Dont look if youre a purist!!! Volksrod build
Page: 1, 2, 3, 4, 5, 6  Next
modelmakerinc
modelmakerinc is offline
PostPosted: Thu Apr 05, 2012 6:02 pm    Post subject: Dont look if youre a purist!!! Volksrod build Reply with quote
hey guys I Have seen plenty of modified beetle members get Flamed here. Well this build may tick off a few, buit as the saying goes: its my car.....
As I got it, nothing more than the pic shows
separated it for the body work
after cutting out some rust this was typical on both sides
driverside patch welded in
modelmakerinc
PostPosted: Thu Apr 05, 2012 6:09 pm    Post subject: Reply with quote
cut the front apron for the extended beam
used the factory bracing for the new mount and fuel tank raise
enclosed the new trunk area
front beam in place
Hyundai tiburon seats, they fit awesome, my 5-1" wife can drive it and my 6-4" buddy can also.
modelmakerinc
PostPosted: Thu Apr 05, 2012 6:18 pm    Post subject: Reply with quote
body back off the chassis for bodywork
here are my custom light housings
reassembly front
rear with custom hood treatment
modelmakerinc
PostPosted: Thu Apr 05, 2012 6:22 pm    Post subject: Reply with quote
dash painted and mostly reassembled
trunk spatter painted
here you can see some of the frame head brace
roller
gore666
gore666 is offline
PostPosted: Thu Apr 05, 2012 6:27 pm    Post subject: Reply with quote
damn your work looks good keep it up
txny13
txny13 is offline
PostPosted: Thu Apr 05, 2012 6:30 pm    Post subject: Reply with quote
nice ride ,now thats how to make it yours
TjdTaylor
TjdTaylor is offline
i love a good volksrod, especially when done propperly. Looks perfect. Are you looking to do a roof chop?
1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote:
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows
Opticsguy
Opticsguy is offline
PostPosted: Thu Apr 05, 2012 7:07 pm    Post subject: Reply with quote
nice work! what'd you have to do to get those seats in? I still have my stock seats and am not a big fan
72 sb convert
Past vws
98 jetta gl
03 20th gti
03 jetta gls tdi wgn
Lucatero
Lucatero is offline
PostPosted: Thu Apr 05, 2012 7:16 pm    Post subject: Reply with quote
Your work is nice. I'm looking forward to seeing a completed project.
64 Beetle Type 1/Totaled
64 Beetle Type 1/Totaled after owning 5day!
71 Beetle Type 1
70 Karmann Ghia
erfani69beetle
erfani69beetle is offline
PostPosted: Thu Apr 05, 2012 7:21 pm    Post subject: - Reply with quote
clean work man, looks great so far. guess im a purist, but im digging this for sure.
tabbottuf
tabbottuf is offline
PostPosted: Thu Apr 05, 2012 7:53 pm    Post subject: Reply with quote
I'm a purist for the most part but I know good work when I see it....and thats good work. If you can do work like that, then you can damn well do with that car whatever you please. Keep it up and keep the pics coming.
Tracy
vw_hank
vw_hank is offline
PostPosted: Thu Apr 05, 2012 7:59 pm    Post subject: Reply with quote
Looks grate!! nice workmanship!!
I think most of the flaming is directed at guys that cut up and half ass good cars Wink what you did was save A pile of crap from the scraper Cool
1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods!
modelmakerinc
PostPosted: Fri Apr 06, 2012 4:43 am    Post subject: Reply with quote
Thanks for the kind words guys, I appreciate the kudos.
I am not a fan of chopped roofs, I just never liked the look so it will stay stock.
Seating position in a stock bug is my biggest complaint. I feel that I am on top of the car instaed of in it, these lower my a$$ about 5" and make for a "sportscar" feel instead of a van. The install was actually a pretty straightforward task. a piece of 1/16" rectangular tube stock was cut to create mounting "saddles" a nut was welded to the backside and then welded and boxed in. two along the heater channel and two on the shiftrod/tranny center hump. this is the full back position, in the position I drive you cannot see the mounting tabs.
DesertBob
DesertBob is offline
PostPosted: Fri Apr 06, 2012 6:05 am    Post subject: Reply with quote
Very nice. What a way to own it. Every project should reflect the owners style. Love your metal working skills. Can you provide some more details on the speaker boxes you made under the dash? The reverse lights in the rear apron are also killer.
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around.
VeedubPastor
VeedubPastor is offline
PostPosted: Fri Apr 06, 2012 9:12 am    Post subject: Reply with quote
They're in the deck lid. He doesn't have a rear apron.
1971 Super Beetle - Daily Driver
Solex H30/31 & 034 distributor (yeah, I know)
Stock thermostat & flaps
Stock air cleaner and emissions equipment
twomonkeysayoyo
twomonkeysayoyo is offline
PostPosted: Fri Apr 06, 2012 9:33 am    Post subject: Reply with quote
vw_hank wrote:
Looks great!! nice workmanship!!
I think most of the flaming is directed at guys that cut up and 'half ass' good cars Wink what you did was save a pile of crap from the scrapper Cool
yep
Looks like trouble.
Greg in GA
Greg in GA is offline
PostPosted: Fri Apr 06, 2012 2:00 pm    Post subject: Reply with quote
yep, craftsmaship is always appreciated
1969 Beetle
1974 Westy 1800cc FI conversion, L62H
Need a really good mechanic for your VW bus? Consider making an appointment with Colin (Amskeptic) next time he passes thru your area.
poomwah
poomwah is offline
PostPosted: Fri Apr 06, 2012 2:26 pm    Post subject: Reply with quote
Wow, incredible work. Those wheel wells are super smooth., very clean build. Could we see more pics of the frame head brace please. Is that a dbug brace or just the extender
Rocco- my build thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=479675
lukel
lukel is offline
PostPosted: Fri Apr 06, 2012 2:40 pm    Post subject: Reply with quote
Very nice work! I really like the stance this thing has, and the wheels look sweet. Ill definetly be following this thread.
Good job man!
modelmakerinc
PostPosted: Fri Apr 06, 2012 5:45 pm    Post subject: Reply with quote
The frame head brace is 1"square tube welded in but I am using a DBug41 8" extender.
there are alot of things I didnt photograph. I tell you a bit about the chassis. it has drop spindels and ghia disk brakes, beam extender, rotors and front wheels will go to chevy bolt pattern. Rear drums are chevy pattern and has 295 50 15 coopers on 15x10 centerlines. all bushings, bearings, ball joints, tie rod ends, brakes parts. ect. are new I flipped the IRS arms and dropped the rear about 5" from stock. KYB shocks on all for corners. Motor is a very good running 1600 DP with a Weber Progressive on a Bugpack intake, one wire altenator, buggy exhaust bug pack short shifter. Nothing fancy just neat , clean and simple.
here are a few more shots after some blocking getting it ready for the spray booth, it will still get full coat of 2K then blocked once more. then ready for color and clear. I have been working on this for about a year on and off as days off and family matters allow.
Page 1 of 6
