Longer clutch arm
MURZI
MURZI is offline
PostPosted: Sat Aug 25, 2012 6:25 pm    Post subject: Longer clutch arm Reply with quote
I have to swap the tranny in my BAJA...no sure what happened Rolling Eyes Laughing Laughing Anyway while I am in there I am thinking of cutting the stock clutch arm and lengthening it to reduce pedal pressure. Does 100mm from center to center sound right...should I go longer?? Bruce???
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
mark tucker
mark tucker is offline
PostPosted: Sat Aug 25, 2012 9:31 pm    Post subject: Reply with quote
I have the 100 arm on mine it's great .and relubing the peddels&cable , new bowden,helped a lot too. I need a long one for my rino trans, but with the price jump on the long arms Ill just have to make one.
if you go longer you may not have enough peddel travel.
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Aug 25, 2012 10:10 pm    Post subject: Reply with quote
I got mine from Bruce. It's a great mod, esp. if you run a clutch heavier than stock. It eases the force required at the pedal, and also helps reduce stress on the cable and hook. I believe mine is a 100mm also.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
gprudenciop
gprudenciop is offline
PostPosted: Sat Aug 25, 2012 10:24 pm    Post subject: Reply with quote
I have a 100mm one that I just removed.you can have it if you want! Pm me address and its yours!!
Bruce
Bruce is offline
PostPosted: Sat Aug 25, 2012 11:29 pm    Post subject: Re: Longer clutch arm Reply with quote
Be brave, go longer. Measure the clearance between the tip of your existing one and the package tray. That's the limit for those that are afraid to use hammers.
mark tucker
PostPosted: Sun Aug 26, 2012 8:59 am    Post subject: Reply with quote
I had no issue with clearance but the cable bracket needs sloting so it can be adjusted for a better pulling angle with the longer arm.I had thought about making a pivoting bracket so it would fallow the arc and less wear of the bowden tube&cable.
chrisflstf
chrisflstf is offline
PostPosted: Sun Aug 26, 2012 9:06 am    Post subject: Reply with quote
Slotting the cable tube bracket only works on trans that have a removeable bracket. Most are cast into the side cover, in which case the cable will wear more at the top, due to the longer arm
mark tucker
PostPosted: Sun Aug 26, 2012 9:11 am    Post subject: Reply with quote
cut off the bracket & add longer studs and an irs type bracket.
mcmscott
mcmscott is offline
PostPosted: Mon Aug 27, 2012 8:57 am    Post subject: Reply with quote
This is what I did to the ghia. It has a long arm and a 1 inch torsion raise
yamaducci
yamaducci is offline
PostPosted: Mon Aug 27, 2012 10:45 am    Post subject: Reply with quote
AC.n sells a long arm as seen in my gallery. I just did the conversion .
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Oct 25, 2014 8:53 pm    Post subject: Reply with quote
back from the dead Laughing
just wondering, would extending the arm change the throw on the cross shaft/throw out bearing? I am thinking about doing a longer arm and was just wondering what (if any) consequences there may be
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Oct 25, 2014 9:14 pm    Post subject: Reply with quote
I installed mine about 4 years ago, zero negative effects what so ever. It does make a noticeable difference.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
modok
modok is offline
PostPosted: Sat Oct 25, 2014 9:18 pm    Post subject: Reply with quote
It does shorten the throw but with a good PP it's no problem.
I made an early one, 4", two welded together. Even put the holes in it cause I wanna be cool like Bruce.
With my 9-spring PP I could make it 6" long and still have enough travel.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Oct 25, 2014 9:22 pm    Post subject: Reply with quote
it is a kennedy stage 1 with a copperhead disk. any reason to worry? and what is the length overall? I keep seeing 100mm, but is that hole-to-hole or a overall measurement?
I have not been able to find out that tidbit of info
here is what I have
skills@eurocarsplus wrote:
copper head disk and hd p/p:
h/d cross shaft and bronze bushings:
Jake Raby wrote:
Brian wrote:
rs58rag
rs58rag is offline
PostPosted: Sat Oct 25, 2014 9:35 pm    Post subject: Reply with quote
100 mm long clutch arm = easier clutch pedal and release better timed and predictable with stage 1. Also, weld reinforce clutch tube behind ebrake handle and check welds at front and back of clutch tube.
modok
modok is offline
PostPosted: Sat Oct 25, 2014 11:01 pm    Post subject: Reply with quote
I think center to center. I'll check, guess what I'm doin tonight..........swappin transmission Mad
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Oct 26, 2014 6:03 am    Post subject: Reply with quote
that would be great! I would like to know as I may make one (have a bunch kicking around) but I have not checked the availability of them either.
some threads (old ones) mention that they were out of stock everywhere, but they were pretty old threads
Jake Raby wrote:
Brian wrote:
modok
modok is offline
PostPosted: Sun Oct 26, 2014 12:17 pm    Post subject: Reply with quote
I got:
1968-75mm
1975-100mm
One I lengthened-87mm
center to center
bluebus86
Banned
bluebus86 is offline
PostPosted: Sun Oct 26, 2014 12:59 pm    Post subject: Reply with quote
The longer arm will result in more peddle travel for a given throwout bearing travel. If the peddle travel is kept the same, the throwout bearing will move less.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Oct 26, 2014 2:06 pm    Post subject: Reply with quote
modok wrote:
I got:
1968-75mm
1975-100mm
center to center
thanks!
center to center being from the cross shaft hole to the wingnut hole, correct? I know the wingnut hole is a bit oval, that's why I ask.
I was also afraid if I made it too long that it may over extend the throw out bearing, messing with the pressure plate
Jake Raby wrote:
Brian wrote:
