rokcrln Samba Member
Joined: August 07, 2005 Posts: 162 Location: Winters ca. 95694
Posted: Wed Aug 17, 2005 7:42 pm Post subject: What cooling tin's for a T4 motor in a Type3? |
Ok we are moving ahead and now we have the T3 (64 Notch) and the T4 motor out of a camper Bus. The motor is a 2.0L and I want it to cool as well as posible. So what do we need as far as cooling tin and fan schroud (sp?)? I have two or three sets of T3 stuff and one complete T4 set up. What have people done for this? What works the best?
Thanks for the input!
Kevin _________________ 64 Sun Roof Notch S
71 Chevy PU, bagged,body dropped,LT1
71 Ford Bronco stock 59K miles
05 Tube frame rockcrawler
04 Mini Cooper S |
Zarana-X Samba Dreadnok
Joined: September 03, 2004 Posts: 372 Location: How could hell be any worse?
Posted: Wed Aug 17, 2005 7:49 pm Post subject: |
Nothing is interchangable. Just use the Type 4 shrouding and stuff. _________________ "In order to create, you have to destroy." |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23567 Location: Kimball, Mi
Posted: Wed Aug 17, 2005 8:17 pm Post subject: |
| Zarana-X wrote: |
| Nothing is interchangable. Just use the Type 4 shrouding and stuff. |
Yup, that's the way I'm going with mine. I am going to do a convserion boot to get the air into the engine though. I've already got both sides, so it should be a little easier.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| "Friends are God's way of apologizing for relatives." |
| Tram wrote: |
| People keep confusing "restored" and "restroyed". |
Posted: Wed Aug 17, 2005 8:39 pm Post subject: |
That is what I thought as well. But before I made a air duct and boot I thought I would ask. At least I am on the same page
Thanks guys!
04 Mini Cooper S |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11497 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Aug 17, 2005 8:43 pm Post subject: |
I have read where a leather boot has been made to fit the Type 3 body housing to the Type 4 cooling tin... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Wed Aug 17, 2005 9:14 pm Post subject: |
There is a 411/412 wagon only, flange that bolts onto the fanshroud so a boot can be used to get cool air into the shroud. NO the stock type3 boot won't work. I've been told the stock 411/412 wagon boot will fit but haven't found one, so I can't confirm. This is at least a good starting point for fabricating a boot. They are hard to find but they are out there. Parting out type4 ads would probably be the most likely source. Remember, the fastback boot/flange won't work so don't waste your money.
I believe my only gallery pictures are shots of this part. So search my pics for an idea. |
Posted: Thu Aug 18, 2005 4:40 am Post subject: |
Thanks Josh I will look that way as well. You have part #'s listed in your pics so that should help.
04 Mini Cooper S |
Posted: Thu Aug 18, 2005 3:59 pm Post subject: |
| josh wrote: |
| There is a 411/412 wagon only, flange that bolts onto the fanshroud so a boot can be used to get cool air into the shroud. NO the stock type3 boot won't work. I've been told the stock 411/412 wagon boot will fit but haven't found one, so I can't confirm. This is at least a good starting point for fabricating a boot. |
Yes, this the part I've got (both the flange and the boot), but the "body" side of the t-4 boot looks much smaller than the t-3 part. My plan was to merge the 2 parts together (t-3 & t-4 boots), and create the part I needed.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
tomnotch Samba Member
Joined: October 22, 2004 Posts: 788 Location: Key Peninsula, Wash.
Posted: Thu Aug 18, 2005 5:20 pm Post subject: |
http://tunacan.net/t4/tech/type3.shtml
read and absorb
btw, the t4 SB boot fits neatly inside the T3 body hole, almost like the factory kinda knew something......... _________________ Tom
DVKK
DSD, Dark Side Disciples
Progenitor |
Posted: Thu Aug 18, 2005 6:00 pm Post subject: |
| tomnotch wrote: |
| btw, the t4 SB boot fits neatly inside the T3 body hole, almost like the factory kinda knew something......... |
Cool, I learned something new today. Those are always good days. Would you recomend building an upper trans moount (attached to the body) or do you think a heavily modified t-3 engine hanger would work? I've got a t-3 one here that someone had badly butchered for full flow that I thought about reconstructing, and I've got a cast Iron t-4 mount (2 bolt style), that I'm using as a fab guide. This IS going into an AT car, if that helps. Sorry for the thread hi-jack.  _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Thu Aug 18, 2005 6:06 pm Post subject: |
| Bobnotch wrote: |
| tomnotch wrote: |
Cool, I learned something new today. Those are always good days. Would you recomend building an upper trans moount (attached to the body) or do you think a heavily modified t-3 engine hanger would work? I've got a t-3 one here that someone had badly butchered for full flow that I thought about reconstructing, and I've got a cast Iron t-4 mount (2 bolt style), that I'm using as a fab guide. This IS going into an AT car, if that helps. Sorry for the thread hi-jack.  |
I would look at the way the T-2 automatic mounts. Or spread the load out to the shock tower area.
I think ISPWest has something. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Thu Aug 18, 2005 6:14 pm Post subject: |
| Russ Wolfe wrote: |
| Bobnotch wrote: |
| tomnotch wrote: |
I think ISPWest has something. |
Thanks for the recomendation Russ. I guess I'll be tapping some holes into the AT, so I can add some mounting studs. _________________ Bob 65 Notch S with Sunroof
| Tram wrote: |
| Tram wrote: |
Posted: Thu Aug 18, 2005 6:42 pm Post subject: |
My Notch has teh wish bone tranny mount that the 901 will be geting mounted and strapped to. Then the motor will get the rear mount that will be built into the roll cage mounting feet. The more I look at the t3 and t4 fan housings it should be real easy to fab a factory looking boot/mount. Thanks to all for the input.
04 Mini Cooper S |
Posted: Thu Aug 18, 2005 9:44 pm Post subject: |
Mounts should be a seperate topic.
and I have something to share on them. _________________ Tom
DVKK
Progenitor |
Posted: Thu Aug 18, 2005 10:06 pm Post subject: |
Well we have covered the tin issue! So how bout them mounts?
04 Mini Cooper S |
Rome Samba Member
Joined: June 02, 2004 Posts: 10744 Location: Pearl River, NY
Posted: Fri Aug 19, 2005 11:35 am Post subject: |
Try this place for some T4 parts:
http://www.volksrepair.com/page/page/1556665.htm
I stopped by there last week while in the area, and they have at least 2 T4 wagons in the back... don';t know if they'll part them out or if they have loose parts off other cars. |
BerT3 Samba Member
Joined: August 18, 2002 Posts: 1569 Location: Antwerp
Posted: Fri Aug 19, 2005 12:03 pm Post subject: |
| Quote: |
| I've been told the stock 411/412 wagon boot will fit but haven't found one, so I can't confirm. |
Hello,
One of the parts cars I had recently had a stock T4 air bellow instead of the normal one.
All I can say it was a perfect fit !
I liked it better than the T3 one - no brides !
I don't know it was reversed as opposed to the "normal" installation way in a T4.
I mean small hole to big hole at the engine or big hole to a smaller hole at the engine (stock T3)
BerT3 |
square-to-go Samba Member
Posted: Tue Sep 20, 2005 6:03 pm Post subject: try the stock |
| i used a stock t-3 bellow coupled with a t-4 wagon shrould and was able to make it fit. |
Posted: Tue Sep 20, 2005 6:11 pm Post subject: |
After looking at for abit I will be using the t3 billow and a t4 shroud with a custom sheet metal tin the same shape as a t3 tin. It will be a bit of work but not that bad for what the finished product will be.
04 Mini Cooper S |
DMNCLNR Sir Camp'alot
Joined: November 12, 2003 Posts: 2897 Location: Newport Beach Ca
Posted: Tue Sep 20, 2005 10:40 pm Post subject: |
Sorry to hijack your thread and ask a completely rediculous question, but....drumroll, If i was to put a type 4 motor in say a TYPE 34 (not my 63) would i have to do cutting if i wanted to run dual carbs? Is there a 2 barrel that would fit under the engine cover with a filter and get enough airflow? I found a pretty good deal on a type 4 motor and a ratty type 34 to mount it up in. _________________ To his their own PBJ
Pl@y@ #1 |
