It liiiiiiiiiiiiiivesssss
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Mar 25, 2024 6:13 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
steve244 wrote:
Since our cam and hydraulic lifters bathe in oil it's not needed.
you really have no idea do you smuggles?
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Wildthings
Wildthings is offline
PostPosted: Mon Mar 25, 2024 6:47 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
steve244 wrote:
Nope. Show me a reference for that and I'll read it.
Running at 2000 to splash lube the cam in an American OHV V8 is a thing. Since our cam and hydraulic lifters bathe in oil it's not needed. Just seating the rings and normal operation for 400 miles.
I will be putting wheels on the road and running it under load to seat the rings.
Here's a vid of it running just now.
Sounds to me like you may have an exhaust valve that isn't closing, maybe check your valve adjustment again.
E1
E1 is offline
PostPosted: Mon Mar 25, 2024 7:22 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
steve244 wrote:
I’ve never fired one of these up after a rebuild, but that’s a lot of valve noise.
Beautiful install, Enjoy. Cool
‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
steve244
steve244 is offline
PostPosted: Tue Mar 26, 2024 5:55 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Xevin wrote:
I pulled that out of my ass to make your life miserable. I thought you were working with a small block Chevy. WTF?
Buy a book FFS. Or listen to someone other then yourself. The kids like to text GFY.
That's not helpful, xevin.
Asking loaded questions without providing any useful information. Then posting derogatory gifs, after given an answer. Then doubling down with insults when asked a question. Finally ending with GFY?
Go sit in the corner.
82 AC vanagon approx 200K miles (3K are mine).
DD is a 2015 Leaf Twisted Evil
Road Trip to Hell (FL 2023)
The Vanagon's drivetrain and chassis restomod thread. Best sung to the tune of I Did It My Way...
steve244
steve244 is offline
PostPosted: Tue Mar 26, 2024 6:03 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
It's not my build, but it sounds lumpy to me too. I'll run a compression test for reference while I have the air box out. Rebuilt AFM arriving today. I'll also move the O2 sensor to the bung away from the tailpipe. I think it's sniffing outside air at idle.
Thanks.
Xevin Premium Member
Xevin is offline
PostPosted: Tue Mar 26, 2024 6:22 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
You are the expert and already know a 20 minute “Run-in” is not necessary and only needed on “American OHV V8s.” Why would I share the pages of the Book I suggested you read? I was going to offer you an assortment of gear to experiment with, like I did for Brock but you just don’t listen. You do you. I actually like to be helpful.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
steve244
steve244 is offline
PostPosted: Tue Mar 26, 2024 6:25 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Thanks xevin. I'm sure I'll have 20 minutes at temperature on the clock before wheels down.
Xevin is offline
PostPosted: Tue Mar 26, 2024 8:17 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
You should post your Cam break in procedure in the Performance/engine/transmission forum for validation.
This would be a good one to post in. Report back Brothers procedure too. Would be nice to grab their recommendation as well.
That’s a nice engine you have. Best practices can very but some are better then others.
Keep on Busin'
SGKent wrote:
BDorsey
BDorsey is offline
PostPosted: Tue Mar 26, 2024 1:07 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
I have a rebuilt long block from Brothers (1 year old) and when I picked it up they told me it was broken-in. 20 minutes at 2000 rpm to harden the cam lobes. I expect this is their standard procedure.
Hope this helps.
Brian
1982 2.0L Aircooled Country Homes Camper
Xevin is offline
PostPosted: Tue Mar 26, 2024 1:32 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Hope this helps.
Brian
steve244 wrote:
Xevin wrote:
Did Brothers do an initial break-in for 20 minutes before they shipped the crate to you? I gotta think they did.
I don't think so. It appeared to only have assembly lube. No discoloration to exhaust ports.
I'm breaking it in as if it's not been run. Break-in oil (Driven BR30). Change after 30 minutes of running. Change to normal oil after 400 miles.
Great information Brian. I called them this afternoon and they confirmed they do a 20 min run-in on each engine even when shipping across country and the owner only thinks it’s necessary on American muscle cars Wink
Was that helpful Steve?
Keep on Busin'
SGKent wrote:
steve244
steve244 is offline
PostPosted: Tue Mar 26, 2024 1:41 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Thanks Brian. That's good information. Mine was purchased in April 22 and may have sat on their shelf for a while. It's straight stock. Did you get any upgrades?
Xevin. If you want to be helpful, stop asking loaded questions without providing any context. Your book excerpt was helpful. Try opening with that and the suggestion that if not done by the builder, you may want to follow these guidelines.
Today the rebuilt AFM by Fuel Injection Corp arrived before noon. Ordered yesterday from bus depot. $200 plus core. I also moved the AFR meter's O2 sensor away from the tailpipe. This corrected its reading.
It came alive with this and then dialed in nicely. Here's today's video. I think the lumpy exhaust by Vintage speed is by design. It's quieter above idle.
BDorsey
BDorsey is offline
PostPosted: Tue Mar 26, 2024 1:57 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Mine is stock as well. I finally have it running well (except for terrible gas mileage). I learned a ton about the FI system.
Can I ask if you hear a whine from the engine? I didn't hear one in your videos but mine has one and I can't tell what it is. Wondering if another Brothers' engine sounds the same. It doesn't sound like its the belt and it is definitely not in the transaxle because I happens with the clutch depressed. It almost sounds like a straight cut cam (I only recently learned this was a thing) but that is not likely it in a stock engine.
I don't mean to hijack this thread, just a quick yes/no on the whine would be helpful.
Thanks
Brian[/img]
steve244
steve244 is offline
PostPosted: Tue Mar 26, 2024 2:27 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Yeah, there is a medium pitch whine. I just figured it's new tight gears either for the cam, distributor, or oil pump. Or all the above. It sounds good to me. At about one minute you can hear it at full whine.
What's terrible mileage? They only get about 17 mpg on a good day.
BDorsey
BDorsey is offline
PostPosted: Tue Mar 26, 2024 2:56 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Thanks! That is a relief to hear. I imagined it might be new gears but I had no real idea if that was reasonable and ok, or if it was cause for alarm.
I am getting about 12 mpg - mostly in town but even on the one long shakedown trip we've taken it was about the same. I have a rebuilt AFM and all FI components have been verified 4X. But, I do NOT trust the new TSII from my experience and all that I've read. Could be that even though it reads within specs. My other suspect is the fuel pressure regulator, which is just 1-2 PSI higher than spec. I don't know if that is enough out to be the cause though.
Anyway, I may start a thread about all that. Sorry to change the subject and thanks for the input Very Happy .
Brian
steve244
steve244 is offline
PostPosted: Wed Mar 27, 2024 9:00 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
How many miles on the new engine?
BDorsey
BDorsey is offline
PostPosted: Wed Mar 27, 2024 8:50 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Just under 3000 miles.
steve244
steve244 is offline
PostPosted: Thu Mar 28, 2024 5:35 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
I'd like to think mpg will improve after a few more thousand. Has it been smogged since replacement?
BDorsey
BDorsey is offline
PostPosted: Thu Mar 28, 2024 9:21 am    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
Yes, it passed smog just fine. I would love it if the mpg got better, but why would you expect that? Thanks.
Wildthings
PostPosted: Thu Mar 28, 2024 12:51 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
What is your gas mileage? Bread boxes aren't known for not sucking down fuel.
BDorsey
BDorsey is offline
PostPosted: Thu Mar 28, 2024 12:57 pm    Post subject: Re: It liiiiiiiiiiiiiivesssss Reply with quote
12-13 mpg
Page 3 of 4
