Diesel: GoWesty’s radiator baffles installation
Gnarlodious
Gnarlodious is offline
PostPosted: Sat Jun 06, 2015 7:24 am    Post subject: Diesel: GoWesty’s radiator baffles installation Reply with quote
I got the Radiator Baffle Set from GoWesty to get more air through my radiator, as the old ones were pretty much deteriorated. As of this writing, the page says this in red lettering:
Fit notes: This kit fits all watercooled Vanagon vehicles. Basically, if your Vanagon has a radiator, this product is for you.
GoWesty has informed me that this misleading language will be removed.
I am still not sure if the diesel radiator (1983½ model) mount system is different from the gas engined model, hence this post. I’m hoping to learn something here.
Pictured is the baffle on the passenger side lower, it was easy and turned out good:
I had to forcibly bend the plastic and tuck it into a groove between the radiator core and the tank. It may or may not stay there but I'll keep an eye on it. If I had not done this the flap would have covered too much of the radiator, in my opinion. This may be due to the larger radiator on the ’83 diesel, but I am not sure.
Doing the same thing on the driver's side, except the temp sensor prevents a good solid seating of the plastic:
The upper passenger side looked like this floppy arrangement, with no way to attach it:
On my Vanagon the wiring conduit is fastened to the crossmember and so the cutouts shown are unused.
Because I don't know how this is supposed to attach on a "normal" Vanagon, here is what it looks like on the '83 diesel:
I am pretty sure that driving under hot circumstances would cause this piece to flop over, since it is not fastened at the top.
Another angle from below:
I cut it back far enough to tuck it under the metal, which holds it tightly against the radiator tank:
I had to forcibly bend a perforated crease in the plastic to get it behind the top crossmember. I don't know how this will hold up so I'll check it in the hot weather.
The driver's side is an even bigger problem due to the side tank lacking the bleed screw, which doesn't leave anything to press against:
I am going to leave this piece flapping in the hot breeze until I figure out how to fasten it down. I have no clue how these are supposed to be attached on a "normal" Vanagon.
CAUTION! if you fasten the rivet tabs as they come from the factory you will damage them!
Notice the acute angle that applied too much tension on the rivet-downs and cracked the scored plastic at its fold. I then figured out what was wrong and bent the tabs the opposite way from how they came.
The plastic is not terribly flexible and is easily damaged by bending it too much. No instructions were included, so I naturally assumed they came from the factory with the tabs bent in the direction they are riveted down. DON’T MAKE THE MISTAKE I DID!
I then bent them them backwards, like this (passenger side):
The remains of the old paper baffle under the rivet told me that is how VW instlled the baffle too, the tabs were bend to the inside on the diesel.
GoWesty assured me that the exact same piece was installed on all watercooled models, so what gives? I believe that the high capacity radiator on the '83½ diesel has thicker side tanks and may have a larger surface area. The original fiberboard baffles were way more flexible than these plastic ones, so the same part was used despite their poor fit. The only difference being the direction the rivetdown tabs were bent upon installation.
Any observations will be appreciated.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sat Jun 06, 2015 8:00 am    Post subject: Reply with quote
Trim, adapt to fit properly would be the smartest thing to do.
I know they said it would fit all water cooled models--they obviously didn't take your diesel into consideration.
It's a make them fit kinda deal, or send them back and have nothing.
T.K.
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Sat Jun 06, 2015 7:12 pm    Post subject: Reply with quote
I'm interested in this as I'll soon be installing a new radiator in my 1983 diesel Vanagon, and plan to replace the baffles at the same time.
What do you mean by "high capacity"? Compared to the 1982 diesel, or compared to the 1983 gassers?
Several online vendors, including an actual VWoA dealer, list PN #068121253E (radiator) as fitting all 1983 models. Is there something unique to the diesel Vanagon radiator?
Gnarlodious
PostPosted: Sat Jun 06, 2015 7:27 pm    Post subject: Reply with quote
I am hoping someone more knowledgeable than me chimes in with the facts. What I have heard is that the early model diesel had a diesel radiator, but the later model starting with the ’83½ model had a higher capacity cooling system. This included a pressure tank with a larger outlet at the top, level sensor, different hoses, two speed fan and a larger radiator. I’ve read that doing an upgrade to the later radiator is difficult due to different mounts. So yes, the later radiator is physically larger and has a higher cooling capacity.
?Waldo?
?Waldo? is offline
PostPosted: Sat Jun 06, 2015 8:09 pm    Post subject: Reply with quote
'83 diesel radiator is the same as WBX.
vanis13
vanis13 is offline
PostPosted: Sat Jun 06, 2015 9:45 pm    Post subject: Reply with quote
Terry Kay wrote:
or send them back and .....
...make your own
Just made some from coroplast (plastic cardboard) bending is easy with that stuff.
http://www.thesamba.com/vw/forum/viewtopic.php?p=7630228#7630228
Gnarlodious
PostPosted: Sat Jul 11, 2015 4:50 pm    Post subject: More discussions about this part Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=591425
http://www.thesamba.com/vw/forum/viewtopic.php?t=632252
JackE
JackE is offline
PostPosted: Tue Aug 06, 2019 5:01 am    Post subject: Re: Diesel: GoWesty’s radiator baffles installation Reply with quote
Hi I just wondered if anyone has a copy of the pdf templates as the link above doesn't seem to work any more.
Many thanks
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Aug 06, 2019 8:38 am    Post subject: Re: Diesel: GoWesty’s radiator baffles installation Reply with quote
PM vanis13.
That user just logged in yesterday......
ZsZ
ZsZ is offline
PostPosted: Tue Aug 06, 2019 9:46 am    Post subject: Re: Diesel: GoWesty’s radiator baffles installation Reply with quote
I downloaded all the files before: https://www.dropbox.com/sh/jverdl3rbitnzuj/AAAizIU2DUijFPBIINtWf7mHa?dl=0
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
