christopher.webster@60mdg Samba Member
Posted: Tue Jul 29, 2003 12:49 pm Post subject: Dick Landy Superchargers |
| If anyone out there has experience with the supercharger setup from Dick Landy enterprises, I would appreciate info on your experience with it. I have a 62' standard beetle and will be building a 1915cc and am thinking of using the supercharger. My main questions revolve around cost (I'm having trouble getting info out of DLI) what compression I should use, any special things needed when building the engine, how complete the kit is and if there is any custom Fab needed? The car is my only source of transportation so it has to be reliable. Maybe the standard weber 40's are what I should use. I just don't know |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13587 Location: Tejas!
Posted: Tue Jul 29, 2003 1:53 pm Post subject: Dick Landy Superchargers |
| The DLI charger is nice, I don't think anyone will argue that. But I believe it's in the $2500 range once you include the carberator? at that price you could bolt on AJ Sims turbo kit (just as reliable if not more) to a stock 1600 and get more power and probably better drivability. check the AJ sims turbo kit at www.lowbugget.com or aircooled.net |
k29349@yahoo Samba Member
Joined: May 10, 2003 Posts: 652 Location: Inman, S.C.
Posted: Tue Jul 29, 2003 4:14 pm Post subject: Dick Landy Superchargers |
| I have talked to people at shows with DLIs and they had good things to say,but one was on a buggy and the other was on a show car. I would like to know how reliable it would be on a driver. |
Volksrod Samba Member
Joined: July 11, 2003 Posts: 43 Location: Santa Rosa, Ca.
Posted: Tue Jul 29, 2003 6:53 pm Post subject: Dick Landy Superchargers |
I've been running my DLI blown motor now for about nine months as a daily driver. I'm not sure how many miles that I have on it because I don't have an odometer on my car but it's probably in the 1500 to 2000 mile range. I have had zero problems with it and it is very drivable. The only problem that I have with it as a daily driver is the fact that it only gives me about 12 M.P.G. but who's counting. Check my page at www.walt.info. or see the link.
blower%20motor4s.jpg |
Posted: Tue Jul 29, 2003 7:01 pm Post subject: Dick Landy Superchargers |
| I give up!!!! |
Posted: Wed Jul 30, 2003 3:50 pm Post subject: Dick Landy Superchargers |
| What size motor are you running Volksrod? |
Posted: Thu Jul 31, 2003 9:07 am Post subject: Dick Landy Superchargers |
It's a 2017 with 8:1 compression. I'm running an FK8 cam and 42X 37.5 heads. I've geared the blower to produce 6 Pound of boost at 6000 RPM's. I am able to run on 91 octain pump gas. I am also running MSD 6AL ignition and eventually I will be installing the boost retard system so that I can increase the boost a little without the preignition problem.
When I first put the motor in the car I was spinning the blower a lot faster and was pumping out over 20 pounds of boost and I had to run 110 octain gas to keep it from pinging. As a daily driver that wasn't going to cut it. The combination that I'm running now is working out real nice. |
Posted: Thu Jul 31, 2003 10:20 am Post subject: Dick Landy Superchargers |
Volksrod-
Was the supercharger a bolt on? Any custom Fab required? |
Posted: Thu Jul 31, 2003 12:20 pm Post subject: Dick Landy Superchargers |
| The only fabrication that is required is to drill and tap 1 hole to a 3/8"-16nc in the alt/gen stand. everything else is a bolt on but be aware you will probably have to run a new Morse throttle cable because the stock cable is too difficult to hook up with bell cranks or cable extensions and the Morse cable only requires drilling a hole in the throttle cable and a hole through the firewall and strapping it to the floorpan. |
Posted: Thu Jul 31, 2003 6:55 pm Post subject: Dick Landy Superchargers |
| I meant throttle pedal not cable. Another senior moment! |
vwmworks Samba Member
Posted: Tue Aug 05, 2003 12:06 am Post subject: Dick Landy Superchargers |
| i,m building a 2332cc d.l.i. supercharged engine that will be an every day driver i am expecting horsepower and torque in the low to mid 200s to 250 this one will be run with dual 48mm dells, i heard the single holleys run real well to. the problem with VWs is the intake manifolds can only push so much air thru the small pipes. you want to run the biggest cam like fk 89 and heads you can afford you won,t lose bottom end. it would be nice to custom build a fatter manifold, i will be doing this. maybe you can call D.L.I. they seemed to be very helpful when i talked to them about how to build a engine for their blower,thanks TOM (909)595-5663 any questions feel free to call. |
uselescrapytwit Samba Member
Joined: February 03, 2009 Posts: 24 Location: brizzle
Posted: Fri Feb 22, 2013 4:12 am Post subject: Uk dick landy runner |
I run one with the holly set up one word
Super charger can help with set up spec if needed |
bugnut68 Samba Member
Joined: June 10, 2003 Posts: 4180 Location: Eugene, OR
Posted: Fri Feb 22, 2013 10:29 am Post subject: Re: Dick Landy Superchargers |
| Erik G wrote: |
Take a look at AJ Sims (who I believe has been banned from The Samba, if I recall correctly) and his issues with customer service, first... In the past I purchased Kadron jets from him, but after seeing how a number of people were treated/mistreated, I will likely never seek out any serious high-end parts or service. The feedback thread speaks for itself.
Edit: Just noticed this thread dates back 10 years in the earliest posts... obviously, things have changed a lot over the past decade. |
vwjimbo Samba Member
Joined: January 10, 2005 Posts: 201 Location: akron, ohio
Posted: Thu May 01, 2014 11:39 am Post subject: |
does anyone know how many DLi kits were sold? there seems to be a registry website for everything else on the planet....anyone ever heard of one for the DLi VW power charger owners?? i know there were 2 different "kits" sold the 58ci setup (that i have) and the larger 75ci one.....when you set both the 58ci and the 75ci blowers side by side it is super easy to tell them apart!! the 75ci one is about 1" deeper than the smaller 58ci one.... and it's the same with the manifolds!! _________________ never enough hours in the day!!!! |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2377 Location: Mount Airy, Maryland
Posted: Thu May 01, 2014 1:41 pm Post subject: |
| vwjimbo wrote: |
| does anyone know how many DLi kits were sold? there seems to be a registry website for everything else on the planet....anyone ever heard of one for the DLi VW power charger owners?? i know there were 2 different "kits" sold the 58ci setup (that i have) and the larger 75ci one.....when you set both the 58ci and the 75ci blowers side by side it is super easy to tell them apart!! the 75ci one is about 1" deeper than the smaller 58ci one.... and it's the same with the manifolds!! |
After going to the Bug Out in VA for 20 straight year then in the last 10 years I have gone here and there; I have only seen one running car with a DLI. It was cool but looked like it was putting a lot of stress on the crank bearing and pulley. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Posted: Thu May 01, 2014 3:25 pm Post subject: |
i agree you don't see them very often but that's a big part of the cool factor!!! hopefully mine will be sticking thru the rear decklid of my 57 lowlight soon!!!!! _________________ never enough hours in the day!!!! |
Split 1 Samba Member
Joined: May 03, 2005 Posts: 764 Location: Adelaide. South australia
Posted: Fri May 02, 2014 2:22 am Post subject: |
| And if anyone has one for sale please send me a PM |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3518 Location: Charleston, SC
Posted: Fri May 02, 2014 2:58 am Post subject: |
| Split 1 wrote: |
There are two DLI supercharger set-ups for sale in the classified ads right now.  _________________
| 66brm wrote: |
| Bodacious wrote: |
| Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
