DaveB9 Samba Member
Posted: Mon Apr 15, 2024 11:34 pm Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
obus that is a lovely selection of cars to choose from on a beautiful day!
On the glovebox buttons, the Beetle ones are the same up to 1967 - you have to push it in while the door needs to come the other way. I fitted an accessory locking handle to my Beetle, but the locking button on the Ghia convertible has no handle. I think the key will act as something to pull on when turned though. One option would be an EMPI style glovebox pull, but it does mean drilling two holes: https://www.thesamba.com/vw/classifieds/detail.php?id=2092042 |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3918 Location: In Molinya Orbit
Posted: Tue Apr 16, 2024 2:36 am Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
There should be two rubber bumpers in the lip of the glove box. Little conical shaped things apply a little bit of opening pressure against the lid and tensions the latch against the striker.
The striker hangs from the top of the opening in the form of a tongue of metal with a rectangular hole. This has to be "adjusted" so the latch hooks onto it when closing and releases it to open. The pressure from the rubber allow the door to open just enough so when the button is released the latch misses the striker and the lid continues to open. It took me weeks of fiddling to get it right.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Marcdeb Samba Member
Posted: Tue Apr 16, 2024 8:07 am Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
sputnick60 wrote: |
Nicholas |
That makes sense. I've played around with it several times in the past and have yet to find that perfect adjustment. In my case the hinges on the either side are not perfectly aligned (or bent) so they cause additional friction. The hinges also seem to be a very touchy adjustment. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
obus Samba Member
Joined: March 08, 2001 Posts: 11073 Location: just off Garden State Parkway Exit 81
Posted: Wed Apr 17, 2024 7:54 am Post subject: Re: 1960 Paprika Red Ghia in New Jersey "Schatze" |
sputnick60 wrote: |
Nicholas |
This is what i need to do!!! Thank you! Will fiddle with it next time i get out in the garage. _________________ July 1959 Mango Standard Bus aka Obus L346 L347 https://www.thesamba.com/vw/forum/viewtopic.php?t=256592&highlight=
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273 |
