BugChit Samba Member
Posted: Wed Jun 12, 2013 5:23 am Post subject: Recommended Diesel Gearing? |
Trying to pull all my thoughts together and est cost for my anticipated 1.9TD Build..
So it brings me to the Trans Gearing Question.
It is a 2WD Manual Van
If I was starting from scratch, which Trans gearing Package should I consider.. My tire size is approx. 25" tall.
I have a few 091 4 spds, that I can use as donors, just not sure what is the preferred R&P and Best 1st-4th gear selection.. One thing I do know is I'd prefer a .70 or .77 4th wish I could go even lower then .70 to get the best fuel mileage I could.
OK, all You Gear Heads... Your Thoughts
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10124 Location: Where?
Posted: Wed Jun 12, 2013 5:51 am Post subject: |
| Are you planning a 1.9TDI build or 1.9TD? The difference is very pertinent to gearing. The 1.9TDI engines do not like to rev as high as the 1.9TD (AAZ) engine whereas the 1.9TD (AAZ) does not have as much low-end torque. |
svenakela Samba Member
Posted: Wed Jun 12, 2013 6:04 am Post subject: |
I would say, if you are going to use a stock tranny the AAP is the best choice whatever diesel you choose. I even had one in my standard 1.6TD before. very nice combination.
If you're willing to rebuild, it's a totally different story. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10462 Location: Orbiting San Diego
Posted: Wed Jun 12, 2013 6:17 am Post subject: |
We never got the AAP over here. Nothing even close
For 1.9TD use the stock waterboxer tranny, add larger tires
Mark
| svenakela wrote: |
| BugChit wrote: |
| Trying to pull all my thoughts together and est cost for my anticipated 1.9TD Build...... |
Posted: Wed Jun 12, 2013 7:26 am Post subject: |
| Andrew A. Libby wrote: |
It's a 1.9 tdi engine code AHU....
Oh-ooooo and looking to build the proper Gear Box. Do it once and hopefully get it right the 1st time.
I realize I can always go with taller tires, but not a fan of Raised tall tires if possible i'd like to keep things low.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19065 Location: Retired South Florida
Posted: Wed Jun 12, 2013 8:50 am Post subject: |
For my TDI powered vanagon.
Stage 1 transmission from an aircooled Vanagon. Stock 4.57 ring and pinion. Stock gearing
Stage 2 215/65/16 tires. Good for a 200 rpm drop
Stage 3 Custom built transmission from later WBX vanagon with 4.14 ring and pinion, .77 4th gear.
Stage 4 Ended up too tall for long uphill grinds, had to add larger nozzles. Gearing ideal now.
The ALH TDi makes max torque at 2200 rpm stock and max hp at 3800 rpm. I can cruise easy at 70 mph at around 2900 rpm with the above setup. Fuel economy really suffers on the TDI above 2400 rpm. Plan accordingly. The nice thing about upgrading the ring and pinion is all the gears are improved. |
Jon_slider Samba Member
Posted: Wed Jun 12, 2013 10:45 am Post subject: |
rsxsr is using a 27" tire with a 4.14 ring and pinion and a .77 4th. I agree with that combination, and would also suggest a 1.14 3rd.
Then you will need to change ring and pinion like rsxsr, even if you don't match his tire size and stay with your 25" tire (what is the exact tire you are using, I would confirm that dimension)
So for your 25" tire I recommend a 4.14 ring and pinion, and change to a 1.14 3rd and a .77 4th.
You could later go to a 27" tire like rsxsr if you find the gearing too short with your tire size, but the gear spacing and ring and pinion would not need to be changed again, IF you use a 4.14 ring and pinion.
IF you were willing to go to a 28" tire, you would not need to change your 4.86 ring and pinion, and then I would recommend a 1.88 2nd, 1.08 3rd, .7 4th (however a 1.88 is very difficult to obtain)
Your choice of tire size, determines whether you need to change ring and pinion. And your choice of ring and pinion, determines what 3rd and 4th gear to use.
I think you are making a mistake trying to run a 25" tire on a TDi, and I think changing ring and pinion is an unnecessary expense, IF you can accept that a 28" tire is a better choice for a Diesel. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Wed Jun 12, 2013 11:28 am Post subject: |
| With those tyres, the absolutely lowest Ring and pinion you can get and a stock Diesel 5 speed tranny. |
Posted: Wed Jun 12, 2013 11:39 am Post subject: |
The 1.88 2nd was a rare Syncro gearing variation AFAIK. 1st and 2nd gears are machined into the mainshaft. The mainshaft of a 2wd is different than that of a Syncro. I don't think you can get even near to a 1.88 2nd in a 2wd tranny without screwing up 1st gear too tall.
Mark
| Jon_slider wrote: |
jimeg Samba Member
Posted: Sat Sep 28, 2013 8:34 am Post subject: |
Going to install an AAZ in my Syncro. I would like run 195/75 - 16 tires. Do I need to re-gear my trans, or run a different tire size than this? _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490
outwesty Samba Member
Joined: June 06, 2006 Posts: 1078 Location: Northern Sierras
Posted: Sat Sep 28, 2013 9:35 am Post subject: |
If you are going to chip tune and add injectors on the AHU I'd do a 1.14 3rd and a 0.70 4th and stock R&P....I run 215 70 16 tires and I think its about perfect. Just yesterday I did donner pass with the cruise on at 73 no problem. If you run any larger tires than that I would not do the .70 4th. At 3000 RPMS's I'm at 72 MPH.
That is about a 755 rev/mile tire. I consider that about right for taller tires with a stock AAZ and stock US Syncro tranny. I have run that tire/gearing combo with AAZs for many years.
195/75/16 is not a very common size. I guess you are planning Nokians?
Mark
| jimeg wrote: |
| Going to install an AAZ in my Syncro. I would like run 195/75 - 16 tires. Do I need to re-gear my trans, or run a different tire size Han this? |
jimeg Samba Member
Posted: Sat Sep 28, 2013 10:09 am Post subject: |
| crazyvwvanman wrote: |
Mark
| jimeg wrote: |
Yes. Nokians. Exactly. I like the taller/narrower look - more classic VW looking. Plus better snow performance.
That is great to hear. I can just get away with the tire/wheel change and no gearing modifications.
Also. I don't think I intend to "chip" of tweak the engine much. Just want to get up the mountain passes as the speed limit. Don't need to be that quick, mostly efficient and long lasting. I still have some more to learn about this engine though. Waiting on a few more parts to arrive from the seller, then I can make a full assessment and plan.
Thanks! _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Posted: Sat Sep 28, 2013 10:27 am Post subject: |
no problem, as long as the speed limit is 58mph, which is what you will be doing at 3000rpm in 4th with a stock box and those tires.
You can always regear later if you dont like the stock gearing.
I believe hans j is currently running a stock tranny with a TDi, he goes offroad a lot, maybe touch base with him. I dont think he cares about going on the freeway. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Sat Sep 28, 2013 11:21 am Post subject: |
If it is a fairly stock AAZ he won't be doing 58 up many mountain passes in 4th. Maybe if he put a 5.43 r&p.
Mark |
jimeg Samba Member
Posted: Sat Sep 28, 2013 12:36 pm Post subject: |
Sounds like I might have the cart before the horse here. Not sure on the build, yet. I'll get that sorted first then. Thanks. _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490 |
jimeg Samba Member
Posted: Sat Sep 28, 2013 2:19 pm Post subject: |
| Jon_slider wrote: |
I believe hans j is currently running a stock tranny with a TDi, he goes offroad a lot, maybe touch base with him. I dont think he cares about going on the freeway. |
Thanks. Is 3000 RPM the happy place for this motor? After reading your repsonse, i noted i am at 2500 RPM in my Sprinter at 60mph. I don't intend to spend much time "wheel'n". Mostly highway and back roads traveling around The Great Pacific Northwest and BC. _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Posted: Sun Sep 29, 2013 6:54 pm Post subject: |
[quote=
Thanks![/quote]
Just to let you know a chip in most cases increases your MPG's while adding a significant amount of power. I'm getting ready to do a second AHU Tdi swap and can't imagine not chipping it....its too easy not to and only $300 |
jimeg Samba Member
Posted: Sun Sep 29, 2013 7:15 pm Post subject: |
| outwesty wrote: |
[quote=
Thanks! |
Just to let you know a chip in most cases increases your MPG's while adding a significant amount of power. I'm getting ready to do a second AHU Tdi swap and can't imagine not chipping it....its too easy not to and only $300[/quote]
Thanks outwesty. I am still acquainting myself with my AAZ install, but I believe everything is mechanical so I can't chip mine. How are you sourcing your AHU's? _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Witless Joe Samba Member
Posted: Mon Sep 30, 2013 11:53 am Post subject: |
| jimeg wrote: |
| I am still acquainting myself with my AAZ install, but I believe everything is mechanical so I can't chip mine. |
Even if it's not "chipable", you can make some useful mods to the injection pump of an AAZ engine.
Here's a place where you can start to get a few ideas (translated from French a bit roughly):
http://www.vwdiesel.net/forum/index.php?topic=579.0 |
