richparker Samba Member
Joined: November 24, 2011 Posts: 6989 Location: Durango, CO
Costa66 Samba Member
Posted: Sun Feb 11, 2024 3:16 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
Only thing that may be concerning is if the motor mounts give way and there not being enough slack in the line.
Josh |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Sun Feb 11, 2024 8:49 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
I'm a fan, looks clean. Next do the fuel line that way! _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Sun Feb 11, 2024 9:38 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
Costa66 wrote: |
Josh |
If the engine and transaxle separate, I got bigger problems then some short oil lines. 😜
scrivyscriv wrote: |
I'm a fan, looks clean. Next do the fuel line that way! |
Thanks! It was kinda a spendy set up that I didn’t have planned. I wanted one, my builder doesn't like putting the filter in the wheel well. We planned on running the 26mm Maxi Pump again. But, then he basically had the full flow all machined into the case when he cleaned out the oil galleys, so we went for it. My idea of putting the fittings through the fender was an idea that he thought was cool and made the decision happen.
The fuel lines will be set up the same from the last engine. If you go back to page 11 and look at the engine pics, you’ll see that the line is barely noticeable .
Minus the oil lines, I’m sure it’s gonna look exactly like the 2109 that was removed. Performance should be a lot better too. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Sun Feb 11, 2024 9:56 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
I only mention it because I've been thinking about doing a bulkhead fitting on the left side of my 1967 bug engine bay for the fuel line, instead of going through the forward engine tin hole as stock. Grommets are okay for wires and cables, but I'm a big fan of bulkhead fittings for fluid lines, sort of like your oil fittings, although it does look like you're going straight in to the body of the filter mount with regular fittings. Still a good design the way it's set up.
You'd think with all the years of aftermarket stuff, someone would come up with a good place and design for a remote oil filter, and they haven't (that i'm aware of)!! We all just have to engineer to our level of satisfaction and peace of mind. _________________ Robert in Memphis
viiking Samba Member
Joined: May 10, 2013 Posts: 2673 Location: Sydney Australia
Posted: Tue Feb 13, 2024 7:26 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
richparker wrote: |
Rock guard fits like a glove.
I like the idea of the rock guard but just an observation.
The rock guard looks a bit longer than the filter that you have. Is there a likelihood that a large rock could actually hit the rock guard and break off the filter housing because there is a long fulcrum/lever now? It's not obvious (to me) how the rock guard fits.
Is it worth adding a bracket at the end of the rock guard to remove the fulcrum issue and reduce the risk of damage. Yes you would have to work on how you can remove the rock guard and spin off the filter. Perhaps a simple bracket welded on and then attached to the body?
I guess I'm thinking of the worst case scenario of a big rock and perhaps the probability is low. Just thinking. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Tue Feb 13, 2024 9:01 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
I don't know what filter he's using but the common PH1A most people use is BIG. The rock guard looks about the right size for one. _________________ Robert in Memphis
Posted: Tue Feb 13, 2024 9:57 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
Viking, good eye. The current filter is a WIX 51085 which is a short filter. When the filter was purchased, we weren’t exactly sure how the layout was gonna be. So I bought the short one to be on the safe side. I actually bought 2 of them. There was a particular rock guard/heat sink I was looking for, but I have been unable to locate one. I bought the current rock guard b/c it is what’s available. Although everyone who posted on the thread I started in the performance forum states they don’t use a rock guard and they’ve never had issues. 🤷♂️. I will use the shorty to start and again at 400 miles service. Then at the 1400 miles service I will change over to the longer WIX 51515, which will take up the whole interior of the guard.
Hopefully tomorrow I’ll be posting a picture of a long block. 🤞 _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
mtnbus Samba Member
Posted: Thu Feb 15, 2024 10:19 am Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
Lookin good Richie!
you gotta be stoked |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9978 Location: Huntington Beach, CA
Posted: Thu Feb 15, 2024 10:31 am Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
The rock guard is a cool idea! I like it…..but the bigger issue you need to protect against is tire treads from semi trucks. Those things ring the fender when they slap up against the inside of the fender. That canister cover is just a larger target!
Just a thought as I just ran over a big chunks of rubber, a few days ago, flying down PCH! I was able to avoid it hitting on the drivers side where the filter rests by turning the steering wheel at the last minute! It ended up passing under the middle of the car!
Regardless, I like the idea, but it still seems like a target. You need to fabricate a steel box that bolts up into that area, with a little bit of air space, inside the box for deformation. Then you would have a chance. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
esde Samba Member
Joined: October 20, 2007 Posts: 5971 Location: central rust belt
Posted: Fri Feb 16, 2024 8:43 am Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
richparker wrote: |
I’ll lines are run
Nice work so far! I have a few questions about the full flow oil routing
I'm wondering how the builder has the case plumbed to work as pictured.
The lower line in the picture is the beginning of the oil galley, closest to the pump. This is the location usually used to return filtered oil to the case, but here it appears your builder is using it to supply the filter. I can't see how this works to supply oil to the engine and filter unless he's plugged the oil passage somewhere. Has he buried a plug in the galley under the fitting? And then the top line (I assume is clean oil from the filter) is feeding the oil galley from what is usually the end, near the #4 bearing supply and pressure switch. Feeding the oil to this end works, but the cooler bypass piston will be inoperable.
None of this is a criticism, just me asking questions trying to understand what's been done here.
SD _________________ modok wrote:
toxicavenger70 Samba Member
Posted: Fri Feb 16, 2024 12:42 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
Looking good! Thanks for sharing the ideas Rich.
I wonder if this will be the last motor JB will put out before he retires? |
Posted: Fri Feb 16, 2024 8:36 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
esde wrote: |
SD |
The case is plugged, not the oil pump outlet. Oil leaves the pump and exits the horizontal galley rather than entering the opening into the vertical galley that connects to the oil cooler relief valve, the cooler and the oil pressure switch galley as normal. It then goes through the filter and enters the main galley above the cooler relief valve just two inches or so above where it normally would from the factory.
If you study the oil network, there is no connection to #4 main bearing and any of the galleys mentioned. There is a separate oil galley between #3 and #4.
toxicavenger70 wrote: |
I wonder if this will be the last motor JAD will put out before he retires? |
I hope not. It’ll be a sad day in the ACVW community the day he hangs up the tools.
Almost ready to be “stabbed in” as JAD likes to say….
Looks just like the engine that was removed 😂
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
esde Samba Member
Posted: Fri Feb 16, 2024 8:47 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
richparker wrote: |
Very cool. Now that you describe it, I can see the connection to the case is not the typical port behind the pulley, but above that.
Posted: Sun Feb 18, 2024 5:34 pm Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
Oh yea!!!!! Full report to come after I pick up the car. I believe it’s going for a alignment tomorrow, so maybe I’ll pick it up on Tuesday.
Lots of room for the tires.
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Wed Feb 21, 2024 7:42 am Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
I picked up the car yesterday morning, woot woot! Wifey dropped me off at the shop, I loaded up the parts that didn’t get used, the tires and shot the shit with the builder for a bit.
The car fired right up and after a few pumps of the gas it went right to idle. The builder was very happy with how it idled with the 297A (VZ25) cam. The drive home was about 30 miles, all highway driving. The car drove very nice, it is very tight. I cruised around 60 and did a lot of engine braking to help set the rings. It’s not surprising the car it so tight, it’s basis new car. It’s been about 4 months since I had the car last, here’s a list of things that were done.
2175cc
9.25:1
AS41 case w/custom full flow
78.4 CB Super Race crank w/Chevy rod journals
5.4 CB H-Beam rods
94mm Mahle P&Cs
Total Seal rings
Engle cam with Berg 297A grind (aka VZ25)
CB straight cut cam gears
CB 044 heads
Thundermingo IDF48s
CB intakes, filter bases and linkage
phonic spacers
Vintage Speed 57/35 Super Flow exhaust
Real 009 with Petronix
30mm oil pump
Scat 1 1/2 qt sump
Kats VW-15 sump heater
KEP stage 1 clutch
Veleo disc
Vdo oil pressure and oil temp senders and guages
Working T-Stat and flaps
German long block tin and Chinese 36 hp fan shroud
Brosol fuel pump
Summit Racing oil fittings and oil lines
CB crank and Alternator pulleys
Transaxle rebuild w/new bearings, syncros and new boots
CB Rhino Trans mounts
VS 12” Classic Shifter
New German rear drums
New e-brake cables
Carb Windows
Rear torsion adjustment to 20° w/new bushings
New tie rods
5.5” wide rims in rear
205/75R15 Hankook tires in rear
4 wheel alignment
Basically a new car…
I’ll be taking it back to the shop for the 400 mile service, I’m sure that won’t take too long to put those miles on. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build
Kafer_Mike Samba Member
Joined: June 23, 2004 Posts: 348 Location: Noblesville, IN
Posted: Thu Feb 22, 2024 6:38 am Post subject: Re: Scored a local ‘65 Deluxe, The Monster |
Nice! Enjoy your 'new' ride and keep us posted with updates. _________________ Kafer_Mike
Build 'em fast...or let 'em sit. |
