hrsr Samba Member
Joined: June 21, 2010 Posts: 57 Location: Aldershot, Hampshire, UK
Posted: Fri May 24, 2013 10:51 am Post subject: Beetle 1300cc (Historic Touring Car Racing) |
She's getting quicker!
Roadcow Samba Member
Joined: November 14, 2003 Posts: 1012 Location: Stockton, Ca. area
Posted: Fri May 24, 2013 11:10 am Post subject: |
nice job with the Cortina! _________________ 71 Westy Roadcow
67 Panel
63 Bug
66 Ghia Bonneville 2014
74 Ghia Vert
69 Bonneville Ghia 150 in Chico
69 Bonneville Ghia in Ireland
80 Cabby 2.1 16v
98 Passat |
hrsr Samba Member
Posted: Fri May 24, 2013 11:18 am Post subject: |
| Yep!....Quicker on the day than four of the 911's, couple of Lotus Cortina's and a 7 litre Galaxie. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2585 Location: The Real NDK So Cal
Posted: Fri May 24, 2013 12:10 pm Post subject: |
| that motor sounds great. if you could get rid of some understeer you would be right up front. |
hrsr Samba Member
Posted: Fri May 24, 2013 12:40 pm Post subject: |
| The understeer is just cold tires. Once they are up to temperature the car is pretty well balanced...Not a lot of grip though with skinny Historic crossply tires 120mm fronts and 135mm rears! |
Boolean Samba Member
Joined: January 19, 2012 Posts: 1712 Location: Stockholm
VW&MGman Samba Member
Posted: Fri May 24, 2013 4:20 pm Post subject: |
Could you post some pictures of the out side of your car? I'm running a Beetle in vintage racing and just wondering if you have any aero devices on your car. Your steering seem very stable at 100 MPH as opposed to mine.
Thanks! |
hrsr Samba Member
Posted: Fri May 24, 2013 5:10 pm Post subject: |
Hi
No aero devices allowed so the cars stability is all down to the suspension setup. If you look at all 1960's, 1970's rear engined road racers (Porsches, Renault Alpines, Fiat Abarths etc) the rear end is always lower than the front. Rear engined cars must have more aerodynamic lift on the front than the rear (this is one reason why Porsche 911's have such large rear spoilers and the same reason why VW raised the Beetles front ride height by an inch or so in the late 60's, early 70's)
Set the rear end an inch or so lower than the front and you should see a difference on the straights AND in the corners.
Good luck!
Ian
[/img][/code][/url] |
fcampbell356 Samba Member
Joined: December 15, 2007 Posts: 217 Location: Pensacola, Florida
Posted: Fri May 24, 2013 5:29 pm Post subject: |
Ian:
Whats up with the motor? And what brakes are you running?
Cool cars, gotta love them.
Thanks
Frank |
hrsr Samba Member
Posted: Fri May 24, 2013 6:02 pm Post subject: |
CSP disc brakes all round with fast road pads. The brakes kept locking up when I tried using race pads as the skinny historic tires don't have enough grip to cope with the braking power.
The engine is fine, the stuttering in the corners is tire shake!!
I'm pushing the car so hard now that I'll need to start adding better bracing on the gearbox. I've also been told to replace the rear body rubber mounts (in front of the rear dampers) with metal spacers as this should stop the rear torsion housings from flexing. |
Posted: Fri May 24, 2013 6:57 pm Post subject: |
Main intrest in engine, size, carbs ect. You might consider one of the offroad type transmission strap kit like Bugpack list, their part number
6522. Look on the Bugpack or any offroad supplier for something similar.
to help with the tranny flexing.
Does the car feel stable at top speed? The sedans always wanted to fly around.
Thanks
Frank |
hrsr Samba Member
Posted: Fri May 24, 2013 10:39 pm Post subject: |
The Beetle is really stable and doesn't slide or twitch around anything like as bad as the Lotus Cortinas and Hillman Imps that I'm up against. If you notice on that lap, i'm going through bends at up to 83-99mph without any drama.
Car Spec: 1965 swing axle Beetle, CSP disc brakes all round, 1285cc, 44 Webers, Engle FK10 cam, reworked stock heads with stock sized valves, cooling by 12 inch electric fan and ram air pipes, approx 120-125bhp@ 8000rpm. Bears close ratio gearbox with a Quaife ATB diff, Dunlop historic crossply tyres, weight around 740kg with driver. Front suspension: Stock beam, springs and rubber bushes, adjustable Formula Vee anti-roll bar, 2.5" dropped spindles, Quantum double adjustable motorsport dampers. Rear suspension: Stock springs and rubber bushes, lowered 2 splines, custom made heavy duty adjustable Z-bar, Quantum double adjustable motorsport dampers. |
dawie Samba Member
Joined: July 27, 2008 Posts: 222 Location: Cape Town, South Africa
Posted: Fri May 24, 2013 11:54 pm Post subject: |
| Nice. What is your compression ratio and fuel type/ octane? |
John Moxon  Samba Moderator
Joined: March 07, 2004 Posts: 14260 Location: Southampton U.K.
Posted: Sat May 25, 2013 2:09 am Post subject: |
Thanks for the pictures. The car looks awesome!
Are you using any caster shims up front? How many pairs are you using? |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Sat May 25, 2013 3:42 am Post subject: |
| Outstanding ! |
hrsr Samba Member
Posted: Sat May 25, 2013 7:15 am Post subject: |
| dawie wrote: |
I believe its 9.5: or 10:1 and it currently runs on regular 101 octane supermarket fuel...nothing fancy.
May try some Sunoco fuel at some point but it must be designated 'pump gas' to be legal for the racing, so there won't be any noticeable HP gains...may run cooler though. |
hrsr Samba Member
Posted: Sat May 25, 2013 7:26 am Post subject: |
| VW&MGman wrote: |
I believe there is only one set because the front is barely 1 inch lower than stock. the rear is probably only 2 to 2.5 inches lower than stock.
Lowering your swing axle Beetle to the floor won't make it handle any better...It's a 1550lb car with a fairly low centre of gravity, so you can get away with plenty of suspension travel and quite a soft setup. As an example my front suspension moves by 4 or 5 inches (watch the front end when I brake hard) |
boxkiteflyer Samba Member
Joined: May 22, 2008 Posts: 261 Location: Taylorsville, KY
Posted: Sat May 25, 2013 10:54 am Post subject: |
| What a nicely sorted car! Thanks for posting! |
Posted: Sat May 25, 2013 1:01 pm Post subject: |
Ian:
Please keep updating the thread with pics and details. Reminds me when some guys got together and ran a 71 or 72 Super Beetle in the Old
Trans-Am Series here in the States. They went so fast , bent the front
hood in and helped with the aero. |
