Bradyy02 Samba Member
Posted: Wed Mar 20, 2024 7:59 pm Post subject: Loose alternator belt even with no shims why? |
Took off my cracked alternator belt to put on my new alternator belt from jbugs and even with no shims it’s still loose, why? The old belt had a part number of 25515 11A0900 but I can’t find the belt that is like it. Why doesn’t my new alternator belt work for my alternator?
[/url] |
zerotofifty Samba Member
Posted: Wed Mar 20, 2024 9:22 pm Post subject: Re: Loose alternator belt even with no shims why? |
belt appears to be too narrow as it appears to ride below the top of the generator pully. with no shims the belt of correct width should ride higher, near the outer diameter of that pulley.
of course maybe you got the two generator pulley halves indexed wrong, such that the wide location tang is over the narrow slot, and thus the two halves are not correctly seated with each other.
the other thing, are you using a power pulley (smaller than stock crank pulley)
Empi Power Pulley is 5 13/16 inch diameter, empi std pulley is 6 3/4 inch dia.
A power pulley requires this belt....
https://www.jbugs.com/product/9120.html?rrec=true
what was part number of new belt? _________________ Give peace a chance. No American war with Russia! |
Posted: Thu Mar 21, 2024 1:54 am Post subject: Re: Loose alternator belt even with no shims why? |
Hey thanks for the comment. The part number For the new belt I got is 113X912 |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
Posted: Thu Mar 21, 2024 5:43 am Post subject: Re: Loose alternator belt even with no shims why? |
Do you have shims under the nut and hat assembly? Total 8 shims... |
raydog Samba Member
Joined: February 09, 2006 Posts: 1164 Location: Cape Cod
Posted: Thu Mar 21, 2024 5:51 am Post subject: Re: Loose alternator belt even with no shims why? |
From that angle, it looks like a power pulley. _________________ Come on, It's not rocket science. KISS |
richparker Samba Member
Joined: November 24, 2011 Posts: 6989 Location: Durango, CO
wdfifteen Samba Member
Posted: Thu Mar 21, 2024 6:57 am Post subject: Re: Loose alternator belt even with no shims why? |
I see the shims laying on the engine tin. You need all the shims on the alternator shaft even if none of them are between the pulley halves. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13852 Location: White Mountains Arizona
Posted: Thu Mar 21, 2024 7:07 am Post subject: Re: Loose alternator belt even with no shims why? |
Go to your local auto parts store and buy a couple of belts and fit the one that works the best...return the others. Simple fix _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Cusser Samba Member
Joined: October 02, 2006 Posts: 31392 Location: Hot Arizona
Posted: Thu Mar 21, 2024 8:21 am Post subject: Re: Loose alternator belt even with no shims why? |
gt1953 wrote: |
Go to your local auto parts store and buy a couple of belts and fit the one that works the best...return the others. Simple fix |
EXACTLY !!! Take belt with you, get slightly smaller; store will go by measurement, they have a fixture.
On my two Nissan Frontiers, of the three belts, I use two that are slightly shorter than what the computer information states. Be smarter than a computer ! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Mar 21, 2024 9:06 am Post subject: Re: Loose alternator belt even with no shims why? |
Bradyy02 wrote: |
The new belt is longer than the old, 912 mm verses 900 mm (about half an inch longer)
You have what appears to be an empi type crank pulley. empi makes this pulley in either standard or power pully styles. Measaure this pulley diameter as per my prior post above. then go to the JBug website to order the belt you need.
What you had for the old belt is not one of the types listed at JBugs. remember that a narrow belt rides lower in the pulley groove, so a narrow belt need be shorter, a wider belt rides higher in the pulley groove, so a wider belt needs to be longer. So you need to consider both diameter and width of the belt.
Your best bet is to measure you crank pulley diameter to confirm if power pulley or not. Then ortder the correct belt from J Bugs.
a power pulley does turn the fan slower, so that can cause over heating unless you are high reving all the time. I dont like the power pulley for that reason.
Or your best bet maybe to take the old belt into a parts store and have it matched. It MUST match in both length and width., sure if you get one a tad wider, then it MUST be a tad longer and visa versa.
PS as others have noted, you MUST store the extra shims all on the pulley, 8 shims total, the extras get placed under the flanged retainer outside of the pulley on the nut end of the pulley. The reason is that if the shims are not there, the nut can bottom out before fully gripping the pulley halves together, and that will damage the pulley over time, even damage the shaft.
Plus the extra shims might be handy if you need to make an emergency belt change on the road and cant find the exact same belt, you need to be able to adjust for this. Note a new belt may initially stretch a bit, so recheck tension periodically. Carry a spare belt always. Keep it in the trunk for emergency. You cant drive but a minute or so with no belt before engine damage happens. _________________ Give peace a chance. No American war with Russia! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24772 Location: Olympia Wash Rinse & Repeat
Posted: Thu Mar 21, 2024 9:34 am Post subject: Re: Loose alternator belt even with no shims why? |
At any engine RPM a power pulley will not properly cool an engine due to the cooling fan running slower, so that results in less cooling air is pumped over all the engine cooling surfaces. Better to get the larger stock pulley for doghouse cooling.
Daily driving one is not going to notice the slightly less HP at the wheels with stock pulley. A properly cooled engine will have much better longevity.
Power pulley is only a good option if one is actually going to do the 1/8 or 1/4 mile drag strip, when one can win or loose due to a fraction of a second difference. At that point one might as well just loose the cooling fan, gen/alt and install one or more electric cooling fans instead after each pass on the drag strip. _________________ In Stereo, Where Available! |
Posted: Thu Mar 21, 2024 11:05 am Post subject: Re: Loose alternator belt even with no shims why? |
I do have my 8 shims under the alternator shaft guys. The ones on the side were just ones I bought just in case I needed any extras, the guy I bought the bug from was lazy on fixing it and had some things messed up |
Posted: Thu Mar 21, 2024 11:34 am Post subject: Re: Loose alternator belt even with no shims why? |
I just measured my pulley and it’s a stock pulley 6 3/4. Anything else it could be? |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Thu Mar 21, 2024 11:58 am Post subject: Re: Loose alternator belt even with no shims why? |
I think it's been answered... a shorter or wider belt is needed. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76969 Location: Sneaking up behind you
Posted: Thu Mar 21, 2024 12:08 pm Post subject: Re: Loose alternator belt even with no shims why? |
KTPhil wrote: |
THIS
It's not rocket science, if the belt you have it too long... get a shorter one.
As suggested, buy a few different sizes and return the ones you don't need.
I run a 890mm belt even though the stock size is a 912mm. _________________ Glenn
Member #1009
#BlueSquare |
KTPhil Samba Member
Posted: Thu Mar 21, 2024 12:11 pm Post subject: Re: Loose alternator belt even with no shims why? |
Belts stretch, and pulleys wear. Plus, new belts are not always made to exact lengths and widths. Hence the GOOD advice to buy several and return those that aren't right. |
Posted: Thu Mar 21, 2024 1:04 pm Post subject: Re: Loose alternator belt even with no shims why? |
Bradyy02 wrote: |
Could be someone put it on a lathe to make the groove deeper. Could be it was manufactured that way. Could be the soft aluminum has worn down. _________________ In Stereo, Where Available! |
Posted: Thu Mar 21, 2024 3:30 pm Post subject: Re: Loose alternator belt even with no shims why? |
Try a Dayco Top Cog 15315 NOTE*15355 is corrected part number
