in place. Came in handy to pull it out when changing the engine. Allowed access to that darned upper driver side engine mount nut. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1784 Location: Santa Rosa, Ca
Posted: Wed Jul 23, 2014 9:51 am Post subject: |
Great info, nice to know that a Eberspacher will fit without having to remove the spare tire well. The S-W heater looks like some kind of a Transformers reject. |
caseydenise Samba Member
Joined: April 25, 2004 Posts: 1637 Location: The Great Swamp, NJ
Posted: Wed Jul 23, 2014 2:32 pm Post subject: |
I have a 67 Westy walkthrough with no spare tire hole. My bus has it's fair share of hacks though. _________________ Central Jersey Volkswagen Society - President |
Clara Samba Member
Posted: Wed Jul 23, 2014 8:54 pm Post subject: |
EDragnDean wrote: |
INCAPPLES wrote: |
Yes, you probably also have a hole in your fire wall to the left of the gas tank. |
x2
Those two holes to the left of the engine area are classic signs of a one time S-W heater install.
Like they said, for the S-W heater, the spare tire well got removed.
I heard that a S-W heater works great. I like the looks of a Eberspacher better, though. Old timer VW mechanic I talked to said he installed a S-W heater a week back in the day. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14280 Location: Casa de Oro, California
Posted: Thu Jul 24, 2014 8:19 am Post subject: |
Your engine bay and engine are well done, INCAPPLES.
On that Stewart Warner brochure, how do they raise the spare tire: just use another lug hole and the bracket stays the same? |
Posted: Thu Jul 24, 2014 9:07 am Post subject: |
BarryL wrote: |
Yep. |
