Middle child Samba Member
Joined: April 18, 2009 Posts: 119 Location: Minnesota
Posted: Mon Apr 21, 2014 3:14 pm Post subject: Start button... 1960 Bug? |
I just picked up another 1960 bug and I had a key made but there's no detent to engage the starter...?... just the two position on/off ... so what's up with that? I don't remember seeing a starter button a pushin starter button. I know some of the really old ones have them. So the locksmith screwed up or what? Any help would be appreciated. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24768 Location: Olympia Wash Rinse & Repeat
Posted: Mon Apr 21, 2014 5:33 pm Post subject: |
Post image... _________________ In Stereo, Where Available! |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Mon Apr 21, 2014 6:33 pm Post subject: |
Perhaps it is normal?
On the early switches, they don't have the no-repeat feature like '61 up.
Pretty sure up to '60, you turn it to first click, then you have to push in on the key (it's under light spring tension) to get it to turn to the crank position. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
bluebus86 Banned
wayne1230cars Samba Member
Posted: Mon Apr 21, 2014 8:29 pm Post subject: |
That is how my original SE switch on my '60 works. You have to push in on the key as you turn it from the on position to the start position and as already stated, it does not have the non-repeat feature that the 61 and on have. _________________ 1960 beetle
1970 beetle convertible |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Mon Apr 21, 2014 9:39 pm Post subject: |
Just chiming in with the rest... You have to press the key in a bit as you turn to engage the starter, otherwise, it hangs up. _________________ Plate of shrimp |
Posted: Tue Apr 22, 2014 5:28 am Post subject: |
Thanks for the half dozen or so replies but no its a 2 position switch no pushing in does anything different and it's the screw in terminals that the 60's still had the terminal in the back closest to the mounting screw bracket is number 30 clockwise from there the next terminal is marked with a 50 clockwise from there over to the other side 15 / 54. |
bluebus86 Banned
Posted: Tue Apr 22, 2014 7:12 am Post subject: |
Middle child wrote: |
maybe it is jammed up, try some graphite on the key???? _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
BWD Samba Mailman
Joined: August 23, 2002 Posts: 2154 Location: In bed.
Posted: Tue Apr 22, 2014 10:58 am Post subject: |
I have been happy with Justin's (the guy in the ad) work and think that is a good option! _________________ BWD
JHC
member #2850
1966 Beetle
_____________________________ |
Posted: Tue Apr 22, 2014 12:53 pm Post subject: |
BWD wrote: |
I have been happy with Justin's (the guy in the ad) work and think that is a good option! |
I purchased an original SE ignition switch and key from Justin and was very pleased. _________________ 1960 beetle
Posted: Thu Apr 24, 2014 6:06 am Post subject: |
Falling just short of digging out a BFH and no amount of oiling or persuasion even talking to it could make it any more than a two position switch. I asked the locksmith and he checked it with an ohmeter or whatever and said that there's power there so anyway I'm headed back home in a couple days and I'll probably have a duh moment finding a start button...or I'll be ordering a new switch as was suggested. Thanks. |
61SNRF Samba Member
Posted: Thu Apr 24, 2014 6:00 pm Post subject: |
There's the biggest clue right there to it's functionality.
Why would a two position switch have a terminal 50? If it has a 50 terminal, then it is most likely a three position switch made to momentarily energize the starter solenoid.
Ignition switches live a hard life, and the guts are made made of white metal, so it might just be broken inside. The locksmith would only have to mess with the tumbler to make a key, so probably not their fault either.
Another clue to it's vintage is the key profile. Is it in fact a '60 SE profile switch? Does the key match the door handles? _________________ -Bruce
Posted: Sat Apr 26, 2014 8:25 am Post subject: |
That's what concerned me so I had the "lacksmith" check it out....I thought if it were a three position switch he could tell me..all he said was that there was power there...."there"? I mean for a switch that is over fifty years old everything unscrewed perfectly...I can't imagine the inside being so burnt up as to not move at all...but anything is possible. I'm an hour away from home, I'll do some more checking. Thanks. |
Posted: Sat Apr 26, 2014 1:18 pm Post subject: |
Well you guys sure know your stuff I would never have believed that I could get that to move by pushing it in... But I did get it to work and move to that starter crank position but it doesn't spring back which is what I was expecting ...?... so there's something wrong in there ... who did you suggest sending it to? And the key does not fit the door I know someone asked if it fit the doors plural but it only has the lock on the drivers door so that was a trick question? I have a couple other cars like that that need keys I'll probably take them to the same locksmith very inexpensive to have done and we'll see how the other ones turn out. It kind of amazes me that I don't remember that because years ago back in the 70's I owned a '60 European model with working semaphores. I bought it for 75 bucks... fixed the brakes and sold it for 4 times what I paid... I was so proud of myself... |
Posted: Sat Apr 26, 2014 1:28 pm Post subject: |
If the key works in both door and ignition, it would be a matched pair quite possibly from the factory. If not matched, then one or both have been replaced....
Up to you if you want to have a matched set so you only need one key. If you do, then contacting one of the VW key dealers in the classifieds and get it done. _________________ In Stereo, Where Available! |
Posted: Sat Apr 26, 2014 3:42 pm Post subject: |
Wow...if I wasn't at a loss for words before I am now....that key that I had made fit my other 1960 Bug perfectly. And the reason I didn't remember about pushing the key in is because you don't have to think about pushing it in ... the turning motion pulls it in. |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Sat Apr 26, 2014 5:01 pm Post subject: |
If you want to match your ignition key to the doors, you can do it yourself.
This "type 3" site explains the process.
The ignition has more tumblers than the door so you match the doors to the ignition key, NOT the ignition to the door key. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
Posted: Mon Apr 28, 2014 1:29 pm Post subject: |
I went to that site and could not find anything but that's okay. I have one more 1960 bug to pick up in Nebraska ... what are the chances of that one having the same key as well... ? Probably not very likely. |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Tue Apr 29, 2014 4:06 am Post subject: |
Aussiebug wrote: |
The ignition has more tumblers than the door so you match the doors to the ignition key, NOT the ignition to the door key. |
Is this only for certain years? When I redid the doors and ignition on my 62, all my SC cylinders had 6 wafers/tumblers. _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
