nextgen Samba Member
Joined: August 19, 2004 Posts: 6035 Location: CONGERS, N.Y.
Posted: Sat Nov 11, 2023 9:26 pm Post subject: What do you recommend for a good valve cover gasket |
Is Cork still the best as long has you don't store it to long or get a cheap sent that don't fit correctly
Or is there a new material ..
Use adhesive or not and if you do, both sides of the cork or only one.
Did the valve adjustment and that was fine.
Old gaskets lasted for a long time no problem
New gaskets and both sides leaked.
Put in another set and only one side leaked.
They are for my T-4 bug. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
modok Samba Member
Joined: October 30, 2009 Posts: 26796 Location: Colorado Springs
Posted: Sat Nov 11, 2023 10:11 pm Post subject: Re: What do you recommend for a good valve cover gasket |
The good gaskets are really more like rubber with cork.
the purpose of the cork being to make it more flexible and grippy.
But anyway the quality of the rubber is what matters, cork is cork more or less.
Works with tires too. |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3594 Location: viroqua wi.
Posted: Sun Nov 12, 2023 1:30 am Post subject: Re: What do you recommend for a good valve cover gasket |
Type 1 guy here but my 2 cents are that thickness and bail strength have a lot to do with it. |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2152 Location: Behind the wheel
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76977 Location: Sneaking up behind you
Posted: Sun Nov 12, 2023 6:04 am Post subject: Re: What do you recommend for a good valve cover gasket |
Cork, I use Permatex aviation to the valve cover only, stock valve cover and bail.
Never a problem. _________________ Glenn
Member #1009
#BlueSquare |
richparker Samba Member
Joined: November 24, 2011 Posts: 6989 Location: Durango, CO
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Sun Nov 12, 2023 8:34 am Post subject: Re: What do you recommend for a good valve cover gasket |
I`ve used the silicone gaskets from Wolfsburg West with good results. _________________ If you`re going to do something, do it right. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31396 Location: Hot Arizona
Posted: Sun Nov 12, 2023 8:44 am Post subject: Re: What do you recommend for a good valve cover gasket |
I've used only the cork gaskets on my two VWs, since 1972 and 1976 respectively, and have had zero leak issues. I've also been known to re-use such gaskets.
I have factory/vintage unpainted/patina covers and bails on both.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21521 Location: Oklahoma City
Posted: Sun Nov 12, 2023 9:12 am Post subject: Re: What do you recommend for a good valve cover gasket |
Glad you linked to that so I don't have to re-type all of that!
But yeah.....things have changed in rubberized cork.
The other issue is this.....and I see this same problem in all kinds of AFTERMARKET auto parts.
Our original parts (valve cover gaskets) were made by some large company for VW. In the beginning eons ago, during testing, I am sure there were issues. I am sure there were many versions made and tested while VW was ramping up production after WW2.
Like any other consumable part, VW had to figure out what version lasted a reasonable amount of time leak free, was affordable, worked with the oil and heat range.....and wrote a spec for it.
In turn, the mfg of the gaskets issued a rubberized cork sheet specification for type of rubber resin, grade of cork, size of granules, porosity etc.....to make sure that when they dies cut these parts.....they met VWs spec.
It's also possible that VW did the cutting and sealing and only had to issue a specification to the raw material/sheet goods mfg.
That's how it works generally.
Cut to 40-50 years later, demand is huge versus right after ww2.....and it's all been farmed out to big sealing company's like Elring and Reinz. Those are still OEM and material and construction still have to meet spec.
Later still, the ACVW is out of serial production and these parts are kicked full to the aftermarket curb.
A lot of 2nd and 3rd world aftermarket companies.....while they may try to follow the spec....they have no real knowledge of WHY certain chemicals, rubber types, porosity, granule size etc.....are important. It's an obsolete part system for an obsolete car. They are used to modern materials and designs......so they skimp and substitute.
And, they are driven to do so because of COST targets.
I see this same issue in MANY rubber and plastic parts. If your only knowledge of valve cover gaskets is watercooled.....you may question why Viton is required instead of say Neoprene or Buna, not realizing that the temperature of the AC engine at this gasket....might be 150° higher than in a WC car.
Ray |
Posted: Sun Nov 12, 2023 9:41 am Post subject: Re: What do you recommend for a good valve cover gasket |
Funny my dad once said misery like company. Man I got alot of that on this post. I feel so much better, ha.
I was thought it was only me, to a point were I was thinkiing maybe I put the covers on Reversed !!
OK so use stock cork with Permatex which I did use, on both sides of the cork.
As mentioned they are T-4 covers.
BTW having a hard time trying to remove the double sided Permatex cork.
RAY your are a T-4 guy were are you. T-1 vs T-4 should not be any difference except the T-4 has larger covers.
Thanks again, _________________ email: [email protected]
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13852 Location: White Mountains Arizona
Posted: Sun Nov 12, 2023 10:29 am Post subject: Re: What do you recommend for a good valve cover gasket |
I use the cork gaskets and soak the in water for a while as they swell up..then a thin coat of grease on the cover and on teh cork gasket...works every time. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
gt1953 Samba Member
Posted: Sun Nov 12, 2023 12:16 pm Post subject: Re: What do you recommend for a good valve cover gasket |
Like i say i soak them in water and just pat them dry with a paper towel. Thin coat of grease..as someone mentioned it is about the suggness of the bails. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2215 Location: UK (South)
Posted: Sun Nov 12, 2023 12:32 pm Post subject: Re: What do you recommend for a good valve cover gasket |
raygreenwood wrote: |
Cut to 40-50 years later, demand is huge versus right after ww2.....and it's all been farmed out to big sealing company's like Elring and Reinz. Those are still OEM and material and construction still have to meet spec. |
FWIW, I've just binned a pair of Elring cork valve cover gaskets. They leaked just as bad as the no-name ones from ebay that I bought them to replace. I wish I hadn't bought a few pairs of the Elrings. I'll probably not use the remainder of them.
The previous several pairs of no-name covers, prior to this last leaky pair, were leak free. There seems to be no logic to the failure.
I'm trying silicone ones now, but with the weather turning, I've only been out in the truck once since I fitted them. No leaks when I came back.
Type 1 engine. OG VW valve covers and bail arms. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Glenn Mr. 010
Posted: Sun Nov 12, 2023 12:33 pm Post subject: Re: What do you recommend for a good valve cover gasket |
nextgen wrote: |
Oh as for the Permatex, how much do you use? Just a light bit in a few places as a few guys said just to hold the gasket in place or do you do the entire surface? |
Just around the entire rim, enough to hold it in place. _________________ Glenn
Member #1009
#BlueSquare |
Zed999 Samba Member
Posted: Sun Nov 12, 2023 1:44 pm Post subject: Re: What do you recommend for a good valve cover gasket |
Just a smear of grease both sides for me and they don't leak (type-4). I've been doing that for25 years or more.
But... to bump up to free post minimums I had a habit of buying these gaskets (saves thinking) and ended up with quite a lot of them so it's at least 10 years since I bought any. I still have half a dozen sets so I'm good for a while yet. Perhaps as Ray proffers, they aren't the same these days.
The other thing is I don't check my valve gaps every service. New engine I did the first few services but they never changed so I'm happy to check every third time or if I felt the engine wasn't running smoothly and couldn't find a fuel related problem I'd check them. |
Cusser Samba Member
Posted: Sun Nov 12, 2023 3:34 pm Post subject: Re: What do you recommend for a good valve cover gasket |
And, they are driven to do so because of COST targets. |
I bought this leaf rake last week; apparently it is cheaper to just provide the screw to lock in the handle, rather than install it at the factory. Even drilling a hole and inserting a screw has a cost...
Posted: Sun Nov 12, 2023 3:40 pm Post subject: Re: What do you recommend for a good valve cover gasket |
Glenn you hit it on the head.
( Just around the entire rim, enough to hold it in place).
From what I am getting from this post and from from some real old ones on this N.G.
It really is keeping the gasket in position especialy when installing it. If the cover was glass, we would be able to see if the gasket moved while we installed it.
One guy on youtube just does on dot of sealent on each corner and the middle of each side and back and front. Total 8 dots and he holds them in place till they dry a cloth pin.
His story was if you do it all around it is hard to clean it off the cover next time he did his valves. _________________ email: [email protected]
