Yorkie Samba Member
Joined: September 16, 2011 Posts: 9 Location: Long Beach
Posted: Tue Sep 11, 2012 6:10 pm Post subject: Deluxe Trim Color Insert: How to Install? |
I am about to replace the insert trim on my '67 Delux and I was wondering if anyone had some tips on how to make this task go smoothly. Last time I tried it I ended up leaving marks on the insert rubber and my fingers went numb.
Thanks,
Kevin
Long Beach |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3505 Location: Anderson SC
Posted: Tue Sep 11, 2012 6:16 pm Post subject: |
I just did my 67 deluxe and I used a plastic trim tool and placed the rubber trim into the top of the aluminum and pushed the bottom of the rubber trim piece into the bottom of the alumninum trim. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Tue Sep 11, 2012 6:21 pm Post subject: |
I've used a credit card, too. It helps if the plastic (trim, not the card!) is as warm as possible so it is flexible. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Tue Sep 11, 2012 6:24 pm Post subject: |
X2 on the warmth of the insert...leave it out in the sun for a while before you start. Also, and esp. if its warm, avoid stretching it along its length as you insert it, as it will then draw back up afterwards and be too short.
Also, when you cut the ends, a bit of a point will help the end caps keep it in place. |
69er Samba Member
Joined: July 24, 2009 Posts: 42 Location: Chiang Mai, Thailand
Posted: Tue Sep 11, 2012 10:57 pm Post subject: |
I sacrificed an old, expired credit card and it helped a lot.
Suggestion: Leave the rubber outside under the midday sun for 7-10 days before installation, let it shrink as much as it could before you put it in the trim.
I learned this lesson the hard way when I didn't do that before parking the bus outside. Two weeks later, both ends of the rubber insert just drew back about half an inch. |
runderwood Samba Member
Joined: July 17, 2007 Posts: 274 Location: near philadelphia, pa
Posted: Wed Sep 12, 2012 6:32 am Post subject: |
X2 on the "do not stretch" the insert. I stretched it on mine when I installed and was fine for a few months, then it got cold, and now every piece is way short. I actually brought another insert, and need to redo now. _________________ 61 DD Panel |
Dluxsplits Samba Member
Posted: Wed Sep 12, 2012 8:57 am Post subject: |
I let it soak in bucket of hot water right before install but like said before don't stretch it. good luck _________________ ________________
'67 deluxe bus
'66 deluxe bus
'60 og paint kombi
'59 og paint bug |
d-rick Samba Member
Joined: May 14, 2006 Posts: 892 Location: Columbia,MO
Posted: Wed Sep 12, 2012 7:59 pm Post subject: |
I just did mine on my '66 13 window
I left it in the bed of my truck which has a topper on it(like a dang oven!!).. Let it sit in there for a few hot days. Made it easier for sure. The credit card trick works well if you can get it down _________________ 1959 mango-trailerbus
1962 single cab *1/2
1966 13 window
1967 panel/camper
1968 cig-panel *1/2
1968 passenger bus *1/2
1969 beetle
1969 dormobile
1978 sage green Westy
1990 DoKa
2002 Golf TDI |
Split 1 Samba Member
Joined: May 03, 2005 Posts: 764 Location: Adelaide. South australia
Posted: Thu Sep 13, 2012 6:54 am Post subject: |
I put mine in a pan of hot water for a few minutes, used a wooden spatula, went in easy enough
Split1 |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71919 Location: Phoenix 602
Breckskier Samba Member
Joined: December 16, 2002 Posts: 239 Location: Grand Rapids, MI
Posted: Sat Nov 15, 2014 11:41 pm Post subject: |
Where is a good place to buy this rubber? And what do people feel about this red insert on a Turkis color deluxe? _________________ BreckSkier
67 13w Deluxe-"St. Pete" the Airport Jet Bus
65 13w Deluxe-"St. Nikolas"
67 912(911.5 Outlaw build spring 2015), 90 C4Cab. Formerly: 59 DD, 78 SuperB, 81 911Cab, 82Vanagon, 81Vana & other German / US stuff.. |
Posted: Sun Nov 16, 2014 1:25 am Post subject: |
| Mine was a Turkis and white duxe and it came standard with the red infill |
Posted: Sun Nov 16, 2014 11:40 am Post subject: |
| EverettB wrote: |
| Breckskier wrote: |
| Where is a good place to buy this rubber? And what do people feel about this red insert on a Turkis color deluxe? |
The red stuff above I bought from Wolfsburg West.
I personally like the green on my green Bus but if you like red better, go for it. |
Awesome! Thanks! _________________ BreckSkier
Posted: Sun Nov 16, 2014 11:44 am Post subject: |
Is there a difference in the Sealing Wax red to the Titan red? I'm sort of color blind, so I don't see the difference well. Which would go on a '66 Deluxe? _________________ BreckSkier
Posted: Sun Nov 16, 2014 5:24 pm Post subject: |
| Breckskier wrote: |
| Is there a difference in the Sealing Wax red to the Titan red? I'm sort of color blind, so I don't see the difference well. Which would go on a '66 Deluxe? |
There are two options of sealing or Titan on WW, so wasn't sure if much of a difference? _________________ BreckSkier
dawerks Samba Member
Posted: Sun Nov 16, 2014 6:28 pm Post subject: |
Cannot be done at -20 Celcius. Don't try it. _________________ "There is only one sin; disconnection from self." |
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Sun Nov 16, 2014 8:40 pm Post subject: |
| Breckskier wrote: |
| Breckskier wrote: |
There are two options of sealing or Titan on WW, so wasn't sure if much of a difference? |
The Titian red is more a blood, SWR more like a tomato (if it helps). The natural compliment to Turkis would be the darker Titian insert, but if people don't already know you're colorblind, they will after the install.
This thread is heavy with warnings about shrinkage, but it is easily combated, simply cram in more insert than you think you can. Example: on a cargo door, if the piece you pre-cut is 1" long, cram a 1/2 inch of it in the molding. You should be able to cram 1/2" of extra material into every 12" of run in the strip. I easily have 5 1/2" of extra material crammed into my long strip on the driver's side. When it shrinks in 40 years, I'm ready. _________________
| EverettB wrote: |
FU#5 |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7125 Location: Lawrenceville, Ga
Posted: Sun Nov 16, 2014 8:44 pm Post subject: |
| Breckskier wrote: |
| Breckskier wrote: |
66 and up would be titian red. _________________ regards
Uli
Posted: Mon Nov 17, 2014 3:36 pm Post subject: |
| hitest wrote: |
The natural compliment to Turkis would be the darker Titian insert, but if people don't already know you're colorblind, they will after the install. |
Ha! LOL that's great! Thanks guys. _________________ BreckSkier
