jehlan Samba Member
Posted: Tue Sep 19, 2023 1:28 pm Post subject: New Wiring Harness CANT FIND HORN HOOKUP in column |
So all new wiring installed all OK after much trouble shooting except
Cant find where to put Horn Ground wire into the column. Wiring diagram shows 2 brown wires coming from column, one for the hi/lo beam But I see no 2nd brown in the column harness. (there are 3 separate plugnconnectors going into column all wires appear used up)
My steering wheel has a black wire going into column housing.
Any ideas?
Thanks |
Semper_Dad Samba Member
Posted: Tue Sep 19, 2023 5:23 pm Post subject: Re: New Wiring Harness CANT FIND HORN HOOKUP in column |
Ground path is through the steering column itself. There's a jumper wire across the steering coupler that takes it to horn ring under the wheel. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
jehlan Samba Member
Posted: Wed Sep 20, 2023 6:29 am Post subject: Re: New Wiring Harness CANT FIND HORN HOOKUP in column |
i got that. The brown ground wire from the horn comes up in the firewall. If I touch it to the horn contacts in the steering wheel I get my Beep beep!
I cant figure where to connect this to. The multi connector for the turnswitch harness? I bought all my new wiring from the Thing Shop
Maybe I am missing a pin? The harness has unused slots (but no unused pins)
ncpi Samba Member
Posted: Mon Nov 27, 2023 7:42 am Post subject: Re: New Wiring Harness CANT FIND HORN HOOKUP in column |
I am having the exact same problem. I also have The Thing Shop harness. Did you solve it?
If I can find a pinout of the steering wheel connectors, I know we are looking for "-S"
Thanks,
Bill |
ncpi Samba Member
Posted: Mon Nov 27, 2023 3:50 pm Post subject: Re: New Wiring Harness CANT FIND HORN HOOKUP in column |
Figured it out from my old wiring harness. The open position next to the brown-wht is where the horn wire goes. There is an wire (brown with black sheath) included in the stack of wires that really should have that been preinstalled in that harness. It has a small female spade on on end and a large male spade on the other end. Use a connector housing to connect to the brown wire in the front harness.
...Bill |
Posted: Mon Nov 27, 2023 7:54 pm Post subject: Re: New Wiring Harness CANT FIND HORN HOOKUP in column |
The horn's brown wire was included in the front wire harness when I rewired my car. Took a photo inquiring about another issue (light blue wire).
I now remember having to install the other end (small female connector) into the dash connector.
Leg 1 was for the Driver's side headlight bucket
Leg 2 was for the Passenger side headlight bucket
Leg 3 You see 3 wires. Brown, Yellow/Black, and Light Blue). I'm surprised it wasn't included in your front harness like mine. I believe it is NOT connected to the dash connector because the front harness and dash harnesses are sold separately.
BTW, The light blue wire is not documented in any wiring diagram. It is considered "extra". I reworked it into powering up an electrical washer pump.
Leg 4 connected to the Frunk's Ground lug _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
ncpi Samba Member
Posted: Tue Nov 28, 2023 5:43 am Post subject: Re: New Wiring Harness CANT FIND HORN HOOKUP in column |
Leg 3 was included in my front harness but it is the end that goes to the horn itself. It is the other end of the front harness that has to connect under the dash to a brown wire that is included in the instrument wiring package but NOT preinstalled into the steering wheel connector. That wire not being preinstalled was causing the confusion. |
KChallener Samba Member
Posted: Mon Jan 15, 2024 6:40 am Post subject: Re: New Wiring Harness CANT FIND HORN HOOKUP in column |
Last wire for my 1974 is the horn. Harness from The Thing Shop. I installed the wire in the harness as noted in pictures above. If I use the brown to the harness the horn is on at all times. If I use the light blue wire the horn works great. Where is the brown grounding so the horn is always "on"? Also, the left front of my Thing was damage at one time and the fender, quarter, and parts of the front plate were replaced. Where does the horn wire exit the Frunk? Picture would be helpful (also where does it travel underside?
Ken _________________ 1976 Bay, 1974 Thing, 1979 Vert Bug, 1973 Super, 1968 Beetle, 1967 split Brazilian Kombi |
