Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22480 Location: Kimball, Mi
Posted: Sun Jun 18, 2023 11:06 am Post subject: Re: What did you do for your Type 3 today? |
tylerbright wrote: |
After a year of restoration my 69 made its first test drive and car show the same day.
That looks good. Very nice job on it. Two milestones on the same day is great. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Sun Jun 18, 2023 12:05 pm Post subject: Re: What did you do for your Type 3 today? |
Sprayed the replacement package tray for my 68 Squareback with some weld through primer today.
_________________ If you`re going to do something, do it right. |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4206 Location: Pasadena CA/DTLA soon China
Posted: Sun Jun 18, 2023 1:06 pm Post subject: Re: What did you do for your Type 3 today? |
Finished the brakes, removed a broken lug nut, reinstalled trim rings and hubcaps after a good cleaning and she is ready to go. I would really like to rebuild the front end.
_________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
tylerbright Samba Member
Joined: November 01, 2010 Posts: 19 Location: Sand Springs, OK
Posted: Sun Jun 18, 2023 4:47 pm Post subject: Re: What did you do for your Type 3 today? |
andybla wrote: |
Nice ride height, how many clicks front rear? |
I actually set it to the stock height by degrees but I think it sits slightly lower than stock _________________ Volkswagen & Vinyl
______________________
1969 Squareback |
Posted: Mon Jun 19, 2023 12:53 pm Post subject: Re: What did you do for your Type 3 today? |
Probably just torsion bar sag, or just settled in. I wouldn't worry about unless you start hitting ground. I think it looks good like it is. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22484 Location: Escondido CA
Posted: Mon Jun 19, 2023 1:41 pm Post subject: Re: What did you do for your Type 3 today? |
Pulled it out of Ramona and brought it to the Type 3 Factory for vert work.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Mon Jun 19, 2023 2:45 pm Post subject: Re: What did you do for your Type 3 today? |
Awesome! When does work start? _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Mon Jun 19, 2023 4:07 pm Post subject: Re: What did you do for your Type 3 today? |
ALLWAGONS wrote: |
Awesome! When does work start? |
Yesterday.
Dash needs to be a 64 and the rear parcel tray is in the way of the convertible top. Out they come. The dash from the 64 nose donor will be used.
t3kg wrote: |
1964 1500 S
ibjack Samba Member
Joined: February 06, 2002 Posts: 2107 Location: Imperial Beach CA
Posted: Tue Jun 20, 2023 8:51 pm Post subject: Re: What did you do for your Type 3 today? |
64 dash now installed.
_________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
Buscowboy Samba Member
Joined: October 29, 2004 Posts: 415 Location: South Coast, England
akokarski Samba Member
Posted: Sat Jun 24, 2023 6:58 pm Post subject: Re: What did you do for your Type 3 today? |
last weekend started on clean up of floorpans, today was able to finish welding all the little holes from A/C and other random things, cleaned up a bunch of rust and got most of it in primer. I figured out how to get the seatbelts off the floor pan so no more extra holes!
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3722 Location: San Jose, CA
Posted: Mon Jun 26, 2023 9:00 am Post subject: Re: What did you do for your Type 3 today? |
Not today, but yesterday I took it out for my first real spin in it.
_________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
andybla Samba Member
Posted: Mon Jun 26, 2023 2:39 pm Post subject: Re: What did you do for your Type 3 today? |
Congrats |
Posted: Tue Jun 27, 2023 9:11 am Post subject: Re: What did you do for your Type 3 today? |
akokarski wrote: |
But you are keeping the lap belts? Right? _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Tue Jun 27, 2023 9:48 pm Post subject: Re: What did you do for your Type 3 today? |
ALLWAGONS wrote: |
akokarski wrote: |
But you are keeping the lap belts? Right? |
I am not sure what you mean, this originally came with lap and sholder restrain belts which got swapped for retractable belt. The common thing is to mount the mechanism with a bolt to the floor pan rather than original mounting hole in the rocker.
Here I have retrable mechanism up, off the floor.
Posted: Tue Jun 27, 2023 10:19 pm Post subject: Re: What did you do for your Type 3 today? |
I don’t know what I am talking about. I only own early cars and don’t know late setups. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Posted: Mon Jul 17, 2023 8:42 pm Post subject: Re: What did you do for your Type 3 today? |
Finished last section of the floor plans
MVB Samba Member
Joined: June 21, 2023 Posts: 58 Location: Sydney, Australia
Posted: Thu Jul 27, 2023 8:35 pm Post subject: Re: What did you do for your Type 3 today? |
Put a replica Talbot Berlin fender mirror on the passenger side & took it for a spin to see if turning the floor mat 90 degrees resolved or ameliorated the fast idle issues. Which it did by decreasing the problem by about 65 to 70 percent. |
Johan_f72 Samba Member
Posted: Wed Oct 04, 2023 11:55 pm Post subject: Re: What did you do for your Type 3 today? |
I got my girl a little gift |
