Slow 1200 Samba Member
Posted: Tue Dec 16, 2014 9:27 am Post subject: Anyone got a source for properly sized idle-cut off solenoid |
All the vendors have the Beetle one which is a G55 jet, while 99% of type 3s need a G50 idle jet for the PDSITs, I have regular jets in there right now, but I was wondering if anyone makes them? |
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 634 Location: Boston Metro West
Posted: Wed Dec 17, 2014 3:12 am Post subject: |
yep, that's the part number, seems like it might also be 058.129.412A |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17974 Location: Eugene, OR
Posted: Wed Dec 17, 2014 7:56 am Post subject: |
I don't see any numbers on my solenoids? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
tanhis Samba Member
Joined: July 23, 2005 Posts: 655 Location: Rauma Finland
Posted: Wed Dec 17, 2014 11:34 pm Post subject: |
You also need to check that the solenoid does not hit the acc pump cover. As some solenoids are not long enough for pdsit.
_________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Nov 18, 2018 8:32 pm Post subject: Re: Anyone got a source for properly sized idle-cut off solenoid |
I'm helping a friend look for them same solenoid -- g50 for twin 32PDSITs on his 68 T3.
Have only come across g45 and g55. What would the impact be of running either one of them instead?
Slightly richer or leaner idle?
Can the g45 be drilled to g50? _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Posted: Sun Nov 18, 2018 11:43 pm Post subject: Re: Anyone got a source for properly sized idle-cut off solenoid |
We just robbed a solenoid off of a Beetle engine & it worked fine on my '67 square dual Solex's.
We didn't spend months searching for the absolutely correct solenoid! _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Mon Nov 19, 2018 5:02 am Post subject: Re: Anyone got a source for properly sized idle-cut off solenoid |
bnam wrote: |
Can the g45 be drilled to g50? |
There are old style electric cut off solenoids that are two piece and the jet part is removable and I suppose one could ream it out..I have never reamed idle jets. The fixed idle jets (non solenoid type) have a check ball and cannot be drilled out. I have all types and can add some pictures for reference later on.
-Lucas
*EDIT
look at this ad
https://www.thesamba.com/vw/classifieds/detail.php?id=2038881
the silver ones are two piece and the jets can be swapped. the goldish colored pair are fixed and cannot be swapped. He appears to have 6v .50's and you could take the jets from those and put them on a 12v solenoid with ease.
I would just run a .55 myself and have had to go up jets sizes on pretty much all my cars due to crap fuels available these days perhaps
good luck! _________________ 1964 Notchback
1966 Squareback
1969 Type 34 Ghia
1969 Fastback
1989 Doka AFN TDI |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22435 Location: Kimball, Mi
Posted: Mon Nov 19, 2018 2:19 pm Post subject: Re: Anyone got a source for properly sized idle-cut off solenoid |
EasternNotch wrote: |
bnam wrote: |
-Lucas
*EDIT
look at this ad
good luck! |
Good point on today's fuels. Back when I ran the electro magnetic valves, I had g45's in mine, but back then the fuel was better. I'm running mechanical g50's in mine on the same carbs. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
