motolou Samba Member
Posted: Thu May 04, 2006 11:39 pm Post subject: squareback wheelbase q's |
hey guys, I was just wondering if anyone knew if squarebacks had the same wheelbase as the notchbacks. sorry for the silly questions but vw are knew to me. thanks in advance. lou |
EverettB Administrator
Joined: April 11, 2000 Posts: 69855 Location: Phoenix Metro
Posted: Fri May 05, 2006 12:23 am Post subject: |
oh no, I had something much more sinister in mind! I have compared various pictures of both bodies. can the front fenders, hood and doors be swapped in these vehicles? maybe? |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri May 05, 2006 3:01 am Post subject: |
motolou wrote: |
yes - they are the same; it is the rear fenders that are different from a notch and square...
but swapping the front fenders, hood and doors would get you... the same looking car... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22458 Location: Kimball, Mi
Posted: Fri May 05, 2006 7:21 am Post subject: |
blankmange wrote: |
motolou wrote: |
but swapping the front fenders, hood and doors would get you... the same looking car... |
Yeah, but you might need conversion door hinges, if you're using late Square / Fastback doors on a Notch. After 65, VW changed the door hinges on the Square and Fastback to the 2 bolt design, while the Notch stayed 3 bolt until the end. Also keep in mind that the later (70 to 73) used different front fenders and hood than the early cars (up to 69). These late parts won't fit un the early car without heavy modification (or the reverse is true early parts won't fit on a late car). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri May 05, 2006 7:39 am Post subject: |
Bobnotch wrote: |
blankmange wrote: |
motolou wrote: |
Yeah, but you might need conversion door hinges, if you're using late Square / Fastback doors on a Notch. After 65, VW changed the door hinges on the Square and Fastback to the 2 bolt design, while the Notch stayed 3 bolt until the end. Also keep in mind that the later (70 to 73) used different front fenders and hood than the early cars (up to 69). These late parts won't fit un the early car without heavy modification (or the reverse is true early parts won't fit on a late car). |
gotcha - I was comparing year to year on cars... _________________ póg mo thóin
Posted: Fri May 05, 2006 7:56 am Post subject: |
But if you go back to his original post, he didn't list a year. And the doors can cause a major headache if you're not aware of the change. He also mentioned he wanted to do something sinister, I wonder what that ment? Cut the roof off? Put 2 front ends on the same car? Built a half back? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri May 05, 2006 1:59 pm Post subject: |
AND, unknown to a lot of people, the T-3 also has the same wheelbase as the T-1 AND the T-2. 2400mm (94.48")
Track is not quite the same.
T-1 = 1305/1310mm
T-2 = 1370mm
T-3 = 1310mm _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri May 05, 2006 6:15 pm Post subject: |
I found a post about choppin vw rat rod style I was thinkin front mounted engine, stacks out the hood, you know the normal stuff. I hope it don't offend any traditionalists, but I do like the lines of type 3s, just with a personal twist |
Godsbug Samba Member
Joined: April 29, 2006 Posts: 996 Location: Renton, WA
Posted: Fri May 05, 2006 9:22 pm Post subject: |
As long as the car isn't worth restoring. It kills me to see perfectly good VW's mangled. I knew a guy who bought a 66 T1 from an old lady who bought it new. This car was in pristine condition with 60k miles on it and he hacked it into a baja and primered over the paint. It was painful. _________________ 2017 Golf Alltrack
2011 Fit
1968 Fastback |
