Weber DCNF set up for 2110?
PlanB
PlanB is offline
PostPosted: Mon Mar 05, 2012 8:38 am    Post subject: Weber DCNF set up for 2110? Reply with quote
Finishing up a 2110 type 3 motor that I plan on road racing ('73 Fastback/DE car) and am looking for advice on setting up the 'Berg Special' 42 DCNF's that came on the original engine that I rebuilt.
Looking for advice on a starting point set-up of these weber carbs / jetting suggestions, venturi size, etc. specifically for road racing.
2110cc, 40x36 heads, web cam 110, 1:1 rockers, 1 5/8" exhaust, 9:2 CR
Thanks!
DarthWeber
DarthWeber is offline
PostPosted: Mon Mar 05, 2012 3:45 pm    Post subject: Reply with quote
You might consider going with different carbs (Dellorto 40DRLA's) for a pure road race application. Since you have the Berg Specials have you called the Bergs and asked for set up info? I think one thing they will recommend is the ball type fuel inlet valve, rather than needle valve type. The ball type helps keep the fuel level in the float bowl more stable which can be a problem with DCNF's (that and they have a very small float bowl) in high G turns leading to a lean out condition.
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
luckystiff
luckystiff is offline
PostPosted: Mon Mar 05, 2012 4:00 pm    Post subject: Reply with quote
theres simple cures for the "lean out" condition that seems over exagerated anyhow. i think it was BRENT that posted the tech...ken....
ITMC
Secret Service
DarthWeber
PostPosted: Mon Mar 05, 2012 9:58 pm    Post subject: Reply with quote
There's a reason the DCNF wasn't a very popular carb for VW performance builds. IDF's, IDA's, Dell DRLA's all have much better design for fuel supply than the DCNF. I stand by my recommendation of switching to Dellortos for road racing. At any rate, you could help PlanB by posting a link to the "tech" you refer to.
PlanB
PlanB is offline
PostPosted: Tue Mar 06, 2012 11:26 am    Post subject: Reply with quote
Thanks for your thoughts. For several reasons I'm 'stuck' with the DCNF's for at least 3 events and yeah, I've already addressed the ball valve inlet issue and plan on using phenolic spacers to deal with the fuel bowl percolation issue with DCNF's.
I will as you suggest; Contact Berg — but I thought I'd seek specific advice on a 'starting point' set up for jets, vents and emulsion tubes (for this particular motor's' specs) from the crowd the crowd here first, so that I'd have some starting point for discussion with them.
subtaf
subtaf is offline
PostPosted: Fri Mar 09, 2012 10:07 am    Post subject: Reply with quote
Where is the best place to buy the parts to convert to the ball type inlet valve?
I have twin 40DCNF's on my 2019cc type 4 with a cam similar to the 110 for a type 1. The chokes were far too small (28mm). But pulled real hard from 2500 - 5000 rpm. It couldn't rev any more than 5500rpm in top gear with these chokes though.
I'm running 34mm chokes now but with a stock motor while the stroker is getting a freshen up. 34mm seems to big for the stock motor with a better exhaust.
59 Split Panel van project.
2109cc 75 micro bus
89 T3 4WD Syncro
Zero Type 3's as yet.
spencerfvee
spencerfvee is offline
PostPosted: Fri Mar 09, 2012 8:51 pm    Post subject: Reply with quote
i two just picked up a set of 40 dcnf webers i have 32 venturis with 220 airs and 125 mains i never liked 220 airs and the mains seem to be to small for my 2180 motor. i have not put the 40s on my motor yet .they need rebuilt first . i had a set years ago and liked them. i to would like to know who sells jets for the dcnf weber carbs spencerfvee
DarthWeber
PostPosted: Fri Mar 09, 2012 10:17 pm    Post subject: Reply with quote
Jets, venturis and replacement parts can be sourced from Pierce Manifolds
http://www.piercemanifolds.com/
or AirCooledEngineering or AC.Net.
Gene Berg always toted the DCNF flag with their Berg Special carbs. They might have some DCNF parts and also the inlet ball valves. You never know, it's probably a 50/50 chance they'll have something in stock nowadays.
spencerfvee
PostPosted: Sat Mar 10, 2012 6:56 am    Post subject: Reply with quote
wow thanks darth that web site rocks . darth for a starter what size mains and air jets would you start with for a 2180 motor with ported 40mm by 35 mm valves heads. engle v26 cam the carbs have 32mm venturis. 45 pump jets .50 idl. jets thanks spencerfvee
subtaf
subtaf is offline
PostPosted: Sat Mar 10, 2012 6:27 pm    Post subject: Reply with quote
Hi spencefvee,
I have 34 venturies in my 40's with my 2109 type 4 which I run in a bus. These are probably a little too big and I'm thinking I should be running 32 venturies in mine. My 34 vents would probably suit your 2180 and your 32 vents would suit mine. Interested in a swap?
I think postage is on $10 or so to here.
2109cc 75 micro bus
89 T3 4WD Syncro
PlanB
PlanB is offline
PostPosted: Fri Mar 16, 2012 11:16 am    Post subject: Reply with quote
subtaf wrote:
Hi spencefvee,
I already sent my vent's out to be re-bored.
Thanks for the offer though...a swap probably would have been quicker too!
subtaf
subtaf is offline
PostPosted: Fri Mar 16, 2012 11:20 pm    Post subject: Reply with quote
No problem. At least you will get the size you need anyway. I'll get around to advertising these eventually.
2109cc 75 micro bus
89 T3 4WD Syncro
Brent
Brent is offline
PostPosted: Sat Mar 17, 2012 8:41 am    Post subject: Reply with quote
Here's the link to the vent stack thread to keep fuel from sloshing into the air correctors.
www.thesamba.com/vw/forum/viewtopic.php?p=5821771
I don't agree that they were not a popular choice for performance. Seems to me they were THE carbs to have for street 20+ years ago.
Yes, DCNF's are old, harder to find parts for, parts are more expensive...
But...
In a Type 3 they have some advantages over IDF/DRLA/HPMX:
- They're shorter, about 5/8" or so. With the other carbs, you'll have to run the little air filters that barely fit under the decklid. Not that DNCF filters are much bigger, but that little amount of room is a lot in a Type 3.
- The manifolds are skinnier. I can change a spark plug without pulling the carb/manifold/linkage. It's not easy to get at though.
I've also removed the chokes and soldered the tip of the starter jet shut.
PlanB-
Venturis are like $80 a set, so you want to get it right the first time. For a 2110, probably 34's. Take a look at this:
http://7faq.com/owbase/ow.asp?HowDoI%2FTuneWeberCarburettors
Here's some other formulas I like for dual carb jetting (about middle of the page):
http://archive.mirafiori.com/show.php?fid=6&msg=1587
The aux venturis should already be 4.5's. I think there's a stamp on the side.
F24 or F25 for ET's. I'm not sure of the difference. I know mine came with F11's, which I changed.
Idle jets. You could try 55 and see how they work. A wideband would really help here. You don't want them too big - rich.
Mains. Maybe try 135 to start with.
180 or 190 for the air correctors.
I think this would be close. Depending on what's already in them you can easily spend a couple hundred bucks getting them set up.
69 Fastback Build
Berg5 Build
VerySquareBack
VerySquareBack is offline
PostPosted: Thu Mar 22, 2012 9:16 pm    Post subject: Webe r DCNF set-up Reply with quote
I've observed this topic, and wanted to add some more. I've been running a pair of DCNFs for 40 years on a 1640 and have got the mileage up to 33 with no lean spots. The set-up has been with 32 Venturi, but the air and fuel jets, and e tubes are not specific to any one formula. My biggest observation is that a Air/Fuel meter is manditory along with a CH Temp guage. I've seen a 50 degree increase within 2 miles after a jet change. A person has to use caution and be very careful.
Carbs can be very smooth yet way off proper mixture and until they are very lean don't make their condition known. Lately I've started making my own emulsion tubes that have allowed the main fuel jets to drop from 145 to 119 and run at a steady 13:1 at mid speed and top. The transition from the idle circuit is still difficult to get right.
On the issue lean mixture on cornering consider this: on the Ferrari motors the DCNF is mounted across the motor with the float bowl in front. On acceleration the top surface of the fuel tilts up at the back which is over the fuel circuit richening the mixture. On our VWs the carbs sit sideways, so the inside carb goes rich as the outer carb goes lean. On the other hand, the IDF/IDA have the fuel bowl between the barrels and should lean the front barrels on acceleration. Oh well, that's carbs.[/url]
wheel607
wheel607 is offline
PostPosted: Fri Mar 23, 2012 10:22 am    Post subject: Reply with quote
If you have a Carquest auto parts house in your area, go there. The same company owns Redline and Carquest and they will order any Weber jets you want and will even overnight it to any Carquest location you desire for free. I know because they did this for me.
