honky Samba Member
Joined: August 10, 2006 Posts: 149 Location: Connecticut, USA
Posted: Thu Nov 02, 2006 7:26 am Post subject: hinge Pins |
I need to drill out and replace a couple of door hinge pins. Can anyone tell me what size the pins are and what size drill bit to use. ever see a write up on this here or anywhere. |
alg Samba Member
Joined: April 24, 2006 Posts: 134 Location: Webberville, TX
Posted: Thu Nov 02, 2006 7:51 am Post subject: |
there are a few threads here in the forum about this topic.
One of them in the last 2 or 3 months mentioned the pin sizes and a few clever items you can find at your home store that will work in a pinch.
Do some more searching in the forum and you should find the info. |
markie61 Samba Member
Joined: April 11, 2005 Posts: 583 Location: Northern Virginia
Posted: Thu Nov 02, 2006 8:19 am Post subject: |
alg wrote: |
Best and most recent http://www.thesamba.com/vw/forum/viewtopic.php?t=193630
Mark _________________ Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!? |
germansupplyscott Samba Member
Posted: Thu Nov 02, 2006 1:28 pm Post subject: |
i would not drill them - you will ruin the hinges. the pins are very hard.
they will press out. when i did this i used a sturdy large vice. support the hinge with a deep socket over the pin and use a very short drift - i think i used a short screwdriver bit - to do the pressing. the pin will get pressed into the socket. after it is mostly out you can drift it put the rest of the way. use a lot of heat - a small blowtorch will do. _________________ SL |
Ferretkona Samba Member
Joined: December 03, 2005 Posts: 1306 Location: Columbia, CA
Posted: Thu Nov 02, 2006 3:57 pm Post subject: |
If you can wait, I would order some new pins from The Thing Shop and use the new pin to drift out the old. |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22440 Location: Kimball, Mi
Posted: Thu Nov 02, 2006 6:05 pm Post subject: Re: hinge Pins |
honky wrote: |
I wouldn't drill them out either. I used a torch to warm the hinge area up (only burnt the paint on that part), and used a drift punch to knock it out of the hinge. I then used a 6mm reamer to clean up the pin part after it cooled. I think the stock pin size is actually 5mm in diameter. I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
honky Samba Member
Posted: Thu Nov 02, 2006 7:44 pm Post subject: Hinge |
did you have to knock out the pin stuck on the hinge that is welded to the car ? |
Posted: Thu Nov 02, 2006 11:20 pm Post subject: Re: Hinge |
honky wrote: |
The pin and the hinge are not welded to anything.
The door hinge is mounted with machine screws.
The door hinge pin is merely pressed in. |
kubelmann Samba Member
Posted: Fri Nov 03, 2006 6:06 am Post subject: |
I have an "ample" supply of door hinges available... K-mann |
