Hubster43 Samba Member
Joined: June 03, 2013 Posts: 43 Location: Northern CA
Posted: Tue Jan 30, 2024 8:17 pm Post subject: Re: The Stupid Question Thread |
I hooked up the timing gun and then reached in and increased the rpm’s quite high. According to what I had read, I went till the line didn’t keep moving clockwise and made sure it was at the specified number, which I can’t remember, but I think 27.5. It was your (busdaddy) sage advice for setting it. Ignoring the idle timing mark. I hope that makes sense. |
Posted: Tue Jan 30, 2024 9:19 pm Post subject: Re: The Stupid Question Thread |
Hubster43 wrote: |
Did you have the hoses disconnected from the vacuum can? That is a necessary step. |
Posted: Wed Jan 31, 2024 9:20 am Post subject: Re: The Stupid Question Thread |
I am 98% certain I did and had followed the steps properly. I think I should go ahead and recheck it and be 100%. May take me a couple of days to get out there. Thanks. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Thu Feb 08, 2024 5:17 am Post subject: Re: The Stupid Question Thread |
This isn't a stupid question, but couldn't see where else to post these milestones...
Both BusDaddy and Wildthings have contributed
more than 50,000 posts to The Samba!
Wildthings and BusDaddy have been incredibly helpful during my seven years of van/bus ownership.
Thanks to both of you! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Thu Feb 08, 2024 7:23 am Post subject: Re: The Stupid Question Thread |
Gawddang!! Congrats, guys! And thanks for all your knowledge! _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
pgtips Samba Member
Posted: Fri Feb 16, 2024 4:06 am Post subject: Re: The Stupid Question Thread |
They certainly helped me get my bus on the road, been enjoying it ever since so 110% thank you.
I do also have a stupid Q.
Air filter housing. Sizing. Within reason are they interchangeable, so could you use a 1.3 air filter housing and filter on a 2.0 ltr engine.
What about 1.6 etc. I see 1.0 ltr housings Which are tiny so I assume there is a limit but where would you get to a acceptable zone of size match. The only thing that restricts air flow is the filter inside but I imagine too small would be noisier as it's sucking so much air.
I'm looking at retrofit air filters for my Subaru bus.
Pg _________________ 1975 1.8l FI Auto Westy - Subaru converted
1971 356 kit 1600 TP - semi/stickshift
1971 1302 LS - semi/stickshift
Trim ring info here -> http://www.thesamba.com/vw/forum/viewtopic.php?t=559668
http://www.thesamba.com/vw/forum/viewtopic.php?t=451210
http://www.thesamba.com/vw/forum/viewtopic.php?t=479721 |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4925 Location: Southern AB
Posted: Fri Feb 16, 2024 9:26 am Post subject: Re: The Stupid Question Thread |
this is what I used for my EJ2.5
I wandered the pick & pull and came across a few different donor options, this was from a late 90's ford Ranger V6, hose and all. It's quiet, has holes for evap system hoses that I just screwed new fittings into. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
pgtips Samba Member
Posted: Fri Feb 16, 2024 10:49 am Post subject: Re: The Stupid Question Thread |
Hi, thanks for the reply. Looks nice !
The obstacles I have are that over here in the UK breakers yards are very few and far between now. Used to be loads near me but Jehova W bought up the land and it's a huge JW site now.
So I'm onto eBay looking for options.
Mine has to go where the original FI air housing would have been mounted ( I took off the original brackets but that area is all I've got.)
I looked at these and that's where I wondered about the donor cc engine sizes
2007-2011 Toyota Yaris Air Filter Housing _________________ 1975 1.8l FI Auto Westy - Subaru converted
Blazman Samba Member
Joined: August 02, 2020 Posts: 57 Location: Ecorse MI
Posted: Tue Mar 12, 2024 4:34 pm Post subject: Re: The Stupid Question Thread |
How do I hook up a battery under the bed in a 74 Canadian Westfalia? I've been scratching my head about this and I just came to the conclusion that I am an absolute buffoon that has no idea what I'm doing with it. I just need to test out the inverter before hooking the stove in sink back in. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Mar 12, 2024 4:42 pm Post subject: Re: The Stupid Question Thread |
Blazman wrote: |
Refresh my memory, any pics of the battery area and surrounding loose wires? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Mar 13, 2024 6:44 pm Post subject: Re: The Stupid Question Thread |
Here is a image of under the bed.
Also, I found these seals on Amazon for the valve covers and I am afraid to take the valve covers off now because I don't know if the seals will get screwed up if I take them off with these be a good set to use with a type 4 or at all?
FEL-PRO VS 21566 C Valve Cover Gasket Set https://www.amazon.com/dp/B01EIT8YOC?ref_=cm_sw_r_mwn_dp_TQ1QRQ028P1J8F5PM2G9&language=en_US
I think I fixed the link.
[/quote]Refresh my memory, any pics of the battery area and surrounding loose wires?[/quote]
Posted: Wed Mar 13, 2024 7:47 pm Post subject: Re: The Stupid Question Thread |
Refresh my memory, any pics of the battery area and surrounding loose wires?[/quote][/quote]
Those are not Type 4 valve cover gaskets. |
Posted: Wed Mar 13, 2024 8:32 pm Post subject: Re: The Stupid Question Thread |
[/quote]Those are not Type 4 valve cover gaskets.[/quote]
Well that's good to know. I almost ordered them earlier today. Are the type 4 the longer ones that are kind of skewed a little? Like these?
I'm sorry for the long link but I copy and pasted it the way it's in my browser.
https://www.amazon.com/Fel-Pro-VS-26084-Valve-Gask...amp;sr=8-2 |
Posted: Wed Mar 13, 2024 9:21 pm Post subject: Re: The Stupid Question Thread |
https://www.amazon.com/Fel-Pro-VS-26084-Valve-Gask...-2[/quote]
There is a thread on Type 4 valve cover gaskets, I suggest reading it before ordering. |
Posted: Thu Mar 14, 2024 7:54 am Post subject: Re: The Stupid Question Thread |
In regards to the battery, fish out those wires and trace them as much as possible, then tell us what you find. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Mar 14, 2024 11:54 am Post subject: Re: The Stupid Question Thread |
Blazman wrote: |
Wildthings wrote: |
Posted: Thu Mar 14, 2024 12:09 pm Post subject: Re: The Stupid Question Thread |
busdaddy wrote: |
In regards to the battery, fish out those wires and trace them as much as possible, then tell us what you find. |
I will do that as soon as it stops piss pouring rain they said it should be until Monday over here.
I'm saving up for a collapsible carport so I can still work on her when it starts raining. |
Posted: Thu Mar 14, 2024 12:10 pm Post subject: Re: The Stupid Question Thread |
Wildthings wrote: |
Blazman wrote: |
Wildthings wrote: |
All right. I'll look it up on here. I didn't think to in the first place. Thank you. |
Posted: Thu Mar 14, 2024 12:11 pm Post subject: Re: The Stupid Question Thread |
I just got the Bentley repair and service manuals today. |
Posted: Fri Mar 15, 2024 7:38 am Post subject: Re: The Stupid Question Thread |
Has anybody tried this panel? I am in need of a rocker panel but I'm trying to find one that is in my price range That's good.
I can't find those funky green panels for the outer rocker panel. Only the inner and middle.
https://www.ebay.com/itm/262841258189?mkcid=16&...media=COPY |
