ataraxia Samba Member
Joined: March 19, 2010 Posts: 4511 Location: Illinois
Posted: Mon Aug 18, 2014 6:45 am Post subject: Pushbutton Assembly and 12v conversion |
I'm considering a 12 volt conversion on my 1964 Variant S.
Going from memory on 4 hours of sleep, I'm pretty sure I have all of the pieces to the puzzle:
*Bulbs
*Horn
*Electronic signal flasher
*Headlight relay
*Generator
*Starter with 6volt teeth
*Battery
*12v wiper motor
*Voltage regulator
*Coil
*Fan shroud
*Generator strap
*Chokes
What did I forget?
One question remains:
What problem will I find when converting a pushbutton dash car to 12 volt?
Before I go diving in I'd like to know about how it'll affect the pushbutton assembly (if at all). I don't think there are any issues beyond the wiper switch which might not like the conversion without a voltage drop doohickey.
Any experience with a pushbutton assembly and a 12 volt conversion? What did you find?
ron smith Samba Member
Joined: October 24, 2003 Posts: 33 Location: San Diego
Posted: Mon Aug 18, 2014 7:16 am Post subject: pushbuttons |
I been useing my pushbuttons in my 64 notch for the last 15 years and have no problems useing 12 volts. my wiper motor is still 6v and you just need to turn the switch to the slowest speed. |
Posted: Mon Aug 18, 2014 7:22 am Post subject: Re: pushbuttons |
ron smith wrote: |
Thanks for the input...I'd hate to roast the pushbutton assembly by overlooking something. |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2400 Location: Moody, AL
Posted: Mon Aug 18, 2014 7:28 am Post subject: |
That sounds like everything...
You can use a 6 volt starter. I used one for 16 years on my 66 Bug. _________________ 71 Elm Green FI A/T Squareback |
Posted: Mon Aug 18, 2014 7:31 am Post subject: |
Donnie strickland wrote: |
You can use a 6 volt starter. I used one for 16 years on my 66 Bug. |
I've done that in the past...I have a brand new IMI starter with the 6 volt teeth so I'm going to use it. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Mon Aug 18, 2014 9:16 am Post subject: Re: pushbuttons |
ataraxia wrote: |
ron smith wrote: |
Putting an old Chrysler ballast resistor inline to the wiper motor works to keep the speed sane.
Don't forget the clock. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Those who can't? Subaru. |
Posted: Mon Aug 18, 2014 10:05 am Post subject: Re: pushbuttons |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
Don't forget the clock. |
Got a link for that resistor?
Tach in the clock hole so I'm good there... |
Posted: Mon Aug 18, 2014 10:20 am Post subject: Re: pushbuttons |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
http://www.partsgeek.com/gbproducts/MC/14451-07038...Mgod6FkAYw _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 23505 Location: Kimball, Mi
Posted: Mon Aug 18, 2014 10:31 am Post subject: |
Depending on which 12 volt wiper motor you're using, you might have to add a seperate switch to control the wiper speed. I did that, when I converted my 64 T-34 to 12 volts. The push button unit then just becomes an on-off switch.
Also, IF your carbs have electric idle cut off jets, you'll need to swap them for 12 volt units. If you have the mechanical version, then you don't have to do anything with them.  _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Aug 18, 2014 10:39 am Post subject: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
http://www.partsgeek.com/gbproducts/MC/14451-07038...Mgod6FkAYw |
Thank you...where does it go in the system? Is this keeping both the pushbutton assembly and the 6 volt wiper motor or do I have to replace the wiper motor with a 12 volt unit? Trying to find the most useful, least involved method.
Bobnotch wrote: |
Also, IF your carbs have electric idle cut off jets, you'll need to swap them for 12 volt units. If you have the mechanical version, then you don't have to do anything with them.  |
Single speed 12volt wiper motor (unless Tram's idea works better). The car isn't going to be driven in the rain all that often...although I like your idea.
Carbs don't have electric idle cut offs so I'm good there.  |
Posted: Mon Aug 18, 2014 7:18 pm Post subject: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
Bobnotch wrote: |
Ok, so you're using the 67 only (12 volt variable speed) wiper motor? And not the 2 speed unit? If so, then it's just plug and play. If you have a 2 speed motor (68 to 70), then you'll need to add a 2 speed switch. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4695 Location: Pasadena CA/DTLA soon China
Posted: Mon Aug 18, 2014 9:22 pm Post subject: |
Don't mean to highjack thread, but what kind of relay did you use for the horn and foglights on your type 34, Bob?
Martin
allwagons _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
Everything sounds good on paper! |
Posted: Tue Aug 19, 2014 8:18 am Post subject: |
ALLWAGONS wrote: |
Martin
allwagons |
Standard 12 volt Bosch relays from KGPR. I basically kept the wiring stock, and used the 12 volt relays with 12 volt components. Plug and play. I should mention that I had to zip tie the relays to the bracket, due to them being smaller, but it wasn't that big of deal. Remember, I still have the 6 volt components, that go with the car, so I didn't want to alter anything. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Aug 21, 2014 7:18 am Post subject: |
Bobnotch wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
Bobnotch wrote: |
Ok, so you're using the 67 only (12 volt variable speed) wiper motor? And not the 2 speed unit? If so, then it's just plug and play. If you have a 2 speed motor (68 to 70), then you'll need to add a 2 speed switch. |
Yes. 67 only wiper motor. I figured it's the easiest way to go if I have to pull the 6 volt motor out. |
Posted: Thu Aug 21, 2014 9:27 am Post subject: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
Bobnotch wrote: |
It goes in the power supply wire to the wiper switch. That's it- no other changes. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Posted: Thu Aug 21, 2014 9:28 am Post subject: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
Bobnotch wrote: |
It goes in the power supply wire to the wiper switch. That's it- no other changes. |
Hmmm...might be worth a try for $15.  |
Posted: Thu Aug 21, 2014 10:02 am Post subject: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
Bobnotch wrote: |
Sure beats performing actual work in my book! Screw it to the firewall up under the dash- and if you really want to over engineer it, mount it to a heat sink first. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Posted: Thu Aug 21, 2014 10:08 am Post subject: |
I used this style on my Bug, and really liked it. You can adjust the speed down to really slow, if it's just drizzling...
Posted: Thu Aug 21, 2014 11:29 am Post subject: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
Tram wrote: |
ataraxia wrote: |
ron smith wrote: |
Bobnotch wrote: |
Sure beats performing actual work in my book! Screw it to the firewall up under the dash- and if you really want to over engineer it, mount it to a heat sink first. |
If he's using the 12 volt single speed wiper motor, then he shouldn't need to install a voltage drop, should he? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
