Root_Werks Samba Member
Joined: December 31, 2007 Posts: 816 Location: San Juan Islands
Posted: Thu Feb 29, 2024 10:30 am Post subject: Re: The Berg 5 Speed Thread |
Rancho gear and Fulcrums should arrive today. I should get my box off to my builder next week.
I did pull off the nose cone, but that's as far as I'll go. I'm not a Engine or Tranny builder.
Here's a couple of pics (fuzzy, sorry) of the .82 screaming 5th. Screams under load, quiet no load. Until the gears are removed, not sure there's anything to be seen. I can see shinny areas where the gears mesh.
_________________ When I set my timing, why do I flush, then take a pee? |
Posted: Thu Feb 29, 2024 10:35 am Post subject: Re: The Berg 5 Speed Thread |
The other issue I'm running into is hearing/feeling the axles/fulcrums after driving anything over 70mph for 15+ minutes. It's like there isn't enough oil getting to them?
Yes, the trans oil was filled properly.
Right side never made noise, Left side did. Last freeway drive I pulled off and was freaked out a little when I could hear the left side making noise. Quieted right down once off the freeway. Way home, kept under 65mph and it was fine/quiet.
Check out the fulcrums though, yikes. Right side had a .005" gap between axle and fulcrum. Left was .010", maybe too much gap?
Super Diff has oil mod holes.
Thoughts anyone? Going to put all this back together and would love to drive 75+ mph.
-Dan
Bruce Samba Member
Joined: May 16, 2003 Posts: 17296 Location: Left coast, Canada
Posted: Thu Feb 29, 2024 12:52 pm Post subject: Re: The Berg 5 Speed Thread |
Your side covers need to be modified to allow oil to go around the diff to the axle side. Good thing you posted those pics while you have it apart so you can fix the side covers.
Every trans with a superdiff needs this modification done.
Here's what VW did for cars that had a limited slip diff:
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Thu Feb 29, 2024 1:25 pm Post subject: Re: The Berg 5 Speed Thread |
Those side cover mods shown by Bruce are necessary for swingaxle LSDs and TBDs, as well. Regarding the SD body itself, I'd go the extra mile as shown by Ray Vallero (RIP). https://www.thesamba.com/vw/forum/viewtopic.php?t=622360 _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Thu Feb 29, 2024 2:33 pm Post subject: Re: The Berg 5 Speed Thread |
Wow, thanks guys! I'll pull the side covers off and check for the mod. I have a scope camera, but don't think I could bend it up enough to see if the mod has been done or not. My builder did the oil holes on the SD I know for sure, but don't know if anyone modified the side covers.
-Dan _________________ When I set my timing, why do I flush, then take a pee? |
Bruce Samba Member
Posted: Thu Feb 29, 2024 4:13 pm Post subject: Re: The Berg 5 Speed Thread |
The modifications are visible from the outside. Since you already have the axle tubes off, you should be able to see. _________________
Posted: Thu Feb 29, 2024 5:55 pm Post subject: Re: The Berg 5 Speed Thread |
Popped a cover off just to be certain. No mod. Sure explains things.
Well, feel like I've got a plan at least.
Not 5spd specific, but figure anyone building a Berg5 swing will probably lave either a SD or LSD. _________________ When I set my timing, why do I flush, then take a pee? |
Posted: Fri Mar 08, 2024 10:39 am Post subject: Re: The Berg 5 Speed Thread |
Don't want to turn this into a build thread, but thought this is a good picture of 5th gear removed and nose cone off.
New GT .82 going on in place of the unknown (no markings) .82 gear set that really screamed under load. Since everything checked out, we're hoping/assuming it was a miss-matched set.
Brent Samba Member
Joined: April 28, 2010 Posts: 1617 Location: San Tan Valley, AZ
Posted: Tue Mar 12, 2024 11:54 pm Post subject: Re: The Berg 5 Speed Thread |
Here's one that can go totally sideways...
What oil are you using in yours?
I'm planning on Swepco 201. _________________ 69 Fastback Build
Berg5 Build |
Posted: Wed Mar 13, 2024 7:48 am Post subject: Re: The Berg 5 Speed Thread |
Brent wrote: |
I'm planning on Swepco 201. |
Currently use Valvoline GL-5, GL-4 75-90W non-synthetic. I buy quarts, believe the part number is 820.
I used 201 years back in some 901 gear boxes and liked it. Thought about using it in the Berg5. Heard from some the only advantage of 201 these days is it's blue.
Posted: Wed Mar 13, 2024 9:24 am Post subject: Re: The Berg 5 Speed Thread |
Since I pulled the Berg5 out again, wanted to show another minor mod I had to make to the mid mount.
Berg5's require the mid-mount be used. I'm on a 1966 frame so this mod may/may not apply to other year frames. The mid mount didn't touch, but it was very close to the Right frame horn. I didn't notice until after everything was installed and used a sawsall to cut a small notch out. Hard contact of drivetrain to frame or body transfers a lot of noise and this was a definite possible contact point.
Picture shows I cleaned up the cut a little and were it was cut. The mid mount metal is so thick, seriously doubt this compromises any structural function of the mount:
Olli from NJ Samba Member
Brent Samba Member
Posted: Wed Mar 13, 2024 7:45 pm Post subject: Re: The Berg 5 Speed Thread |
Root_Werks wrote: |
I'm curious how you mount these to the studs. Do you sandwich it between 2 nuts? Seems like if you didn't, you'd have a mess if you had to remove it. _________________ 69 Fastback Build
Berg5 Build |
Bruce Samba Member
Posted: Wed Mar 13, 2024 9:18 pm Post subject: Re: The Berg 5 Speed Thread |
You're right Brent. If you remove the mid mount, you've got a big leak that you'll never be able to seal. That's why I require the mid mount when I do the initial build. Then it's on the trans when it's picked up.
I've never heard of anyone putting nuts on the gear carrier then adding the mid mount. The studs aren't long enough to take an extra nut. _________________
Brent Samba Member
Posted: Wed Mar 13, 2024 9:37 pm Post subject: Re: The Berg 5 Speed Thread |
Bruce wrote: |
I've never heard of anyone putting nuts on the gear carrier then adding the mid mount. The studs aren't long enough to take an extra nut. |
Thanks. I was hoping I could add it later with longer studs... Looks like I'll be opening up the wallet again.
I do like the one you made, but don't have the time, so I'll buy the 'boat anchor' from Berg. _________________ 69 Fastback Build
Berg5 Build |
Bruce Samba Member
Posted: Wed Mar 13, 2024 10:01 pm Post subject: Re: The Berg 5 Speed Thread |
Brent wrote: |
I do like the one you made, but don't have the time, so I'll buy the 'boat anchor' from Berg. |
The Berg mid mount's plate is either 5/16 or 3/8" thick. It is that thick so that if you replace the 4 bottom short studs with longer upper studs, it all works out. Structurally, you don't need the plate to be that thick. If it was 1/8", it would never break. I made mine from ¼" Al.
My car is already really heavy, so when I did the 5 speed, I knew I didn't want to add to it by using the Berg heavyweight mount. I believe it's around 12lbs with the rubber bumpers. Mine is under 3 lbs. If I was to do it again, I know how to make it lighter. Plus, I think I saved a couple hundred by not buying the Berg mount. _________________
Posted: Thu Mar 14, 2024 7:48 am Post subject: Re: The Berg 5 Speed Thread |
I wouldn't install a Berg 5spd without the mid mount. Berg's blue bible states it's a requirement. When I get my Berg5 back, I'll snap a pic of the mid mount on the trans.
Fitting the Berg5 to the Bug took some time. The mod's in the blue bible can't be ignored.
Posted: Thu Mar 14, 2024 9:00 am Post subject: Re: The Berg 5 Speed Thread |
Here's a good shot of the mid mount on the trans. Just 4 studs need to be about a 1/4" longer:
Posted: Thu Mar 28, 2024 1:54 pm Post subject: Re: The Berg 5 Speed Thread |
"Rancho" hybrid fine tooth .82 installed and much quieter than the generic .82 I was running. You'll be very happy with it.
Failer Samba Member
Joined: April 16, 2005 Posts: 511 Location: South Austin
Posted: Sun Apr 21, 2024 4:00 pm Post subject: Re: The Berg 5 Speed Thread |
I know from this thread that the B5 conversion lengthens the nosecone a bit and requires some clearancing of the body. Is that the only obstacle to it being a straight bolt-in thing? Does the nose cone keep the mount and the length of the gear selector the same? I mean, do the shift coupler or rod need to be moved or modified as well? |
