65 Rear Brake Drums
Gunfighter
Gunfighter is offline
PostPosted: Fri Feb 08, 2008 9:32 am    Post subject: 65 Rear Brake Drums Reply with quote
Doing a complete restoration on my 65 Beetle. When taking the old rear drums off I noticed they were of two different designs. One had ribs one was a smooth cone. After research I discovered the smooth cone was the correct ones for my year.
Since they are used I don't know at which point the drum is to thin to be reused.
Does anyone know the factory specs on wall thickness?????
Tom
1965 Beetle
L572
L572 is offline
PostPosted: Fri Feb 08, 2008 9:51 am    Post subject: Reply with quote
Gunfighter: The maximum diameter that the drum can be turned to is usually stamped/cast into the inside of the drum. You may need to scrub the inside well with a scotchbrite pad to remove the brake dust and rust to see it. Off the top if my head I can't remember the exact spec. for the 65 drum....maybe someone else can look it up. Look at page 125 from the 1969 Without Guesswork manual with the max diameters and minimum wall thickness as well as run out. I'm not sure how much difference (if any) there might be with the '65 drum....these numbers seem familiar for my '65.
http://oacdp.freeweb7.com/wog69.html
L572
drscope
drscope is offline
Sorry I don't have the specs with me. But heres a few things to think about.
You have 2 drums that don't match. If you want to do a nice job, you are going to need to replace one of them. I'm not sure you can get new smooth ones anymore.
If you have them turned, you are removing material and therefore the drums ability to contain and disipate heat is diminished a bit. Usually this is not a factor on a street car.
but you need to get some pricing before you get them turned. Look around and price new drums so you know what you are dealing with. And price getting your old ones turned.
It is an on going joke at auto parts stores that do service work where they charge a customer $20 to turn a rotor that could be purchased new at the parts counter for $13. This happens all the time. So before you pay someone $40 to turn your drums, you may want to consider replacing it for $60.
If you look at your ribbed drum, you may find the tolorance measurment cast into the drum. Some have it, some don't.
djkeev
djkeev is offline
PostPosted: Fri Feb 08, 2008 11:19 am    Post subject: Reply with quote
Hi,
There was quite a post about drums awhile back, I did a search and found it, you should read it before you go drum shopping.
http://www.thesamba.com/vw/forum/viewtopic.php?t=263223&highlight=axle+drum+splines
wear limit for rear drums are 231.5 mm (9.114")
Wall thickness should be a minimum of 4.0 mm (.16")
Good Luck
Dave
Ghia
Vanagon
Beetle
Cusser
Cusser is offline
PostPosted: Fri Feb 08, 2008 12:31 pm    Post subject: Reply with quote
I think a matching set (same alloy) would be best, get 2 drums.
Gunfighter
PostPosted: Fri Feb 08, 2008 12:35 pm    Post subject: Reply with quote
Thanks guys for the info. Both these drums although mismatched look to be in pretty good repair or I wouldn't even consider using either of them. I have a friend with several used drums that may work depending on the wear which is why I was wondering about the specs. As far as turning them goes I can get that done for free so that's not an issue for me.
Thanks again
Tom
1965 Beetle
Gunfighter
PostPosted: Fri Feb 08, 2008 1:14 pm    Post subject: Reply with quote
Both the drums that came off the car measure 9.073 which is approaching max diameter (9.114) so I will spring for new drums.
Thanks again for the help.
Tom
1965 Beetle
L572
L572 is offline
PostPosted: Fri Feb 08, 2008 3:29 pm    Post subject: Reply with quote
Gunfighter wrote:
... As far as turning them goes I can get that done for free so that's not an issue for me.
Thanks again
I found that when I took my rear drums into the shop they couldn't fit them on the lathe because of the relatively small diameter of the splined axle bore. You might want to check with the shop before you assume they can do it.
L572
