dodger Samba Member
Joined: February 03, 2006 Posts: 15 Location: Yuba City, California
Posted: Mon Feb 20, 2006 10:31 am Post subject: Seals and Wheels |
Got my (mine for another 5 months till my son gets his license) 64 Square off the trailer and sitting in the driveway. I'm getting a good puddle of oil out of the rear seal I think. PO mentioned that it was leaking even though he had put a new seal in. Is this a chronic problem with the 3's or should I be pulling the rear and putting another seal in?
Also the car is currently running 195/60/14's on Porsche 5-lugs. Scrapes a little over bumps and tight turns in the back. Any suggestions that don't involve replacing the wheels/tires.
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Mon Feb 20, 2006 10:33 am Post subject: |
Did the PO lower it?
You could raise it a click or two.
RMS _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
thejoe138 Samba Member
Posted: Mon Feb 20, 2006 11:28 am Post subject: |
it doesn't look lowered to me..? going up 2 clicks would be great for off-road
use, it might look a bit odd on the street .
i'm betting the wheels are not the proper offset for a T3 |
dailydrivervw Samba Member
Posted: Mon Feb 20, 2006 4:37 pm Post subject: |
Quote: |
I'm getting a good puddle of oil |
If he just put a seal in, and it leaks that much? Could be that he messed up the new seal. Worst case would be that the engine case is beat to death, and the thrust bearing is loose in the case, or has a leak between case halves. Check all the 13mm headed bolts near there , including the one that is quite close to the larger forward lower main case nut.
It could also be a trans leak from the input seal.
Did they use adapters for the 5 lug wheels? If so, you could get them in more by getting the correct aftermarket rear drums that are drilled for the 5x130 pattern. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Feb 20, 2006 6:09 pm Post subject: |
If it is rear axle seals that are leaking, Are they assembled right, and the axle nuts torqued properly???? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Pelle Samba Member
Joined: February 07, 2004 Posts: 200 Location: Sweden
Posted: Sun Feb 26, 2006 9:21 am Post subject: |
Hereīs a Norwegian Square with the same kind of wheels. Lotīs of space and no tirerubbing. Mounted without adapters. |
sovereignsamba Banned
Posted: Sun Feb 26, 2006 10:04 am Post subject: |
Wouldn'y worn main bearings cause seals to go out? |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1084 Location: Dover, DE
Posted: Sun Feb 26, 2006 12:31 pm Post subject: |
Roll them fenders!!!!!
How bad do they rub? _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
K1mech Samba Member
Joined: November 01, 2003 Posts: 31 Location: Stafford, VA
Posted: Sun Feb 26, 2006 7:35 pm Post subject: Rear main seal |
If you pull the engine to replace the seal again take a good look at the area on the crankshaft where the seal rides, it should be smooth with no damage or grooves/scoring from the seal. Main bearing wear would not normally cause the seal to leak that bad unless there is excessive wear and the crankshaft is moving around within the bearings instead of spinning true. |
