1969 Ghia Engine seal to tin
jhraider
jhraider is offline
PostPosted: Fri Mar 15, 2024 11:34 am    Post subject: 1969 Ghia Engine seal to tin Reply with quote
I had a mechanic install a new seal, there is a gap near the engine pulley. Could the seal be upside down or the wrong seal?
Thanks for any help, the engine is a H-engine
Thanks for any help
jeffrey8164 Premium Member
jeffrey8164 is offline
PostPosted: Fri Mar 15, 2024 12:37 pm    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
Should be one piece.
Volkswagen!
(Compression 8.7:1)
Marcdeb
Marcdeb is offline
PostPosted: Fri Mar 15, 2024 1:38 pm    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
There is 2 different type seals, earlier and later. Either one could be used if your not concerned about correctness. 67/68 is when they updated to the later style. If you could post a few photos, it would be much easier to figure out what's going on.
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
sputnick60
sputnick60 is offline
PostPosted: Fri Mar 15, 2024 4:47 pm    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
Looks like that's the later seal and it isn't seated correctly. My understanding is the seals supposed to lay over the engine tin, especially so for the early style with two "tongues". One above and one below the tin.
This diagram from Buzz Bug VW Parts , a local supplier here in New Zealand, shows how they fit in a Beetle which is the same as a Karmann as far as the engine surround goes.
What you show looks like the later "S" shape which I think it needs to be pulled up to sit up over the lid a bit more and so it hooks to the folded edge of the tin
There are some comments about the two types in this thread.. https://www.thesamba.com/vw/forum/viewtopic.php?t=724525 .. where they talk about mixing the early and old seals on early and late cars.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
jhraider
jhraider is offline
PostPosted: Sun Mar 17, 2024 9:01 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
I have a photo before the transmission removed and engine is sealing properly
gatordub
gatordub is offline
PostPosted: Sun Mar 17, 2024 9:33 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
I had the same issue with my 67. I installed the correct seal and had an air gap near the crank pully. All of my tins are original so that shouldn't be an issue. I sent it back to the retailer and received a different manufacturers seal. Still a huge air gap. I ended up installing a Type 4 foam seal. It's not factory correct but seals much better than the factory rubber seal. It's also easy to install and remove as needed.
jhraider
jhraider is offline
PostPosted: Mon Mar 18, 2024 8:55 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
Thanks
gatordub
gatordub is offline
PostPosted: Mon Mar 18, 2024 11:00 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
Sorry, don't want to confuse anyone.. it was a Type 4 seal.
Product link is below.
https://www2.cip1.com/vwc-411-813-225/
Era Vulgaris
Era Vulgaris is offline
PostPosted: Mon Mar 18, 2024 11:08 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
Maybe try the early seal. It sticks straight out and would likely cover that gap. Pic is of a '68 from the gallery. '68 had the same H5 engine as '69.
Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue
jhraider
jhraider is offline
PostPosted: Mon Mar 18, 2024 2:06 pm    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
I have a photo of before and the tin was next to the seal.
sputnick60
PostPosted: Tue Mar 19, 2024 2:48 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
So what is it about the previous answers that keeps you looping with the same question? Is it time to talk to the people who created your the problem? You have by now everything there is to know about these seals. You'll be well informed going in.
Nicholas.
jhraider
jhraider is offline
PostPosted: Tue Mar 19, 2024 10:04 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
I did yesterday afternoon; I wanted to try and get the most answers and knowledge just in case one of you had the solution before talking to him!
sputnick60
PostPosted: Wed Mar 20, 2024 12:06 am    Post subject: Re: 1969 Ghia Engine seal to tin Reply with quote
So how did it go? Did you get and answer out of him?
Nicholas
