Faulty Brake Line
skabonner
skabonner is offline
PostPosted: Sat Sep 17, 2011 4:53 pm    Post subject: Faulty Brake Line Reply with quote
I just found out that my brand new hard brake line going from the passenger front brake to the master is leaking whenever I press the pedal down. Its leaking right from the fitting.
I know I need to replace it, but I am more concerned as to what would cause this, and how I can avoid this in the future. My thoughts are that maybe I bent the line at the fitting causing it to leak?
Douglas Adams wrote:
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.
'68 Beetle "Sadie" (R.I.P.)
'67 Beetle "Ilsa"
'06 Gti "Heidi"
64vdub
64vdub is offline
PostPosted: Sat Sep 17, 2011 6:01 pm    Post subject: Reply with quote
Was the line flared at the end? German lines? Most likely a quality issue. Go with good German lines and tighten them up, should be good....
64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
Founding member of Derkaferklub, Southern Cal. since 2008
Q: Would you consider a trade? What do you collect?
A: I collect money Smile
GO SF GIANTS!
Aynthm
Aynthm is offline
PostPosted: Sun Sep 18, 2011 1:13 am    Post subject: Reply with quote
Go to the fitting, you need 11mm and a 17 or 18 mm box, back off the small nut just a tad until you see 1 drop of fluid coming out, now keep the joint even and level and tighten the small nut back good and tight but don't kill it. Now wipe off the fitting dry and keep an eye on it. Put a paper bag under it and pump the brakes and see if that did it.
Mine was leaking after I pulled and hung the backing plate while I repaired the axle. When I reassembled it, it leaked little. Seems like the hard line got twisted a little. I did what I described and it stopped leaking totally.
I hope it works for you.
djkeev
djkeev is offline
PostPosted: Sun Sep 18, 2011 4:41 am    Post subject: Reply with quote
It is important that you installed the proper brake line into the car. The VW takes what is known as a "BUBBLE FLARE".
Here is an illustration of that they look like..
American cars take a double flare, notice how it is concave rather than convex. You cannot use a double flare on the German brake fittings.
Dave
Ghia
Vanagon
Beetle
skabonner
PostPosted: Sun Sep 18, 2011 8:40 am    Post subject: Reply with quote
I tried the loosening, and tightening, a couple times, and it still leaked, and yes I used a bubble flared line.
'67 Beetle "Ilsa"
'06 Gti "Heidi"
Aynthm
Aynthm is offline
PostPosted: Sun Sep 18, 2011 12:40 pm    Post subject: Reply with quote
Man, that sucks.
Can you get lines that are already flared from the manufacturer?
Maybe just get a new piece and bend it to fit.
Sorry.
skabonner
PostPosted: Sun Sep 18, 2011 3:00 pm    Post subject: Reply with quote
I buy them pre made from my friendly local vw store. I'm just gonna chock it up to either a quality issue, or I man handled it. Either way I will be more careful when I install the line. Thanks for the help.
'67 Beetle "Ilsa"
'06 Gti "Heidi"
KombiMonster
KombiMonster is offline
PostPosted: Sun Nov 13, 2011 9:02 pm    Post subject: Reply with quote
Where can one get a "bubble flare" tool?
djkeev your bottom pic looks more like a "double flare" and the top like a "single flare/bubble flare" how did you accomplish that with a double flaring tool? Mine flares the bottom out.
Dave
FOOK CANCER
*WANTED*
skabonner
PostPosted: Sun Nov 13, 2011 9:38 pm    Post subject: Reply with quote
http://www.amazon.com/OTC-4504-Stinger-Bubble-Flaring/dp/B0015PMZMU
'67 Beetle "Ilsa"
'06 Gti "Heidi"
KombiMonster
PostPosted: Sun Nov 13, 2011 9:54 pm    Post subject: Reply with quote
Thanks. I found the same one on ebay. I was hoping for some feedback on one located at a local parts store. Cool
FOOK CANCER
*WANTED*
djkeev
djkeev is offline
PostPosted: Mon Nov 14, 2011 9:49 am    Post subject: Reply with quote
Dave
Yes, that's exactly what the photos are and are captioned to point that out.
I made the "fake" bubble flare by only doing the first step of making a double flare, putting the die in the end of the pipe and squeezing it down causing it to swell above the clamp. Then just stopped right there.
I must say, I wasn't convinced it was the best system and the angle of the bubble is off from the proper Bubble flare angle so I did purchase a bubble flare tool and used it to make my brake lines for my 69 Ghia. The "fake" bubble flare system I would use in a pinch if I had to but recommend the proper tools whenever possible.
In the photo, the small round black units are dies with a built in pin that slips into the pipe and causing the bulging thus creating the bubble flare. The proper bubble flare tool works in the same manner, just at the correct angles.
Dave
Ghia
Vanagon
Beetle
KombiMonster
PostPosted: Thu Nov 17, 2011 11:23 pm    Post subject: Reply with quote
Dave,
I'm familiar with a double flare tool kit. I can see your tool that holds the line in place has a 45 degree faced edge. That won't keep/make the 90 degree required for a bubble flare. Did you use the back side of the clamp?
FOOK CANCER
*WANTED*
bill may
bill may is offline
PostPosted: Sat Nov 19, 2011 7:47 am    Post subject: Reply with quote
yes,you use rear as it don't have the champher
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Nov 19, 2011 9:28 am    Post subject: Reply with quote
Making a bubble flare by only doing the first half can work sometimes, but it's not right. The back sode of the DIN bubble flare is flat, where the back side of the first half is tapered.
All of your sealing takes place at the flare. If you have a leak, either the flare isn't seating properly to make a seal, or you have a split in the flare. A quick test it to clean the flared end, and color it with a Sharpy. Install the end in the port barely hand tight and spin it. Remove it and you can see where it's hitting......or not hitting. It should be hitting in the middle of the flare, from top to bottom. If it's not, the flare angle is off and can potentially leak. Good luck!
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
