Solex 32 PCI carb
entomologist2004
entomologist2004 is offline
PostPosted: Sat Aug 05, 2006 5:22 pm    Post subject: Solex 32 PCI carb Reply with quote
I found a manual choke solex 32 PCI - 1 carb....It is a downdraft carb so I do not thnk it is TIII..ANY idea what this is from... Okrasa used the 32 PBIC's The carb still has the ID tag on it and the part number is 126290021 K
IN2VWS
IN2VWS is offline
PostPosted: Sat Aug 05, 2006 7:16 pm    Post subject: Reply with quote
That looks like an industrial engine part number
entomologist2004
PostPosted: Mon Aug 07, 2006 9:42 am    Post subject: Reply with quote
That was my thought, unless I had just discovered an new line of VWs...the rare and ellusive Bug Bus designed by Ghia...?... It fits a 1500 manifold...anyone else ever seen one??? There is NOTHING in the Gallery or the forum (or any hits on the web that I found...) It think I am going to rty and fit it on my 55 vert rat ride in the making's 36er, but I will need a slightly larger flange (30-1 to DP manifold redrilled might work..?) Any ideas out there... Also there is a really deep accelerator pump diaphram (the housing is about 4to5 times as deep as usual and has six screws instead of the ususal 4, looks to have a huge spacer, but I have not opened her up yet, did not want to glass bead it if it was a "rare part" I could always knuck under and buy 30#s of walnut shells...
Walt
Downtown Brown
Downtown Brown is offline
PostPosted: Mon Aug 07, 2006 12:16 pm    Post subject: Reply with quote
The set of Okrasa 32 PB1s I've got have the same "6 screws " set up. The rebuild kit for those in 32 and 40s all had "B" letters . Bet you want the name of the person that has the parts ? Laughing (I don't have the name or number either) I'll see if I can track him down. Lloyd
Downtown Brown
PostPosted: Mon Aug 07, 2006 2:50 pm    Post subject: Reply with quote
OK I tracked down the guy who gave away the the carb in question , and looked at the case that had that carb on it, it was on a F series case. More of the story : It was under the bushes at his older friends house who has been into VWs a long time but is getting older and is throwning things away. Needless to say I gave him my name/number for more information and that I'd like to go visit and talk to him Smile and call me before he gets rid of anything else... OH IF you end up using/selling the carb the "young man" who gave it away could use help to get his Beetle running again. His engine dropped a valve on #3 cylinder,He is looking for used parts to get it going. Walleys engine shop says the head is rebuildable, he is looking for a used piston & cylinder for his "2000" engine. Lloyd
PostPosted: Tue Jan 20, 2009 11:06 pm    Post subject: Reply with quote
I just removed one of these from a 36hp engine. It doesn't fit the 36hp manifold though so the installer widened the mounting holes so it would fit. (Weird) Engine ran fine with it, better after I adjusted it correctly.
Part # on mine is 126129021K.
From reading I think it's originally for a 1500 or 1600 industrial engine?
Pics:
More
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516411
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516410
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516409
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516408
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516407
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516406
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516405
http://www.thesamba.com/vw/forum/album_page.php?pic_id=516404
lloydCALI
lloydCALI is offline
PostPosted: Wed Sep 16, 2009 2:41 pm    Post subject: SOLEX 32 PCI for sale? Reply with quote
My 1959 Lloyd Alexander has an old carb - full of holes, needs to be replaced.
Are any other SOLEX 32-series carbs interchangeable with mine?
fig
fig is offline
PostPosted: Thu Sep 17, 2009 1:07 pm    Post subject: Reply with quote
I have a pair of Solex 32PCIs that I bought with a pile of old parts. They are attached to dual-port manifolds marked "Riechert Essen". I was hoping someone here could tell me what car the carbs originally came from.
I had been told that industrial engine carbs can't be made to run on a car engine???
fig
Kaapse Kombi Kult
"Don't make a fuss, just get on the bus ..."
lloydCALI
PostPosted: Thu Sep 17, 2009 1:49 pm    Post subject: Reply with quote
German cars, most likely.
Wayland
Wayland is offline
PostPosted: Thu Feb 04, 2010 11:13 pm    Post subject: Reply with quote
I ran a Mobile Dimension Sawmill for years. It was powered by a modified VW engine, and came originally with a 32 pci. These mills are still being made, so these carbs can probably be bought new somewhere.
ratlookvw
ratlookvw is offline
PostPosted: Sat Feb 06, 2010 3:19 pm    Post subject: 34pci Reply with quote
I have some 34pci carbs I just had rebuilt by keifernut these were sold in germany, by tuner companies....
If the RV Hut is a rockin, don't come a knockn'
57 Panel, 66 highroof panel, 65 Notch, 59 Vert, 61 Vert, 1969 Fridolin, 'Reggie ' 66 RV, 65 Pipe Truck, 65 RHD T-34, 70 dbl slider panel, 1969 Deep sea green sunroof automatic square, the greypoop-on, and a shit load of wheels!
fig
fig is offline
PostPosted: Mon Feb 08, 2010 9:52 am    Post subject: Re: 34pci Reply with quote
I checked and the carbs I referred to above are also 34PCIs. And I found this thread in the Vintage Speed forum on exactly the same carbs and manifolds as I have:
http://www.thesamba.com/vw/forum/viewtopic.php?t=397158
fig
Kaapse Kombi Kult
LittleMicroCars
LittleMicroCars is offline
PostPosted: Thu May 31, 2012 8:39 pm    Post subject: solex 32 Reply with quote
This Solex was used as a vw stationary engine... that ran at a certain speed ...The old Bmw 700 car uses a similar type carb but had an extra fuel tube from the diaphragm side .. these were 34mm in venturi size they had an adapter to step up to the 40mm intake manifold hole. I run this carb on my steyr puch 750cc engine... It runs well from idle to full throttle.. with no stumble flat spot anywhere. do not attempt to just yank the top off to disassemble it...IF you do you will break off the casting taps to align the top these get corroded around the gasket after many years sitting around.. leave the carb in fuel oil for a few days.. then carefully pry off the top evenly..leo
Importer of Steyr Puch rally cars, military Jeeps, and air cooled parts Vienna, Austria
