max_h Samba Member
Joined: February 16, 2022 Posts: 25 Location: Seattle
Posted: Fri Mar 15, 2024 11:35 pm Post subject: Missing nut on automatic transmission (also, what part is this?) |
I'm taking inventory of issues on a new '86 Vanagon 2wd A/T project and noticed this new-looking bolt with no nut on it. My questions are:
1) What is the thing it's securing to the transmission?
2) Anybody know the size/torque spec offhand?
Thanks!
[/img] |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6368 Location: Honolulu,Hawaii and France
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32659 Location: Reading Pennsylvania
max_h Samba Member
Posted: Sat Mar 16, 2024 9:05 am Post subject: Re: Missing nut on automatic transmission (also, what part is this?) |
Copy that. Thanks! |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1040 Location: san diego
Posted: Sat Mar 16, 2024 2:27 pm Post subject: Re: Missing nut on automatic transmission (also, what part is this?) |
firstly the thread on that is M10x1.5mm
secondly there is ZERO harm in leaving the bolt the length that it is, IF you are in the rust belt, and it corrodes badly, you may have an issue getting out if and when needed.
thirdly there's a thread on adding a ground wire to a subaru starter, if you grind the area around where that stud pokes through, it's a good spot for a ground wire, l've added starter grounds that way on a few vans now. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 675 Location: Santa Cruz, CA
Posted: Mon Mar 18, 2024 11:45 am Post subject: Re: Missing nut on automatic transmission (also, what part is this?) |
djkeev wrote: |
markswagen wrote: |
thirdly there's a thread on adding a ground wire to a subaru starter, if you grind the area around where that stud pokes through, it's a good spot for a ground wire, l've added starter grounds that way on a few vans now. |
Yeah......I was looking at where that bolt would protrude this morning thinking that exact thing, what a great place to put a ground cable.
I may just get a longer bolt and washer and nut....... |
That’s a great idea. While you’re at it, add a positive cable from the starter and shielded post for jump starting from the rear. _________________ 1991 tin top GL
Some BMWs. |
