joecestes Samba Member
Posted: Sun Oct 21, 2012 10:58 am Post subject: |
Thanks for the help and info. It is greatly appreciated |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Sat Oct 20, 2012 5:08 am Post subject: |
joecestes wrote: |
I'm in Winchester kentucky |
Phil's Bug shack in Grayson or Southern Buggies in London. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Posted: Thu Oct 18, 2012 3:57 pm Post subject: |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20388 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Oct 17, 2012 7:54 pm Post subject: |
Early tie rod ends and spindles holes are small hole.... Later had larger.... Get a half way decent set of calipers and measure things.... Order things according to dimensions you have on items to replace... Go to Rite Aid or CVS or Staples or where ever and get a spiral ring note book, document and record what works with year/mode/part numbers so in future you can work on the beast with knowledge of what items are and what is needed if you need to replace something...
I have been keeping a "log book" of all the parts and modifications and everything I do for my FG Buggy I autocross race, and it helps me to know what I have done. What does and does not work, and a record of things like valve adjustments or steering adjustment changes and whatever so I can gauge the wear and tear on engine and running gear parts and "go back" to known point where it was working before I fooled with it...
Posted: Wed Oct 17, 2012 3:36 pm Post subject: |
Where in Ky are you located?
I know a couple knowledgeable shops in Ky.........I own a shop in Indiana.
Online stores are great if you know exactly what you want.
Most are typically order takes with no real VW knowledge. _________________ Gary
Posted: Wed Oct 17, 2012 3:02 pm Post subject: |
I understand that it is a mix parts. The problem I have is I don't know of a buggy or VW shop near me (that I would trust). I have to rely on local auto parts stores or online. The parts stores around me will hire anybody regardless of if they know about cars or not, and they don't like to try and match things. Not to mention they don't stock parts for older VW's. I'm just trying to avoid the hassle of returning parts. Can you guys tell me some good reliable and trusted online store.
I do appreciate all the help you guys have given me. Thank You |
sxuxrxf Samba Member
Joined: May 18, 2005 Posts: 1338 Location: Oceanside, CA
Posted: Wed Oct 17, 2012 1:53 pm Post subject: |
You have a buggy, which means it's probably a collection of random parts to begin with.
The year the beam was actually produced doesn't mean anything. Link pin or ball joint is what matters.
The tie rods are connected to the spindles and steering arm. They could be small ends or large, or even drilled for other brands such as Ford.
You'll have to match what you actually have, rather than ask for parts from a specific year or model. Keep a growing list of parts to aid in future repairs. _________________ (ignore the X's ) |
Posted: Wed Oct 17, 2012 8:42 am Post subject: |
what about tierods and steering arm. Are all king pin beams the same? I will probably need bushigs as well. Is there away to know exactly what year the beams is? |
Posted: Mon Oct 15, 2012 12:52 pm Post subject: |
66 was 1st year for ball joint.
Original LP bearings were typically ball bearing style and replacements are usually roller but dimensions are the same. _________________ Gary
Posted: Sun Oct 14, 2012 8:17 pm Post subject: |
All years of K&L front beams use same bearings (only difference being inner and outer) ...
The changes came in 65 when they went BJ and again in 68 when ID of inner bearing went from 27mm to 29mm....
It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Dayton, Nevada
Posted: Sun Oct 14, 2012 6:06 pm Post subject: |
I have found it easier to take the old bearing with you when you go get new ones. It sucks to be in the middle of a project covered in grease only to find the parts do not fit. It sounds like you have a link and king pin front end. _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
Posted: Sun Oct 14, 2012 5:51 pm Post subject: How do you I.D. front H-beam |
I recently got a buggy, but don't know what year the H-beam is. Is there away to identify the beam? It has the wide five bolt pattern and is a king pin. That is all I know. I am going to need to put wheel bearings in and would like to freshen up the front end when I do. |
