turn signal light bulb color 1960
Lidpainter
Samba Anti-Hero
Lidpainter is offline
PostPosted: Fri Nov 15, 2013 1:03 pm    Post subject: turn signal light bulb color 1960 Reply with quote
I had a question regarding the front signal lights on a '60 Beetle. I know the peanut light lenses are clear but are the bulbs themselves also supposed to be clear? I searched but could not find a definitive answer.
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Fri Nov 15, 2013 1:19 pm    Post subject: Reply with quote
The rule of thumb for VW's... all bulbs were clear, if other colors were required.. the lens was tinted.
According to owners manuals, the original replacement 6 volt bulb for flashing indicators would have been a N177311.. Thats a clear lens bulb.
http://www.thesamba.com/vw/archives/manuals/61_65bug_replacement/page81.jpg
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=N177311
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Lidpainter
Samba Anti-Hero
PostPosted: Fri Nov 15, 2013 3:22 pm    Post subject: Reply with quote
Thanks very much Sir.
AlteWagen
Troll
AlteWagen is offline
PostPosted: Fri Nov 15, 2013 11:01 pm    Post subject: Reply with quote
U.S. DOT did not require an orange turn signal until 63.
Official Dual Carb Thread
VOLKSWAGNUT
PostPosted: Sat Nov 16, 2013 6:50 am    Post subject: Reply with quote
For CARS, The front turn/park lamps can be either clear/white or amber. (dot approved)
It is up to the manufacturer which dot approved color to use..
My total off the hip guess, VW changed to all amber fronts to save money.. That way what they (then) shipped to the US (after 63) was the same as everyone else.
aka Ken {o\!/o}
AlteWagen
Troll
PostPosted: Sat Nov 16, 2013 10:56 am    Post subject: Reply with quote
VW used clear bulbs in all vehicles until the end of production. The amber color is due to the lens itself not the bulb.
DOT regulations in 63 approved red or amber front turn signal use on passenger vehicles as studies found it more affective and improved safety. The new law in which amber was "mandatory" in 1968 allowed a transitional period where vehicles produced between 63-67 could use either white or amber.
For VW 1963 was a transitional period where Type II started using an orange insert in the lens around Aug, I have not been able to pin down the use of orange lens peanut signals but late 63 is my guess as well.
Helfen
Helfen is offline
PostPosted: Sat Nov 16, 2013 11:21 am    Post subject: Reply with quote
"The new law in which amber was "mandatory" in 1968 allowed a transitional period where vehicles produced between 63-67 could use either white or amber."
So did you mean the lens must be amber???
Then explain why my 69 Pontiac and my 76 Olds and my 2001 Nissan and 2013 Nissan have clear lens??? They do have amber bulbs though. I believe the law says either the lens or the bulb. Even my 62 Pontiac has clear ft lens with a amber bulb.
AlteWagen
Troll
PostPosted: Sat Nov 16, 2013 11:38 am    Post subject: Reply with quote
The transitional time came as a result of auto manufacturers complaining that the change was not cost effective for them. While some manufacturers went with an amber lens some used an orange bulb. As long as the signal was not white and was seen as amber it passed the requirement.
I wonder if orange bulbs cost more back in the day and thats why VW made the lense orange to keep maintenance cost down for the consumer.
VOLKSWAGNUT
PostPosted: Sat Nov 16, 2013 3:06 pm    Post subject: Reply with quote
Hmmm...... No red lamps on the front for passenger cars.. other than emergency vehicles..
And here in NC.. Front turns/parks can only be white/clear/amber.
aka Ken {o\!/o}
AlteWagen
Troll
PostPosted: Sat Nov 16, 2013 3:09 pm    Post subject: Reply with quote
same here in CA, I guess thats why they specified red OR amber
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Sat Nov 16, 2013 3:47 pm    Post subject: Reply with quote
red in front? I don't think so. Clear or Amber only.
I'm not sure when "modern" amber bulbs with yellow glass came around. Back around 1990 I only remember there being 1157NA dual filament - and I wanted amber bulbs under my front clear lenses, so I had to modify 1157NAs. It was much later that I ever saw any 1156 in amber.
However, Looking through my 1964 JC Whitney catalog, when the amber-in-front conversion was in full swing, they did have what looks like single filament 12V bulbs for sale, lots of conversion lenses, plus both brush on and spray-on amber paint to coat lenses or bulbs. I wonder if those 12V bulbs back then were really yellow colored glass or were internally or externally coated.
AlteWagen
Troll
PostPosted: Sat Nov 16, 2013 4:04 pm    Post subject: Reply with quote
You are correct, red turn signals are only allowed in N. America on the REAR where as in the rest of the world amber is the only allowed both front or rear.
Sorry for any confusion
Helfen
Helfen is offline
PostPosted: Sat Nov 16, 2013 9:09 pm    Post subject: Reply with quote
Andy, because 62 Pontiac's have a clear lens and are mounted in the slot on the ft bumper they are hard to see, but take a look at a 63 Pontiac Grand Prix....you can see the reflection in the turn signal lamp reflector even when their not on and that is the way they came from the factory;
http://gatewayclassiccars.com/images/carpics/LOU/443/443c.jpg
The part # is a 1157NA the NA denotes amber. The clear bulb is a 1157
The Android
PostPosted: Sun Nov 17, 2013 9:16 am    Post subject: Reply with quote
I have no argument about certain classic cars having clear lenses with amber bulbs behind them. I mean, Whitney was selling amber bulbs, they existed. I wanted to do the same back in 1990 or so for my 62 Bug (and could only find 1157NA bulbs back then, which I had to modify to make work)
My question was more along the lines of how the bulbs were constructed back then - NA I seem to recall was for "natural amber" - that is, the glass itself is amber, and isn't just a yellow coating on the inside or outside of the glass.
