mack00 Samba Member
Joined: October 28, 2005 Posts: 173 Location: marietta georgia usa
Posted: Mon Feb 02, 2015 3:11 pm Post subject: Subaru conversion fuel pump? |
Installing a 2.5 in an early bay window. Are you guys using the stock vanagon pump? Or should I be looking for a different setup? Thanks |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Mon Feb 02, 2015 3:14 pm Post subject: |
The stock vanagon pump works fine for my 2.5L Subi conversion in our 84 Westy. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Mon Feb 02, 2015 3:31 pm Post subject: |
I thought early bay vans were carbureted with mechanical fuel pump. My '73 Westfalia was. Anyway, the stock 1986 Vanagon fuel pump has worked fine for my 3.3 litre EG 33 conversion. _________________ '86 Syncro Westy SVX |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17163 Location: Retired South Florida
Posted: Tue Feb 03, 2015 8:53 am Post subject: |
What year bay? FI bay, you could use the Bay Pump. If your bay is carbed, then you will need to add a return fitting to your tank. Since you are in the process of converting a bay to Subaru power, you might find fuel pumps from the aftermarket for a more reasonable price and have some higher availability. There is nothing special about the Vanagon fuel pump. You need to look at the volume requirements. Pressure should not be an issue with any pump that supports EFI injection. Sounds like a nice ride. Look over at Summit Racing, or Autozone. _________________ ☮️ |
mack00 Samba Member
Posted: Tue Feb 03, 2015 2:44 pm Post subject: |
It's a 69 single cab. Was carbed. I'll add return line to the filler neck.
Was leaning towards the Vanagon Bosch pump because they seem to have good reliability. But they do come at a cost.
Who is the go to vendor for these pumps?
Another option at a big price.
http://www.summitracing.com/parts/aei-18689/overview/ |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Wed Feb 04, 2015 1:33 pm Post subject: |
Ideally the return would return under the fuel level. When it returns to an airspace it does get aerated some. _________________ ☮️ |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Wed Feb 04, 2015 2:57 pm Post subject: |
Rather than add a return, put a tee under the tank outlet and run a '90 Cabriolet fuel filter (holds about a quart IIRC) between the tee and fuel pump inlet to act as a swirl pot. People have been using a tee to handle the return line on FI-converted early Bays for years without issue. |
