philvt101 Samba Member
Joined: May 01, 2011 Posts: 51 Location: Salisbury, MD
Posted: Tue May 10, 2011 1:09 pm Post subject: new Empi 34 PICT 3 leaking at throttle shaft bushings |
Just got a 74 Beetle and the PO had just put a "brand new" Empi 34 PICT 3 on. It would only idle with the choke on. Found the base gasket not even on right, half way out. I replace the gasket but still had the same problem. Found the throttle shaft bushings leaking, especially on the choke side. So I found some replacement bushes on eBay but they're listed for the Solex, I'm hoping they'll work. But has anyone seen a brand new Empi have this problem before? I know it's supposed to be common on carbs with some age to them, but that just doesn't sound right to me. And the carb does look brand new... |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32989 Location: Reading Pennsylvania
CHEVYJEFF Samba Member
Joined: July 22, 2009 Posts: 61 Location: WYLIE TEXAS
Posted: Tue May 10, 2011 1:22 pm Post subject: |
I have a new bocrap pict 34 that has same problem. sitting on shelf collecting dust. I think there is a balck gasket that goes on over throttle shaft between carb body and choke rod plate mine is missing.
I just rebuilt my old 30/31 and had not looked back |
Posted: Tue May 10, 2011 2:10 pm Post subject: |
Any recommendations on a good replacement carb for a 74 Beetle 1600cc dual port, center mount? |
cookrw Samba Member
Joined: June 09, 2009 Posts: 873 Location: Augusta, KY
Posted: Tue May 10, 2011 6:04 pm Post subject: |
What distributor do you have? _________________ '71 Super 'Vert
'84 Vanagon GL (w/ Sunroof!)
'96 Jeep Cherokee |
Joey Samba Member
Joined: August 12, 2005 Posts: 5376 Location: Nova Scotia - Canada
Posted: Tue May 10, 2011 6:52 pm Post subject: |
Rule # 2
Don't buy anything new with the word EMPI on it. EMPI = JUNK. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Gene Austin Samba Member
Joined: April 24, 2011 Posts: 72 Location: Marysville Washington
Posted: Tue May 10, 2011 7:31 pm Post subject: Me too |
I too have this carb if i could piggy back off this thread. i just bought a 034 SVDA distribuetor. what would be a good carb for this dist. i am having a stumble on acceleration problem and i think it is the EMPI carb ? |
Mikeys_Fasty Samba Member
Joined: September 21, 2006 Posts: 64 Location: Sutherland,VA
Posted: Tue May 10, 2011 7:37 pm Post subject: |
unfortunately the new carburetors that are produced are hit and miss when it comes to quality, more miss then hit. many of the mfgs use a nylon material for the bushings which simply do not hold up. I would suggest talking to Keith, username keifernet. he does rebushing and rebuilds on carbs and im sure he has some that are for sale or perhaps can correct the issues on your current carbs.
http://www.thesamba.com/vw/classifieds/detail.php?id=429441 _________________ '99 jetta GLS, '88 GTI 16v, '72 Super Beetle, '69 Fastback
bah bah bah bah bahhhh.... I'm VDubin it  |
Posted: Wed May 11, 2011 5:02 pm Post subject: |
Honestly I don't know which distributor I've got. I just got the car and aren't really familiar with the different distributors available. It has no vacuum advance, only mechanical. I assume (probably not a good idea) that it is the factory distributor.
Also, I didn't buy the Empi, the PO did. I'm thinking of buying a Mofoco replacement, and I can't really get Keith to rebuild one for me as I don't have the original Solex. |
Posted: Wed May 11, 2011 5:20 pm Post subject: |
ok. well like i said he may have one to sell already done, and will probably be cheaper then any of the repro's you'll snag. no vacuum advance means it's most likely an 009 (aftermarket). but if you were happy with it, no need to change it. be warned there are some strong opinions here on the use of the centrifugal advance(009) versus vacuum advance ( stock). both sides have valid arguments, but ultimately if you're happy with what you have, run it. _________________ '99 jetta GLS, '88 GTI 16v, '72 Super Beetle, '69 Fastback
Posted: Wed May 11, 2011 5:39 pm Post subject: |
I haven't even been able to drive the car yet. The faulty carb came on it when I bought it, so I don't know how the distributor will work out, but I've seen quite a few mentions of the "009 bog".
Do you have any idea how long it might take to get a carb from Keith? When I checked out his page, he gave the impression that it might be quite a while. I guess I should just ask him, right?
Anyway, thanks for the input. |
Posted: Wed May 11, 2011 5:52 pm Post subject: |
yeah, best to ask him directly. shhhh....don't use "009" and "bog" together.....you may stirr the beast.lol
if it appears keith can't help you, the next best source would be john at aircooled.net. but steer clear of the bocar, empi, bristol, "nonames". mofoco brand I've heard mixed reviews on, haven't had one from them myself so I can't say one way or the other. _________________ '99 jetta GLS, '88 GTI 16v, '72 Super Beetle, '69 Fastback
Big Hoss Samba Member
Posted: Wed May 11, 2011 6:00 pm Post subject: |
I talked to Paul,(email), today about MoFoCo's carbs. He says they are Chinese knock-offs. Even though they set them up for you on a running test motor, I still don't want anything "Made in China" on my bug if I can help it.  _________________ 70 & 77 Bugs, 71 & 72 Supers
Current bug:1970 |
Posted: Thu May 12, 2011 5:10 am Post subject: |
Big Hoss wrote: |
I still don't want anything "Made in China" on my bug if I can help it.  |
You better be selling that car then!! I'm not sure that you can accomplish such a thing in todays world without a LOT of work sourcing OEM parts from stray people and spending a lot of money doing it.
Keep in mind, not all Chinese products are crap. Granted many / most are and you need to educate yourself about quality parts. Sadly many of the better manufacturers have pulled out of the market for they cannot compete with cheap quality based on selling price. Do consider products made with intense quality control over the manufacturing process. These Products do exist. A non VW example would be the Apple iPad. 100% flawless quality, it is Recognized world wide as an extremely high quality product in both manufacture and design............
Made in China.
Ghia
Vanagon
Beetle
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Thu May 12, 2011 7:07 am Post subject: |
Big Hoss wrote: |
I talked to Paul,(email), today about MoFoCo's carbs. He says they are Chinese knock-offs. Even though they set them up for you on a running test motor, I still don't want anything "Made in China" on my bug if I can help it.  |
We can sell you a rebuilt German 34 pict 3 if you prefer. We also test run those on our dedicated engine before shipment. |
Posted: Thu May 12, 2011 9:33 am Post subject: |
@Roy
I didn't see any options on the Mofoco site. Just a single version of the 34 Pict 3 with no indication of who manufactured it. But if you do indeed rebuild/bebush the original German carbs, what is the price difference? |
candymustang65 Banned
Joined: January 11, 2010 Posts: 1674 Location: APPLE VALLEY
Posted: Thu May 12, 2011 10:02 am Post subject: |
The Beast ?
More like avengeing Angel sound's better ? LMAO
Your carb is flooding over !
Most likely reason's for flooding are .
1) Excessive fuel pump pressure .
2) badd inlett valve .
3) Wrong washer under the inlett valve .
4) Badd float .
5 ) Some other reason that is beyond my expertise like cousin Jethro had it apart ?
As to EMPI
again ?
1-800-satanic beast - Empire > Translation 1-800- 666- EMPI is the empi technical support phone number .
So you need to call Satan's Empire up to get help with your Chinneeese aftermarket part ?
Ahhhh ?
Hmmm as in good luck with that ? LMAO
Hey obviously Im not smart enough to make this bleep up ?
The number I gave you here is there number for there technical support .
But yeah Empi part's usually work chances are cousin Jethro has had it apart and failed to install the proper thickness washer under the fuel inlett valve on the carb .
Or fuel pump pressure is excessive .
A good question to ask of the Empi Tech is what thickness washer goe's under there inlett valve on this carb and what the maximum fuel pump pressure is for there carb's .
Stock solex / Bocar pump's put out 5-7 PSI .
Webbers need 2-3 PSI .
gas actually comming out of the throttle plate bushing wreak's and scream's that this is an inlett valve or float problem ?
Sean |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Thu May 12, 2011 11:25 am Post subject: 34-3 carb |
God points Sean the truth is what it is even with a little laugh.
With the same carb that I sold at my parts house I always supplied a plastic filter for obvious reasons.
One guy comes back to me complaining it would not idle after installation.
"Okay" I says, bring the car by so I can take a quick look see.
He comes by and it won't idle as he said. His wife is standing there with daggers coming from her eyes and she is p***** because of the money spent.
I back off the idle jet and the car idles okay, screw in the jet and it dies. Remove the idle jet and there is a tiny piece of what could be called a piece of straw i the small hole. I show it the guy and ask "what is this supposed to be as they do not install this object at the factory of origin".
His mouth drops open and his wife has a funny look on her face.
I ask him what happened to the filter I gave with the carb. He says that the old filter looked okay so he reinstalled it.
There is bound to one in every bunch (customers that is).
Steve |
Posted: Thu May 12, 2011 1:26 pm Post subject: |
Quote: |
But yeah Empi part's usually work chances are cousin Jethro has had it apart and failed to install the proper thickness washer under the fuel inlett valve on the carb . |
If cousin Jethro did have his mitts in there then I would definitely suspect a botched rebuild...in that event or if the internals are untouched it still points to poor QC.
Quote: |
Or fuel pump pressure is excessive . |
very true. even good throttle bushings will weep with loads of excess fuel. riddle me this, why design reproduction stock carbs to require different f/p then what the actual stock carb used?
Quote: |
I back off the idle jet and the car idles okay, screw in the jet and it dies. Remove the idle jet and there is a tiny piece of what could be called a piece of straw i the small hole. |
had the same thing happen to me. did a rebuild for a neighbor's friend with a vw trike. came by, I installed it, tuned it, it purred. next day got a "colorful" call that it stopped idling so told him to bring it by. took out the idle jet and a sliver of debris. admittedly I should have made sure there was a fresh fuel filter installed. _________________ '99 jetta GLS, '88 GTI 16v, '72 Super Beetle, '69 Fastback
Posted: Thu May 12, 2011 1:28 pm Post subject: |
Dave,
You misunderstood. I never mentioned the quality of their parts, you did. I just avoid supporting China's export business in general. I will take that extra time to research where my parts are coming from. I bought my heads from Mofoco because they are made in the USA. They weren't cheap, but the quality is superb and the $$ supports a couple of families here, not in China.
Phil, sorry to step on your thread. I hope you got your problem solved. _________________ 70 & 77 Bugs, 71 & 72 Supers
Current bug:1970 |
