jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Thu Jul 24, 2014 8:38 pm Post subject: 1968 Ghia ignition replacement |
I couldn't find much info on replacing the ignition assembly on '68 Ghias so I figured I'd take pics while I did mine.
So, after you have the steering wheel off and have removed the turn signal ring, you will need to remove two screws to slide off the ignition cover.
The ignition assembly will slide right out.
You will need to use a small point to press in the locking tab on the lock cylinder. I used a pen tip.
There is a retaining pin pressed into the housing to hold down the coupler and spring. Press this out with needle nose pliers. It will not come out all the way.
Coupler removed
The ignition switch slides into the bottom of the housing and is secured by a small threaded pin. Remove this pin and slide out the switch.
Be careful, mine came out in pieces and the metal can stuck inside and had to be soaked in penetrating oil to remove it. Be very careful trying to pry it out if it is stuck as the housing is made of very soft pot metal and will crack easily!
New switch just slides into the housing and secures with the threaded pin
Just a tiny bit of blue Loctite is all you need.
When reinstalling the coupler, note the shape of the pin as it fits a certain way into the switch. Also, the cutout on the left must clear the notch inside the can.
I added a little white lithium grease before installing the coupler.
The tab on the bottom of the lock cylinder fits into the hole on the coupler.
The only problem I had with the reproduction lock cylinder is that it had no cutout for clearance of the pin that holds the coupler down and doesn't allow the lock cylinder to slide in and clip into place.
This is the notch on the OEM cylinder
A Dremel with a metal cutting bit will make a quick notch on the repro cylinder.
The lock cylinder will now push in far enough to snap into place and can be installed back into the steering lock column.
I hope this helps. Main thing is be careful with the ignition housing because it's so soft. I tried prying the old switch can out but it quickly started to distort and gouge the housing. Needless to say I stopped and just soaked it.
Good luck! _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member)
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3918 Location: In Molinya Orbit
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13960 Location: Southampton U.K.
dcat917 Samba Member
Joined: April 13, 2014 Posts: 185 Location: Greenville, SC
Posted: Fri Jul 25, 2014 2:23 pm Post subject: |
Thanks, I hope I helps someone. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
Mrfun2fly Samba Member
Joined: November 29, 2015 Posts: 548 Location: New Mexico
Posted: Sat Feb 13, 2016 10:16 pm Post subject: Re: 1968 Ghia ignition replacement |
Jared,
I noticed your old ignition had only 3 wires but the new ignition has 4 (the grey is extra). What did you do with the grey wire?
Thanks,
Lee |
Posted: Mon Feb 15, 2016 10:22 am Post subject: Re: 1968 Ghia ignition replacement |
The grey wire isn't used. _________________ -Jared
Posted: Mon Feb 15, 2016 10:36 am Post subject: Re: 1968 Ghia ignition replacement |
Jared,
Just to be clear, the key switch part actually needs to be removed to install the electronic portion of the ignition?
Thanks! |
Posted: Wed Feb 17, 2016 12:26 am Post subject: Re: 1968 Ghia ignition replacement |
If you are just replacing the switch, it goes in the bottom. Theres a small flat head screw that has to be removed to get the switch out but it helps to remove the key housing too. _________________ -Jared
xzener Samba Member
Posted: Wed Oct 26, 2016 6:27 pm Post subject: Re: 1968 Ghia ignition replacement |
Was about to ask about the 4-wire part I received... Thank goodness I found this thread. Very informative. My 68's ignition has been rebuilt, now to shove it in and wire it up. Thanks everyone!! _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Wed Oct 26, 2016 9:29 pm Post subject: Re: 1968 Ghia ignition replacement |
Hi Jared
Since you're the expert on this, please help me solve this problem. My '68 Ghia has the original switch and key. When I turn the ignition on, the key does not jump back to a neutral position, with the result that the starter motor keeps running until I manually move the key back to neutral.
I have a new switch - the part you replaced. Before I start replacing things I'd like to know where you think the problem lies. Please.
Chris M _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4576 Location: St Charles, MO
Posted: Wed Sep 13, 2017 7:50 am Post subject: Re: 1968 Ghia ignition replacement |
It looks like I'll be doing this on a Jan of 1970 production Ghia Coupe soon. I imagine that the process so very well shown above on a 1968 will be fairly similar on a 1970, but if anyone has done this on a 1970, can you add any details and differences in the process? I believe that the electrical switch is broken on mine, I think the key mechanism is fine and will attempt to re-use that. I ordered the switch from KGPR and it looks similar to the one used in the '68 above with four wires. So am I also NOT using the grey wire at all in my 1970 Ghia? Thanks for any advice! I'm not looking forward to this, but until I pull this repair off, I can't drive my old Ghia...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Wed Sep 13, 2017 9:41 am Post subject: Re: 1968 Ghia ignition replacement |
BulliBill wrote: |
Bill |
The gray wire is for the 'key left in' buzzer. Your choice to still use it or not. |
Posted: Wed Sep 13, 2017 9:50 am Post subject: Re: 1968 Ghia ignition replacement |
I would probably hook up the key buzzer reminder feature with that gray wire. When looking at my original dirty harness, what wire or connector or terminal do I hook that gray wire to? Do you know the color or combination of colors of the wire in the old original harness that the new grey wire should make too? I have an original dealership wiring diagram for my 70 guia to refer to, just need to find what that grey wire should connect to.
Thanks so much for the speedy reply and advice. My symptom initially was that I would turn the key to the on position and then continue to turn it all the way to "start" position and the engine would crank over and fire up, but when I release the key to spring back to the "on" position the engine would die. So I cannot get the engine to run without repairing what I assume is the electrical part of the ignition switch. Thanks again!
Posted: Fri Sep 15, 2017 12:19 pm Post subject: Re: 1968 Ghia ignition replacement |
Hi all,
I got tired of dicking around with the Ghia and not being able to drive it, so I decided to jerry-rig the brand new new switch in and unplug the old switch still in the steering column of my 1970 Ghia. I wanted to test it in a way that I could definitely confirm that the original electrical switch in the column was the culprit of my non running issues. So I unplugged the wires behind the dashboard to the fuse box and light switch from the original electrical switch. Then I wired in the new switch and plugged it up and left it laying loose up in the front trunk area. Then i hooked up the battery and held my breath and used a screwdriver to simulate the key and turn the switch to "start" and back to "on/run". The new switch worked like a charm! It was so good to hear that 1776 running after about 2 years of sitting in the garage. So good that I left everything the way I wired it and took the car out for a 25 mile drive to run some fuel through it and Ponder my next move. Now I will have to take the Formuling France steering wheel off the column and take apart the ignition switch/lock assembly and remove the old original electrical switch and reinstall the new one and putting everything back together. I might even re-install the stock steering wheel again, who knows? Great to hear the Ghia running again!
If I remember. I will try to take some photos of the process to add to this thread concerning a January of 1970 production Ghia switch replacement...
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Posted: Fri Sep 15, 2017 4:25 pm Post subject: Re: 1968 Ghia ignition replacement |
BulliBill wrote: |
If I remember. I will try to take some photos of the process to add to this thread concerning a January of 1970 production Ghia switch replacement. |
Glad to read you had a moment of enjoyment with your Ghia. Endless problem solving gets old ofter a time but getting out on the road is a joy.
Yes, please do add to the thread, we all enjoy well documented contributions in that regard.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
xzener Samba Member
Posted: Fri Sep 15, 2017 5:00 pm Post subject: Re: 1968 Ghia ignition replacement |
And don't use third party picture hosting. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Sat Sep 16, 2017 7:11 am Post subject: Re: 1968 Ghia ignition replacement |
xzener wrote: |
And don't use third party picture hosting. |
I didn't post ANY photos yet in my above posts. I'm assuming the comment from "xzener" was a preemptive warning? I have NEVER used third part photo hosting, I have ALWAYS hosted any photos that I have right on the Samba gallery. Did I do something wrong, did I miss something? Are you guys are "harshing my Ghia buzz"?
xzener Samba Member
Posted: Sat Sep 16, 2017 7:23 am Post subject: Re: 1968 Ghia ignition replacement |
Just a friendly reminder. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
