Wheel hop when I change gear
SgtSamy
SgtSamy is offline
PostPosted: Thu Dec 23, 2010 8:03 pm    Post subject: Wheel hop when I change gear Reply with quote
Hi guys, sorry if Im repeating myself, I dont know how to delete the other thread sorry about that. When Im in high speed at the 4th gear, the car is rolling good. Its fluid. But I notice when Im starting at the first or when I change from the first to the second, its just bump, or even when Im changing the second to the third (but its less) Just like when you put a gear and you dont put press the gas enough. But I mean even If I press the gas, its still bumping. It does that when I decrease gear too. What can it be, obviously its releated to the transmission or the clutch. What you guys think?
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Dec 23, 2010 8:07 pm    Post subject: Reply with quote
If it's more of a "wheel hop" than a "bump" it could be the bowden tube for the clutch cable.
Picture below is a bowden tube on an older bug. Safari setup is similar. Note the number of washers on the rear end of the tube. They are placed there to give the tube the proper bend.
A "bump" when accelerating or decelerating could be a forward transmission mount.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
SgtSamy
SgtSamy is offline
PostPosted: Thu Dec 23, 2010 8:17 pm    Post subject: Reply with quote
Picture below is a bowden tube on a bug. Note the number of washers on the rear end of the tube. They are placed there to give the tube the proper bend.
Hi Semper, what is the job of this tube? Ad why its need to be properly bend? Yes its kind of a wheel hop. Heheh.
Semper_Dad
PostPosted: Thu Dec 23, 2010 8:19 pm    Post subject: Reply with quote
This link explains it well.
http://www.vw-resource.com/bowden_tube.html
SgtSamy
SgtSamy is offline
PostPosted: Thu Dec 23, 2010 8:24 pm    Post subject: Reply with quote
THX! Yes it sound like it actually.
sixty9fasty
sixty9fasty is offline
PostPosted: Thu Dec 23, 2010 10:08 pm    Post subject: Reply with quote
Hmmm. might wanna also check your tranny mount. Especially the nose mount...
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Thu Dec 23, 2010 11:39 pm    Post subject: Reply with quote
If you have a gear reduction box transaxle in your Type 181 which came in them in Mexico.
The axles turn in reverse direction out to the reduction boxes.
This cause the rear to rise when stepping on the gas instead of squating like a standard bug type transaxle.
1967 and earlier VW Buses do the same thing because of the reduction boxes.
It is referred to as hopping when the rear end rises. Noise could be spring plates hitting lower stops.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
Pierre G
Pierre G is offline
PostPosted: Fri Dec 24, 2010 12:34 am    Post subject: Reply with quote
X2. Samy, I think you might have nothing wrong. Just the typical (and normal) hopping described by turtlebuggy. I had 3 181s in the past with swingaxle and RGBs and they were all doing this. Every single one does. The 1973-on with IRS and no RGBs don't do that.
Now if there's a "move" you can feel in the shifter, when releasing the gas pedal (in full accelaration in 3rd for example), this could be the tranny mount like sixty9fasty said. They break frequently on 181s with RGBs, because of that specific hopping. You absolutely need to check that. That's a simple visual inspection under the car. Crawl under there and check the nose trans mounts (between nose of trans and chassis). See if there's some cracks in the rubber, or if the rubber is separated from the metal part of the mount. Put a huge screwdriver or a flat bar between chassis and mount and make it move (gently) to see any failure.
That's the part we're talking about :
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D211%2D301%2D265%2D1
Pierre
1976 181/Thing, 1967 fastback, 1973 squareback, 1964 microbus, 1967 Double Cab, 1969 westfalia (currently under resto), 1972 LM1C dune buggy, 1974 jean's bug, 1974 1303 (super beetle, currently under reassembly after new paint).
SgtSamy
SgtSamy is offline
PostPosted: Fri Dec 24, 2010 6:15 am    Post subject: Reply with quote
Thx Pierre Semper and sixty9fasty! Im gonna check that today. Merry Christmas btw, Best wishes!
Pierre G
Pierre G is offline
PostPosted: Sat Dec 25, 2010 3:04 pm    Post subject: Reply with quote
You forgot jsturtlebuggy. Wink You're welcome, de nada, de rien, bitteschön !
I'm always glad to help, and I hope you can finally fully enjoy this Safari soon.
Joyeux Noël.
