Jon_slider Samba Member
Posted: Sat Sep 01, 2012 12:08 pm Post subject: Syncro Body Creases forward of rear shock towers |
There is a discussion going on the Yahoo Syncro Group about the presence of reinforced frame rails on 89 and later Syncros. There is also mention of the reinforced body panels on Syncro 16's.
http://autos.dir.groups.yahoo.com/group/Syncro/message/52671
> I have a 1989 Syncro GL passenger van, no lockers, hardtop. It was manufactured
June of '88. It HAS the reinforced frame rails.
Also, developing a crease in the sheet metal above and to the front of the rear
wheel well, seems to be common with the off roaders.
http://autos.dir.groups.yahoo.com/group/Syncro/message/52681
> AFAIK the Syncro 16" had reinforcements for the body panels (on the inside)
around that area, as well as for the rear upper spring / shock mounts,
which presumably was done to address the weakness that causes the creasing.
When I saw body creases forward of my rear shock towers on my 87 Syncro, which has neither reinforced frame rails, nor reinforced body panels, I contact the owner of a 1990 Syncro 16 that has BOTH the reinforced frame rails AND the reinforced body panels. Neither feature prevented that 1990 Syncro from developing body creases on Both sides.
this photo shows the location of my body crease, although it is not visible at this angle.
afaik, there is no way to prevent this from happening to a syncro that is used offroad in ways that puts less than all 4 wheels on the ground at all times. I believe the crease is caused by terrain that causes the front end to try to do wheelies, or makes one of the front wheels airborne.
I believe my crease was caused during this maneuver:
_________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Sat Sep 01, 2012 1:10 pm Post subject: |
This is a common problem on Syncros that are offroaded a lot and exaggerated when stiffer springs are fitted.
It's just one of those 'Syncro' things.
Limey is the same.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
rubbachicken Samba Member
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Sat Sep 01, 2012 2:09 pm Post subject: |
Should it be worn as a badge of honor or as I am actively
looking for a syncro something that I see should be avoided?
I have been pursuing a late model and really trying to avoid
the earlier ones though it doesn't seem to be avoidable by
any year if driven hard enough. I just wonder if it creases
on the body is there also damage underneath or elsewhere? _________________ Bill M
87 Westy |
Posted: Sat Sep 01, 2012 2:14 pm Post subject: |
| SyncroGhia wrote: |
| exaggerated when stiffer springs are fitted. |
Thanks!
That makes sense. 3.5" of Shims make my spring rate higher.
GW +2 spring with 2.5" bottom perch shim and 1" top shim.
That corner has the westy cabinets plus the 70lb spare tire on my 87 Syncro, in addition to the weight of the 2.5 AEL TDi motor _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
BillM Samba Member
Posted: Sat Sep 01, 2012 2:16 pm Post subject: |
Jon is yours creased on both sides or just the one? _________________ Bill M
87 Westy |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Sat Sep 01, 2012 2:25 pm Post subject: |
delete
Last edited by furrylittleotter on Tue Sep 04, 2012 11:18 pm; edited 1 time in total |
Posted: Sat Sep 01, 2012 2:34 pm Post subject: |
I have only creased the side with the westy cabinets and spare tire carrier, my US driver side, so far.
But the couple other syncros I know of with creases, have them on both sides.
I think those drivers like to get airborne more than I do.
Or maybe they have taller gearing and/or charge steep terrain changes faster than I do.
My crease could also have happened at the moment of my front tires impacting with the initial slope, just before the wheelie stage on the video. On that run, I was using more speed than normal, because I had stalled the previous attempt at slower speed. I later learned airing down was more effective than using more speed/momentum, to climb that obstacle. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12397 Location: Santa Cruz, CA
DLJ showed me that crease on his van a year or 2 ago, i have seen it a few times since from the more adventurous syncro drivers.
There are no panels to flex since the entire van is welded together and the stresses will manifest somewhere.
Accept it as a badge of honor or a scar- chix dig scars.  |
insyncro Banned
Posted: Sat Sep 01, 2012 7:10 pm Post subject: |
Nicely done
Syncrozilla Samba Member
Joined: September 11, 2004 Posts: 773 Location: Santa Barbara
Posted: Sat Sep 01, 2012 7:36 pm Post subject: |
So far the evidence seems to suggest that adding the 16" reinforcements (that Dylan illistrated above) will not prevent the side body creases.
My 90 hardtop has been wheeled pretty hard but has not developed the creases. It does have the reinforced frame but not the "16 reinforcements.
Are there any hard tops with the crease or are they all van that are westys or converted campers with holes in the roof?
I also wonder if there is any correlation with total weight. I try to keep my van pretty light. It has a very spartan interior and I pack pretty light. I don't carry a slew of extra Jerry cans, firewood, water, etc etc. I have the factory rear seat plus maybe 250 lbs worth of gear for sleeping eating and possible field repairs. _________________ Please do not message me on TheSamba. Use my email, [email protected] |
Posted: Sat Sep 01, 2012 7:46 pm Post subject: |
| The vans that i have noticed with the wrinkle usually are campers of some variety. |
dipple Samba Member
Joined: April 09, 2005 Posts: 135 Location: Whistler BC
Posted: Sat Sep 01, 2012 7:49 pm Post subject: |
I also have this crease on my high top camper. It was done during a creek crossing. I hit the far bank and the front 2 wheels went up in the air and came down hard. It is a 1991 with syncro.org and OME's a the time. I also had airbags in the springs. I did not notice until a few day later. Passenger side only though. _________________ 1987 Syncro
1998 Syncro TDI Passat |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10453 Location: Orbiting San Diego
Posted: Sat Sep 01, 2012 8:12 pm Post subject: |
My 87 Syncro Camper has had it for many years, looking like Brent's on the driver side and barely a touch on the pass side. I always feared it would get worse but it never has that I can tell. Are there any reports of progressive worsening to greater damage than what Brent shows?
Mark
| syncrodoka wrote: |
Last edited by crazyvwvanman on Sun Sep 02, 2012 1:52 am; edited 1 time in total |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
Posted: Sat Sep 01, 2012 8:34 pm Post subject: |
I have a 2WD westy, a pretty heavy one. My last outing I feared I would get the crinkles. I had the front end in the air twice, and the back in the air once. Everything came off the dash. No crinkles yet. Mostly I get air born when I'm nervous about getting bogged down or stuck in something like a mud pit, and I floor it, and suddenly discover a hidden ramp of some sort  _________________ Check out our Our youtube channel: Https://www.youtube.com/channel/UC-EbskIxNm6SYzsq4ugG81A
http://www.thesamba.com/vw/forum/viewtopic.php?t=496946 1987 VW Vanagon Westfalia with 1.8T |
Posted: Sat Sep 01, 2012 11:42 pm Post subject: |
Jon_slider and SyncroGhia have a hardtop to westy conversion
CVbill and DLJ have a hard top to country homes conversion
dipple has a hard top to high top conversion
Interesting
Is yours a factory conversion mark?
Any hardtops with the super syncro wrinkle? |
Posted: Sun Sep 02, 2012 1:52 am Post subject: |
Mine was a hardtop when I bought it and then I put the Westy stuff in it.
Mark
| syncrodoka wrote: |
Interesting
itsasyncro Samba Member
Posted: Sun Sep 02, 2012 8:03 am Post subject: |
My tin top got the wrinkles when I did hells revenge at
Syncro Solstice.
Prominent on the passenger side, not as bad on the
drivers side. |
Posted: Sun Sep 02, 2012 8:19 am Post subject: |
How did you get your super syncro wrinkle itsasyncro?
Was there airtime involved?
I have accidentally jumped my truck once but it was just going over a rise on a fire road that dropped off not on difficult terrain. I don't have it but there are other "experience" points.  |
GoWestyYoungMan Samba Member
