dropped65 Samba Member
Posted: Fri Apr 11, 2014 8:31 am Post subject: Mirissa's Beetle |
So let me start the story about my friend Mirissa and her fathers plans to build a beetle with the excuse of there's plenty of time and we will get to it excuse. Well time ran out Nov. 24 2011. fast forward a few months and i was talking with her father Steve and we came to the conclusion that we would build her a beetle the way she would like it.
we started with this 73 standard sedan
about halfway through the tear down and body work we found this 65 sedan
body work was all done so it wend straight to paint
[img]https://scontent-a-lga.xx.fbcdn.net/hphotos-ash2/v/t1.0-9/483819_10151356458836517_1996736985_n.jpg?oh=3e19c6c2ed4a610ed56049e2da028fd4&oe=53CC4952[/img]
brought it home and started the finish work on the pan
built a 1681 engine
put the body back on and wired up
took it out for its first ride on april 20th 2013
this past winter was supposed to be interior with a new headliner and carpet but a smoking deal on a fresh 1835 engine slowed the interior progress |
Posted: Fri Apr 11, 2014 10:25 am Post subject: |
Mirissa and her father Steve
2true Samba Member
Posted: Fri Apr 11, 2014 12:23 pm Post subject: |
More pics! _________________ AKA Destroyer of the Rants...... |
Posted: Fri Apr 11, 2014 12:33 pm Post subject: |
Posted: Sat Apr 12, 2014 5:23 am Post subject: |
the 1835 installed
folks55 Samba Member
Joined: August 30, 2008 Posts: 894 Location: High Desert Ca
Posted: Sat Apr 12, 2014 7:17 pm Post subject: |
Very cool |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Posted: Sat Apr 12, 2014 7:23 pm Post subject: |
dropped65 wrote: |
the 1835 installed
A few suggestions.
The generator backing plate needs to be rotated 90* clockwise so the vent in the inside gets air to cool the generator.
I would swap locations of the coil and the voltage regulator.
I would remove the mechanical fuel pump if it's not being used.
I'd loose the serp belt and use the stock V best. You need the belt to slip a bit or you can exploded the fan if you miss a shift. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Apr 14, 2014 6:23 am Post subject: |
i thought the backing plate was on wrong i wasnt there when the owner put it together.
why move the coil and vr?
the mech pump s just there as a block off plate until the block off plate comes in
the owner likes the serp belt he doesn't really get on the car the 1835 is kind of a waste but he likes the look more than anything else |
Posted: Fri Apr 18, 2014 6:00 am Post subject: |
smaller front tires and front trim on
new headliner, seats and door panels
Posted: Mon Apr 21, 2014 4:56 am Post subject: |
Posted: Wed Apr 30, 2014 4:43 am Post subject: |
Posted: Wed Oct 22, 2014 5:23 am Post subject: |
trying out some 15x8s with a 195/60r15 tire |
rwf8ball Samba Member
Posted: Tue Oct 28, 2014 3:37 pm Post subject: |
How do you like those 15 x 8 wheels? Do they rub? Have you lowered it? I like the look. |
Posted: Wed Oct 29, 2014 6:05 am Post subject: |
rwf8ball wrote: |
so far so good they don't rub and as far as i know its stock height i have never measured it but i haven't lowered it |
Posted: Wed Oct 29, 2014 6:10 am Post subject: |
Cool Thanks |
a4tek Samba Member
Joined: October 29, 2014 Posts: 3 Location: san diego
Posted: Sun Nov 09, 2014 11:08 am Post subject: |
looking great keep it up |
Posted: Mon Apr 20, 2015 8:02 am Post subject: |
so we tore the car apart again this winter
put in a ranch pro street trans, 1.3:1 rockers, merged headers, kennedy clutch/pressure plate, vdo gauges
Posted: Tue Apr 21, 2015 6:22 am Post subject: |
also picked up a set of 2pc centerlines
Posted: Fri Apr 24, 2015 5:17 am Post subject: |
new tires 205/70 r 15 |
noslocars Samba Member
Joined: March 09, 2010 Posts: 250 Location: Salt Lake City
Posted: Thu Apr 30, 2015 8:59 pm Post subject: |
Did you re-do the seats yourself? If you did, where did you get the covers from? _________________ Current projects:
http://noslocars.blogspot.com/ |
