101 HP 1500 SP with STOCK internals!!!
Bugman Jeff
Bugman Jeff is offline
PostPosted: Sun Aug 26, 2007 2:37 pm    Post subject: 101 HP 1500 SP with STOCK internals!!! Reply with quote
With a SINGLE carb no less. Thats right, 101 HP without splitting the case. Whats more, it was done in 1969! The November 1969 Hot Rod Magazine features an article on it. Here's a rundown of the specs:
Stock unopened 1500 SP
4-1 header
Single center carb manifold
Zenith 32 NDIX carb
Power pully
'59-'61 Bus distributer
Ported heads w/ 1.4 rockers
Furthermore, it made 79.1 HP with STOCK SP heads. So much for single ports are junk and single carbs don't work... Who were the perpetrators of this build for Hot Rod for Hot Rod? None other than Dean and Ken Lowrey, and Gene Berg. Vintage speed indeed.
Restorer of Porsche Speedster 80486 Smile
sbnova
sbnova is offline
PostPosted: Sun Aug 26, 2007 2:57 pm    Post subject: Reply with quote
Interesting.
Is there any way you can type or scan it so that its more legible?
I'd like some comments from todays engine builders to see if Hot Rod fudged the numbers or if this type of build could really produce that kind of power.
Link to my build thread- Updated 6-6-07 http://www.thesamba.com/vw/forum/viewtopic.php?t=210613
check my sites to see my work;
http://www.cardomain.com/ride/1564293 (bug)
http://www.cardomain.com/ride/448794 (Vette,Nova,Typhoon)
Bugman Jeff
PostPosted: Sun Aug 26, 2007 3:38 pm    Post subject: Reply with quote
If you right click and save as, you can zoom in with Windows Picture Viewer.
buggpower
buggpower is offline
PostPosted: Sun Aug 26, 2007 3:56 pm    Post subject: Reply with quote
can these same mods be done to the 1600cc dp, or is this just for the 1500cc sp?sounds cool.
1972 Standard Beetle
Bite My Shiny Metal A$$ (quoted by Bender)
click the cool link haha!
http://img.photobucket.com/albums/v600/bigguy/avatars/150_tits1.gif
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Sun Aug 26, 2007 5:32 pm    Post subject: Reply with quote
The ideas (bigger carb, extractor exhaust, 1.4 rockers, porting the heads) aren't anything new, and can be done with any engine, but that's a cool article nonetheless. Cool
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
millerje78
Samba Amishman
millerje78 is offline
PostPosted: Sun Aug 26, 2007 6:01 pm    Post subject: Reply with quote
must have been a seriously talented head porter on staff to make numbers like that! that is very cool.
always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry
vwdmc16
vwdmc16 is offline
PostPosted: Sun Aug 26, 2007 6:07 pm    Post subject: Reply with quote
i see peak power is at 5.5K, just how many times can you run up there and back before the crank says no? i didnt think the stock cam would build any more power above 4400.
this would a great "Myth" to bust. not that im saying they were lying but could it be done today, i wonder what the compression was, and if todays pump gas would cope with it.
"Fiberglass is for boats and race cars-Steel is real-fix it right the first time"-Wolff
'72 Ghia: http://i111.photobucket.com/albums/n146/vwdmc17/100_1964.jpg
'72 Honda Z600
'81 Delorean
www.EVILGENIUSRACING.com
clearsurf2001
Samba Vaccinator
clearsurf2001 is offline
PostPosted: Sun Aug 26, 2007 6:17 pm    Post subject: Reply with quote
9.2-1, (Glenn will love this) 010 dizzy @ 33deg total advance, and the best part ... $337 total. Amazing!!
Get ready for the injection Smile
Make sure it is coherent. Rodney
mharney wrote:
I think Glenn has an EMPI crank in his engine.
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Aug 26, 2007 6:22 pm    Post subject: Reply with quote
That was of course measured as "SAE gross horsepower" was back then using the SAE standard of J245 and J1995.
Doesn't really mean much.
Towel Rail
PostPosted: Sun Aug 26, 2007 7:46 pm    Post subject: Reply with quote
I was about to post that, but I feel like I'm beating a dead horse sometimes! Wink
That, and the horsepower at the wheels will of course be lower...
vwdmc16
vwdmc16 is offline
PostPosted: Sun Aug 26, 2007 11:53 pm    Post subject: Reply with quote
so what would the hp be in todays standards?
'72 Honda Z600
'81 Delorean
Towel Rail
PostPosted: Mon Aug 27, 2007 12:29 am    Post subject: Reply with quote
It's hard to say. There isn't some kind of ratio between the two, but it would be less. FWIW, the 1600 DP was 60 HP SAE gross, 48 HP SAE net.
krusher
krusher is offline
PostPosted: Mon Aug 27, 2007 12:36 am    Post subject: Reply with quote
hmmm, just put a single zenith/intake, header and 1.4's on a 1500 and you get just short of 80hp, i dont think so, good bit of number fudging going on there.
Confused
Bruce
Bruce is offline
PostPosted: Mon Aug 27, 2007 2:20 am    Post subject: Reply with quote
9.2:1. You are right, today's pump gas will not support that CR with a stock cam. No matter what rockers it has.
67jason
67jason is offline
PostPosted: Mon Aug 27, 2007 2:44 am    Post subject: Reply with quote
Confused
yeah i agree the numbers are skewed.
i built a mild 1600, fully balanced, ported and polished heads, dual kads, stock rockers, header, mild cam etc...and it only came out to 75HP 85ftlbs at the flywheel.
and regarding the engine in the article, it was revved to 5500 to achieve max HP, if thats the case it will not last very long. a stock non CW crank will not stand up very well to anything much higher then about 4800 or so.
the vw guys referenced in the article were pioneers in the early VW scene and applied many innovative ideas to increase the performance of the humble aircooled engine, but i think the editors of the mag possibly took some very liberal licenses when it came to the numbers.
even today, one can put all the traditional bolt on goodies on an other wise stock 1600 DP engine, things like 1.25, dual kads or ICTs or whatever, header etc and might get 60-70 HP or so out of thier engines. of course i do understand the differences in measuring HP numbers from back then vs today, but even by todays standards that claim of 101 hp would be around 75-80, not impossible on a 1600cc engine, just not very likely on one that has had nothing done to the internals of the crank case.
67 bug x3
67 ghia
64 bug
Jake Raby
Jake Raby is offline
PostPosted: Mon Aug 27, 2007 6:12 am    Post subject: Reply with quote
How about 181HP from a 1500??
I did it last week!
It's all in the combo of intake, exhaust and etc-
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
67jason
67jason is offline
PostPosted: Mon Aug 27, 2007 6:20 am    Post subject: Reply with quote
I did it last week!
impressive. was that with bone stock from the factory case internals? stock cam, non CW crank?
in your experience, how feesible is it to get 80+ HP out of a 1500 using the stock cam and non CW crank? and would it be a good engine for daily driving or would the heads melt due to insanly high CR?
67 bug x3
67 ghia
64 bug
Jake Raby
PostPosted: Mon Aug 27, 2007 6:56 am    Post subject: Reply with quote
No, it was a full race engine- 1493cc.
Yes, I feel that a 1500 with just a cam change could make 80 HP... 9.3:1 should get it there and some head work would help..
BTW- The stopck ratings are a joke- they are Din HP as well, not SAE
Jake Raby
vwairheads
vwairheads is offline
PostPosted: Mon Aug 27, 2007 7:23 am    Post subject: Reply with quote
I did it last week!
not surprising if you have turbo or super charger.
RIS
RIS is offline
PostPosted: Mon Aug 27, 2007 7:26 am    Post subject: Reply with quote
Hard to top this crew Jesse!
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
