usrname Samba Member
Joined: September 12, 2008 Posts: 165 Location: Arizona but not Phoenix
Posted: Thu Nov 18, 2010 10:51 am Post subject: Tire Pressure Question |
| What psi should I be running in the 165/80/R15's on my otherwise stock (mostly) '62 bug? The sidewall says 38 max and the 34 psi I'm running seems pretty stiff. The 16F/20R manual specs for the original stock tires can't be right for these newer tires. Anyone got my size tires? What psi are you running? |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Thu Nov 18, 2010 10:58 am Post subject: |
opening a can of worms here I run 18 front 28 rear on my 165 80 15 on my 60 bug. No one can convince me any different after 200K + |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26634 Location: Douglas, WY
Posted: Thu Nov 18, 2010 10:59 am Post subject: |
It'll ride really rough if you pump them up close to those max numbers you mentioned. Try 18/27:
Max Welton Samba Member
Joined: May 19, 2003 Posts: 11142 Location: Black Forest, CO
joemac Samba Member
Joined: December 17, 2004 Posts: 603 Location: elverson, pa.
Posted: Thu Nov 18, 2010 3:38 pm Post subject: |
| You're better off running higher pressures than low. The only down side of higher pressures is the chance that the tire will wear more in the middle of the tread than the outside, but given that you get better fuel mileage, handling and tread life, I think the trade-off is worth it. |
Posted: Thu Nov 18, 2010 8:25 pm Post subject: |
| On my 62, when I've over-inflated the tires, and not even close to the maximum, I certainly do not get longer tread life, I get over-inflation wear. |
Posted: Thu Nov 18, 2010 9:23 pm Post subject: |
| Gentlemen, I thank you for your replies. I believe I will let some air out. Out of the tires, I mean! |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17685 Location: Left coast, Canada
Posted: Fri Nov 19, 2010 12:19 am Post subject: |
| joemac wrote: |
| You're better off running higher pressures than low. |
You are better off running the correct tire pressures prescribed by VW.
| joemac wrote: |
The biggest downside is you will have less traction, reducing your braking, increasing the possibility of lockup.
The trade-off you are putting up with is foolish. _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Sun Sep 11, 2011 4:38 am Post subject: |
| glutamodo wrote: |
Does anyone know what the third line from the top means? "Quality 32 psi?
Just curious!
Thanks |
carcass Samba Member
Joined: June 25, 2011 Posts: 302 Location: Santa Maria,Ca.
Posted: Sun Sep 11, 2011 5:55 am Post subject: |
It may mean whichever tires you use should be rated for at least 32psi max inflation
(this is a guess,though,because I really don't know) |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Sun Sep 11, 2011 6:43 am Post subject: |
| joemac wrote: |
driving beetles from 8-65 till 8-2005 = i used 18-20 front and 27-28 rear. you must know something about driving them i do not. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sun Sep 11, 2011 10:35 am Post subject: |
Here comes the worms!
You can't take the tire sticker from a 45 year old car and expect those pressures to apply to todays tires.
Just as the Bias plys and Radials on the sticker have different pressures, so do todays modern tires!
We have run flats and high pressure tires that were only a dream 45 years ago.
So when putting modern tires on an antique car, you really need to pay more attention to the tire manufacturer's recomendations then to the car manufacturer's recomendations. _________________ Mother Nature is a Mean Evil Bitch! |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36356 Location: Conejo Valley, CA
Posted: Sun Sep 11, 2011 11:11 am Post subject: |
| drscope wrote: |
| So when putting modern tires on an antique car, you really need to pay more attention to the tire manufacturer's recomendations then to the car manufacturer's recomendations. |
But nobody makes cars as light as a VW that uses tires that large (tall). Tire manufacturers haven't considered their products on old VWs for decades. I woudl never drive an old VW with more than 30# in the front tires, no matter what the tire manufacturer says. |
Posted: Sun Sep 11, 2011 12:42 pm Post subject: |
| All I know is that when I've run even mildly overinflated compared to VW's specs, I get overinflation wear. |
Posted: Sun Sep 11, 2011 12:47 pm Post subject: |
| drscope wrote: |
165 X 15 tires are close to 155 X 15 tires that are correct size for beetle. watch what pressure you run on a 1958-1967 swing axle beetle. maybe t-roy can give some input as he auto crosses beetles. i stand by my statement from driving them for a few years and having tried differant sizes and wheels. with front sway bars and original EMPI camber compensaters and without. to make a statement like "here comes the worms" without suggesting real world experience of yours is kinda lame.  _________________ Admin note: Bill Passed away - July, 2017
www.sv2s.com
SBS #100
Bruce Samba Member
Posted: Sun Sep 11, 2011 3:49 pm Post subject: |
| drscope wrote: |
We've already been through this. Nothing has changed.
It was only 8 years ago that VW was still manufacturing the Beetle in Mexico, installing 155/80/15 tires. Recommended pressures are 18.5/27 psi. Just the same as in the 60s.
You will never find any tire manufacturer making specific tire pressure recommendations for any car because they have no idea how the tire is loaded. _________________
wizcleland Samba Member
Posted: Sun Sep 11, 2011 5:49 pm Post subject: tire pressure..HUGE difference |
I totally agree with the lowering the front pressures! Had Pirelli p7's put all around and never thought to check what pressures they were at. Had just got the car so decided that its supposed to be 'rough' WRONG. WOW, what a difference. tHey were at 30 all around. Settled on 20 and 28 front and rear, may go lower on the front but a LOT of potholes here and think the extra pressure cushions the rims a bit more...
running Pirelli P7's 195/50R15s on all four corners.
starplot Samba Member
Joined: October 06, 2011 Posts: 12 Location: Tomball, TX
Posted: Sat Oct 29, 2011 10:54 am Post subject: Great info, but what's the final word? |
| I just bought a '62 and the tires on it say maximum 44 psi. I was just curious what the recommended pressure was supposed to be since there is no sticker in the glove box anymore. Do we have a consensus here? |
Posted: Sat Oct 29, 2011 11:06 am Post subject: |
No, no consensus never will be. Do a search and come up with your own. |
