Transmission tunnel insulation replacement - PICS
MrPolak
MrPolak is offline
PostPosted: Fri Jul 25, 2008 5:53 pm    Post subject: Transmission tunnel insulation replacement - PICS Reply with quote
If your Westfalia is over 20 years of age, I recommend you have a look at the insulation above the transmission in the "transmission tunnel", for lack of better words.
You may find something like this:
That is a sagging mess of old, cracked backing and disintegrating foam which has lost much of its usefulness. When you pull it out it will look like this:
Next time you do a clutch or a job that requires for the trans or the engine to come out, you may want to consider to replace that mess with something a little more effective. I chose aluminized Refletix 25'' x 16' "bubble" insulation that comes in rolls.
After I pulled out the old insulation in pieces I put the puzzle back together to get a good idea of the size I needed to fit:
I used aluminium tape to seal the folds and to give it a finished look. I also cleaned the transmission tunnel area. It was remarkably clean with only some glue residue and minor dust.
When I finished it looked like this:
I also added a few patches of sound insulating material behind Reflectix. This should do a better job of keeping the heat from the transmission away from the passenger compartment, and do a decent job of suppressing the noise.
tencentlife
tencentlife is offline
PostPosted: Fri Jul 25, 2008 9:46 pm    Post subject: Reply with quote
Looks nice!
What'd you use to stick it up?
Experience is death to doctrine.
1621
1621 is offline
PostPosted: Fri Jul 25, 2008 10:13 pm    Post subject: Reply with quote
Very nice work! I did something similar, but not quite as thorough as you. I had an additional sheet of Motor Mat Pro from a different project that I used. http://www.secondskinaudio.com/thermal-insulation/motor-mat-pro.php I simply took some measurements, trimmed to fit, and put it over the existing insulation. It tucks nicely under the wires holding the original stuff in place. It does make a bit of difference (not scientifically tested), and keeps things clean. Also, you don't need to remove the transaxle to put it in place.
'85 Westy
MrPolak
MrPolak is offline
PostPosted: Sat Jul 26, 2008 5:21 am    Post subject: Reply with quote
Thanks!
The material is held up in place with original wires that clip into place - if you look at the "old" pictures you can see them.
I think the Second Skin material has better noise absorbing properties. If It were available to me I would have used it along with Reflectix.
FYI, I folded the Reflectix material in half and taped it for a thicker application.
the caveman
the caveman is offline
PostPosted: Sat Jul 26, 2008 10:40 am    Post subject: Reply with quote
Everyone should get rid of that foam. It holds water and rots metal behind it.
mediaguy99
mediaguy99 is offline
PostPosted: Fri Dec 06, 2013 2:49 pm    Post subject: "Everyone should get rid of that foam" Reply with quote
Which product are you talking about?
randywebb
randywebb is offline
PostPosted: Fri Dec 06, 2013 4:28 pm    Post subject: Reply with quote
your pics are gone - can you repost them?
1986 2.1L Westy 2wd Auto Trans.
vanagonjr
vanagonjr is offline
PostPosted: Fri May 08, 2015 5:32 pm    Post subject: Reply with quote
Hoping someone can provide some direction, or alternatives (especially since the pictures are gone). My engine and tranny are (still) out and I just noticed how bad my insulation looks.
I'd like to know what people have successfully used as options and how it was held in.
Thanks!
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Fri May 08, 2015 8:50 pm    Post subject: Reply with quote
Thanks!
I have a set of the original wires that held the insulation in place. They are in great condition no rust. Pm me if you are interested in them
Gnarlodious Premium Member
Gnarlodious is offline
PostPosted: Sat May 09, 2015 5:50 am    Post subject: Reply with quote
Something like this?
http://www.thesamba.com/vw/forum/viewtopic.php?t=606406
GypsyDriver
GypsyDriver is offline
PostPosted: Sat May 09, 2015 6:35 am    Post subject: Reply with quote
Good thread. I'm getting ready to pull my tranny and will have to address this issue. I was looking at this material used in race cars: http://m.summitracing.com/parts/the-14100?seid=sre...Ais18P8HAQ
Merian
Merian is offline
PostPosted: Sat May 09, 2015 11:30 am    Post subject: Reply with quote
there is a place that specializes in custom fab of heat and sound insulation panels - forget the name but they mostly do stuff for the Detroit hotrod market
worth a search - somebody could even ask for bulk pricing and do a resale
what does GoWesty do when they refurb a Van?
madmanvan
madmanvan is offline
PostPosted: Sun Jan 03, 2016 4:52 pm    Post subject: Re: Transmission tunnel insulation replacement - PICS Reply with quote
What about not putting anything back? Is that nuts?
I'm doing the rattle trap INSIDE the van for noise reduction.
Madmanvan
1967 Bus turned Westy
1985 Vanagon Weekender (SOLD)
Current Build: '67 Kombi goes Westy
http://www.thesamba.com/vw/forum/viewtopic.php?p=8343416#8343416
pbrown
pbrown is offline
PostPosted: Sun Jan 03, 2016 5:10 pm    Post subject: Re: Transmission tunnel insulation replacement - PICS Reply with quote
How about this?
http://www.gowesty.com/product-details.php?v=&id=24371&type=
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
djkeev
djkeev is offline
PostPosted: Sun Jan 03, 2016 5:25 pm    Post subject: Re: Transmission tunnel insulation replacement - PICS Reply with quote
I pulled my insulation out of that area on my 86.
It was a sponge holding moisture against the body.
The rust was only surface so I cleaned it up and painted it.
I did NOT put any back. Insulate inside the Van if you desire to do so.
Dave
Ghia
Vanagon
Beetle
Merian
Merian is offline
PostPosted: Sun Jan 03, 2016 5:50 pm    Post subject: Re: Transmission tunnel insulation replacement - PICS Reply with quote
not at all - it's in the back and there will be plenty of wind noise to drown it out Wink
the foil material above is mainly for heat
madmanvan
PostPosted: Mon Jan 04, 2016 6:57 am    Post subject: Re: Transmission tunnel insulation replacement - PICS Reply with quote
I'm going to call my style "zen": I'd like to delete anything that isn't 100% necessary. I can live with a little extra noise at the benefit of not having anything hold moisture against metal.
Same with the rear heater delete: the idea of coolant running into a relatively hidden spot in the van is nuts to me.
The front heater I guess I gotta have for defrost, but also doesn't seem as bad of a design - and I'll know sooner if it is leaking. The sweet smell of hot coolant.
The AC that a PO had begun to delete, I've finished and now my radiator area looks nice and tidy.
Madmanvan
