sbnova Samba Member
Joined: January 27, 2005 Posts: 741 Location: Lakeland,FL
Posted: Thu Sep 08, 2005 6:16 pm Post subject: What is the CFM of popular carbs? |
I read all about Weber 40's,44's,48's and Dellorto 40's and Kadrons, and Solex's, but what CFM's are some of these capable of? I know swapping venturis changes the flow, so an approximate is fine.
On a side note- I thought I posted this question a few days ago, but I cant find it so I appologize if this is a duplicate post. _________________ Link to my build thread- Updated 6-6-07 http://www.thesamba.com/vw/forum/viewtopic.php?t=210613
check my sites to see my work;
http://www.cardomain.com/ride/1564293 (bug)
http://www.cardomain.com/ride/448794 (Vette,Nova,Typhoon) |
DRD RACING HEADS Samba Member
Posted: Sat Sep 10, 2005 4:45 pm Post subject: Re: What is the CFM of popular carbs? |
I flowed and IDA with a 42mm choke, it was 325 cfm. This will give you and idea. Smaller carbs will be around 225 cfm on up. _________________ "DRD RACING HEADS"
"CNCHEADS and engine parts"
We sell What Works!
HTTP://WWW.DRDRACINGHEADS.COM
Email [email protected]
Phone-714-545-4100
DRD Online Store
HTTP://WWW.DRDRACINGHEADS.COM/Xcart/ |
sbnova Samba Member
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1875 Location: Grass Pants, Orygun
Posted: Sun Sep 11, 2005 10:49 am Post subject: |
Here are few I found over the years:
Source: JayCee Ent./Perf.Tech- flowed on Superflow 600 @25" water
Weber 48mm IDA w/44 venturi-348cfm (per venturi) 1392cfm total
Weber 51.5mm IDA w/47.5 venturi-395cfm (per venturi) 1580cfm total
JayCee 62mm /55 venturi -633cfm (per venturi) 2531cfm total
with 20" water
Holley 1150 Dominator (4 barrel) 1180cfm (est.) total
Weber 48mm IDA w/44 venturi-311cfm (per venturi) 1244cfm total
Weber 51.5mm IDA w/47.5 venturi-353cfm (per venturi) 1413cfm total
JayCee 62mm /55 venturi -565cfm (per venturi) 2260cfm total
Source: Gene Berg Ent. no flow specs given
Weber 48mm IDA 40mm venturi-561 per carb
Weber 48mm IDA 42mm venturi-583 per carb
Source: CB Performance 1991 catalog- no flow specs or venturi sizes
I assume these numbers are @28" H2O per venturi
Dell'Orto 48mm DRLA 388.5cfm
Weber 48mm IDA 372.1cfm
Dell'Orto 45mm DRLA 329.3cfm
Weber 44mm IDF 292.3cfm
Dell'Orto 40mm DRLA 266.4cfm
Weber 40mm IDF 212.8cfm
Dell'Orto 36mm 205.8cfm _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2050lbs with driver
7.76 @ 89.55mph 1/8 mile
12.27 @ 109.56 mph 1/4 mile
https://youtube.com/shorts/GmifEu5QvnA?si=OIw8eM7QU3LMhtiz
https://www.tiktok.com/t/ZT68foYFS/ |
sbnova Samba Member
Bugman Jeff Samba Member
Joined: May 20, 2004 Posts: 636 Location: Evansville, WI
Posted: Mon Sep 12, 2005 12:23 am Post subject: |
I've often wondered why such a small motor uses so much carb? can anyone explain that to me? I mean, 600 CFM is just right for a mild 350(5.7L) Chevy, yet a 3.0L VW will use 1,200 CFM? _________________ Restorer of Porsche Speedster 80486  |
jamestwo Samba Member
Posted: Mon Sep 12, 2005 5:18 am Post subject: |
on a V8 with a single plane, each cylinder has full benifit of of all four barrels, on a VW with one ventura per cylinder, each cylinder only draws from one barrel.
So on a V8 with a 65 cfm, each cylinder can draw up to 650 CFM, because only one cylinder draws at a time.
running four 325 cfm venturas on a VW would be the same as running a single 325 cfm carb on a single plane intake. |
dawi4x4 Samba Member
Posted: Mon Sep 12, 2005 6:15 pm Post subject: |
my pulling tractor is a chevy 2.3L, demon 1050 cfm
use to run it on my pulling truck 468 ci bbc |
sbnova Samba Member
A.J.Sims Banned
Joined: December 11, 2003 Posts: 1016 Location: LowBugget.com 982 N Batavia A4 Orange Ca 92867
Posted: Tue Sep 13, 2005 5:14 pm Post subject: |
Stock 40 mm Kadron with 28mm vent and stock aircleaner brackit.
165cfm @25"
Our 46mm Kadrons with 38mm vents and our Air Top kit.
243cfm @25"
Our 48mm Kadron with 42mm vents,Air Top Kit, Spray Bar
307cfm @25" With JC.Ent stack 330cfm @25"
Terry Cloyd Banned
Joined: March 23, 2004 Posts: 2218 Location: Valley Center "SO CAL"
Posted: Wed Sep 14, 2005 1:11 pm Post subject: |
| A stock VW dual port head with 35.5mm intake and 32mm exhaust valves will flow 92.93 cfm with 44s. At .450 lift the head flows 126.35 at .600-in lift the flow is 139.01. Terry |
vdubyah73 Samba Member
Joined: July 05, 2003 Posts: 2541 Location: somewhere in Texas, my house has wheels
Posted: Wed Sep 14, 2005 2:09 pm Post subject: |
Is this 1 barrel or both?
Thanks Bill |
Posted: Wed Sep 14, 2005 5:11 pm Post subject: |
Does that mean I can tell some mook thats raggin' on my 2275 cc dune buggy that I got 1170 cfm worth of carb on my puny little VW engine?
Thanks, Bill |
RanX0R0X Samba Member
Posted: Thu Dec 02, 2010 7:10 pm Post subject: |
| jamestwo wrote: |
Yeah, I know, this post was from a long time ago but I'm curious to know how to think about the flow rate.
1 cubic foot/minute = 0.471 947 45 liter/second
Dell'Orto 40mm DRLA
266.4cfm*0.471 947 45
=~125L/second
1914cc/4=478.5cc which thanks to metric
=0.4785L
(2000RPM/2)*0.4785/60 seconds
=~8L/s
Does that look right? |
VW-Gasser Samba Member
Joined: January 30, 2006 Posts: 204 Location: Quincy MA
Posted: Thu Dec 02, 2010 9:23 pm Post subject: |
| stealth67vw wrote: |
Dell'Orto 36mm 205.8cfm |
I am not sure if I read this data right, but it looks like that 48 DRLA are less restrictive than 48IDAs? And does that mean that you can get a little more power out of the DRLA (perhaps the TriJet ones) than out of the IDAs?
Thanks _________________ -- www.vw-gasser.de -- |
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Fri Dec 03, 2010 12:53 am Post subject: |
| RanX0R0X wrote: |
| jamestwo wrote: |
Dell'Orto 40mm DRLA
=~125L/second
=0.4785L
=~8L/s
Do keep in mind
Holley's carb CFM ratings were usually @ 3mm HG for regulear apps and 1.5mm HG for Hp apps. You can roughly convert 25 inches of water depression CFM to the lower carb CFM rating with a conversion you can probably find somewhere maybe.
I don't know what you are trying to figure out, for IR carbs most everybody just goes by venturi size. To get scientific maybe you could figure the flow coefficient of the vent size?? and use that to compare? |
RockCrusher Samba Member
Joined: August 03, 2010 Posts: 4596 Location: Parkesburg, PA
Posted: Fri Dec 03, 2010 1:02 am Post subject: |
| vdubyah73 wrote: |
Thanks, Bill |
You can....kind of.
Those ratings are based on steady stabilized flow where as we use them in a stop and start mode......kind of. Independent runner applications are far different than plenum apps. _________________ [email protected] Please use email for all general inquiries.
I will be happy to speak to anyone who has a serious inquiry (meaning real potential business for RC enterprises) or a parts order. Due to machining noise causing missed calls all calls will be returned promptly. |
catbox Samba Member
Joined: May 16, 2007 Posts: 874 Location: Portland, Oregon
Posted: Fri Dec 03, 2010 9:25 am Post subject: |
This is good information to have.
I just stepped up to a set of Dell 45's for my new motor and was just wondering what these flow for a comparison to the numbers the head guys put out.
Of course they are probablly not a direct comparison but a comparison anyway. Better than nothing.
