Changing rear wheel bearing while on the road
Page: Previous  1, 2, 3  Next
tjet Premium Member
tjet is offline
PostPosted: Mon Mar 25, 2024 6:12 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
I picked up a used housing & installed new bearings, I keep it under the back seat
kamzcab86
kamzcab86 is offline
PostPosted: Mon Mar 25, 2024 6:28 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
khughes wrote:
Man, I live in Phoenix, and Affordable is *still* a long drive!
Ditto. It's on the opposite side of town for me, which is why my van hasn't been there... yet.
khughes wrote:
And I can't believe Doug hit the true rush hour coming down I-17, he didn't use one single curse word! He'd still be cursing if he'd hit when it was BAD. Brick wall
I-17 from Roosevelt Lake?
Regardless, it's not just 17. Every freeway in and around Phoenix is a nightmare during rush hour. Actually, surface streets aren't much better either. Mad
DanHoug wrote:
Highly recommended, just don't expect a pristine shop and Krups machine.
Ages ago I went there with a former friend who needed Cabriolet parts. Affordable German is in a part of town I call "junkyard row"... yard after yard after yard down there.
Glad to hear the van is all fixed. Very Happy
~Kamz Anxious
2016 Golf GTI S
bsrad
bsrad is offline
PostPosted: Mon Mar 25, 2024 6:59 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
This was our solution as well. Plus carry the socket, breaker and high lift handle to get the nut off. Feels pretty good to be couple thousand miles from home and know that won’t be a game stopper.
E1 wrote:
Veddy intedesting……
Our rears have Zerk fittings just for this purpose… perhaps I should use them.
I installed zerks on a set of carrier several years ago. Be careful with those. Just one too many pumps and the grease will push that outer seal out of the carrier. Ask me how I know…. On my current rebuilt carriers I did not drill and tap zerks in them.
Bill
1987 Syncro Westy
1967 OG Single Cab
1976 FJ40
E1
E1 is offline
PostPosted: Mon Mar 25, 2024 7:16 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Thanks.
With that news, I’m not touching them.
‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman
TopBud
TopBud is offline
PostPosted: Mon Mar 25, 2024 7:25 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Dan,
Glad it all worked out. When I did mine on the road, it obviously didn't work well. I was at a camp spot and had time. I was going to go the route tjet did and carry a housing assembly all packed, but noticed I needed rear bearings and... Affordable German is doing it, along with some other work. I drove it down from Flagstaff over 2 hours. Dan and Bill are awesome. They are also sponsors of Van Alert.
I hope I won't need rear bearings for a really long time after this.
Great catching up with you. Looks like we will be heading to MN this summer mid-July.
86 bostig SYNCRO
66 convertible Karmann Ghia
khughes
khughes is offline
PostPosted: Mon Mar 25, 2024 7:31 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Yeah, I'm around Shea and the 51, so not just a hop, skip, and a jump from here. I do most my own work, so I haven't used them much in recent years. But, as I age...
Well anything south of Sunset Point is pretty miserable, especially down around Bloody Basin. Just nuts. And that's before you get near town.
kamzcab86 wrote:
Ages ago I went there with a former friend who needed Cabriolet parts. Affordable German is in a part of town I call "junkyard row"... yard after yard after yard down there.Very Happy
It's absolutely Junkyard Row. Has been for decades. Blair and Sons is down there as well, and sometimes they'll have something that Bill doesn't have. Always worth a check.
'86 Westy FAS GenV Turbo (Marvin)
TopBud
TopBud is offline
PostPosted: Mon Mar 25, 2024 7:38 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Blair and Sons is no longer operational.
Long drive for sure. I also do my own work, but took my van to Affordable German, because we were having a snowy winter when I was having issues and didn't want to work in my dirt driveway in the snow, cold and mud.
86 bostig SYNCRO
shagginwagon83
shagginwagon83 is offline
PostPosted: Mon Mar 25, 2024 7:53 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Ohhh awesome. This is exactly what I needed. This gives me a reason to buy a parts Vanagon.
Brandon
Instagram @joannthevan
tjet Premium Member
tjet is offline
PostPosted: Mon Mar 25, 2024 8:20 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Here you go.
https://www.thesamba.com/vw/classifieds/detail.php?id=2573533
djkeev
djkeev is offline
PostPosted: Tue Mar 26, 2024 2:52 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Here you go.
That's not a bad deal! ^^^^^
Snag it!
Ghia
Vanagon
Beetle
Steve M.
Steve M. is offline
PostPosted: Tue Mar 26, 2024 3:56 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
I've been updating my spare parts and tools recently, focusing on the rear wheel bearing kit. Given its complexity, it's daunting to consider roadside repairs. However, is it feasible?
Key Points:
-Rear Axle Nut: Approximately torqued to 330ft/lbs. A suggested workaround is welding a 3/4" drive head to a high lift jack, using a 40/44mm socket.
-Dowel Pin: My experience involves heating to remove the original pin.
Would a garage be the only solution, especially if you have the parts and tools?
Or, in a scenario like being remote in Baja, could the pressing of the bearing be the deal-breaker for roadside repair?
I think it would be very feasable to do it if you had the necessary pipes approximetely 3-1/2' long to work as a breaker bar. One pipe being smaller diameter to slip inside the other to save storage space.
You would then need the big giant torque wrench to put it back on to 360 ft.lbs.
Or, to make life much easier buy a torque mulitplier to remove it and torque it back on with a smaller size torque wrench.
dobryan
dobryan is offline
PostPosted: Tue Mar 26, 2024 4:11 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
You do not need a torque wrench. This is not a precision operation. It is torque to 360 ft lbs and then keep tightening until the castle nut splines line up. Do the math of your body weight on the breaker bar to get the initial set and then tighten further to line things up.
Dave O
The Western Syncro build
DanHoug
DanHoug is offline
PostPosted: Tue Mar 26, 2024 4:20 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Having seen this done, i think removing the axle nut is the smallest, easiest factor in the job. Here’s what i saw:
- remove axle nut. SnapOn impact gun took it off fine.
- tried pulling wheel hub off of splines with two pry bars. No go. Bill then removed the driveshaft and drove the stub out of the hub and splined wheel mount with an impact hammer. Serious impact power used. Maybe a puller would have worked.
- removed inner circlip. This was maybe the most time consuming aspect as his myriad of snap ring tools couldn’t grasp the snap ring, working from inside the trailing arm opening. He walked away, came back and got it out. It was a bugger due to restricted acces…
- drove the outer bearing, spacer, and inner bearing out with SnapOn impact hammer. Again, serious impact force.
- drew the new bearings in with a large front axle tool used for Rabbit bearings. The bearings were playing Whack-A-Mole until a straight on bite was achieved and they were drawn in. Outer race pressure only so you MUST have the right size adapters.
- assembly of remaining circlip, seals, hubs, etc.
I’m a pretty handy guy and there’s no way i could have done this roadside. Carry a complete bearing set or a spare hub, check your bearings for tightness before you go, and plan on garage assistance if the bearings fail is my plan.
-dan
www.thefixitworkshop.com
E1
E1 is offline
PostPosted: Tue Mar 26, 2024 6:06 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Thanks for all that info, Dan!
So is this from Tjet what to carry after you lived it?
— Colin Chapman
Sodo
Sodo is offline
PostPosted: Tue Mar 26, 2024 7:34 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
So he did all this work overhead on a lift, without unbolting the hub?
I guess not disturbing the brakes.
I’m surprised your hubs could be that tight at 225k miles.
Be happy for that!
....KTMs, GasGas, SPOT mtb
DanHoug
DanHoug is offline
PostPosted: Tue Mar 26, 2024 8:05 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Yeah, this was on a lift without any brake disassembly. It sure seemed like the way to go if the power tools are handy. Maybe replacing the complete hub is easier as a field repair. Anyone care to comment?
That thread involving TK, hub spacers, and voodoo had me freaked out to change the bearings. The OE hub spacer is super hard steel, complete with a VW part number. Bill said he’s never seen a bad one. Bill just moved the bearings together until the spacer stayed in position, put the circlip and seals in, stub, and did a final high torque with a strong impact wrench. Again, lots of experience behind that trigger but sure was simple.
With both rears properly done, this is probably a repair that parts don't need to be carried for. After i do my other side in a warm dry garage, i’m not carrying the parts for it. At least for a 100,000 miles anyway.
-dan
E1
E1 is offline
PostPosted: Tue Mar 26, 2024 8:14 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
I’m not surprised the mechanic had never seen one fail. I should have never been talked into replacing them on this van, per everyone I’ve talked about it with since.
Our first van went well over 350 on the originals, and was totaled with them in. For all I know it’s still rolling down a road with them somewhere.
Thanks to you and Bill, you’ve convinced me I needn’t carry a spare. Cool
— Colin Chapman
khughes
khughes is offline
PostPosted: Tue Mar 26, 2024 8:24 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
Rear axle bearings were one of the first things I did on my current van. Bought it with 95K on it, and within the first 5K of ownership, the right rear started sounding like a chainsaw. I replaced both, just for grins, and 175K later both sides are fine. Not sure why one side failed "so quickly" but...
mtnhome Premium Member
mtnhome is offline
PostPosted: Tue Mar 26, 2024 8:55 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
DanHoug wrote:
Bill just moved the bearings together until the spacer stayed in position, put the circlip and seals in, stub, and did a final high torque with a strong impact wrench. .
Hopefully the outer bearing rollers were NOT touching the spacer to hold it in place. The inner race of the outer bearing is free floating.
When I rebuilt my rear hubs, the hub was packed with grease and the spacer stayed put on its own.
Sodo provides an excellent write up in this thread.
https://www.thesamba.com/vw/forum/viewtopic.php?t=776438
'84 Westy, '93 Subaru ej22 and Subarugears 5speed
Build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=763098&highlight=
Sodo
Sodo is offline
PostPosted: Tue Mar 26, 2024 9:11 pm    Post subject: Re: Changing rear wheel bearing while on the road Reply with quote
I bought new German INA/Shaeffler roller and FAG ballbearings.
Just by "feel" it seemed that my original 225k mi VW bearings were tighter than the new bearings.
I measured the slop and sure enough, the 225k mile bearings were a little tighter
so I put the 225k mile bearings back in.
With all new seals.
And put the "new" bearings back into the project pile.
See thread: Can 225k rear Wheel Bearings be better than "new"? (mine were!)
My hubs were a little loose though. I could slide the (inner) bearings in/out with my fingers.
I glued them in with Loctite 660®.
I guess we'll see if they are still glued in sometime down the road.
Now they have 235,000 miles.
I had needle-greased my rear bearings at 175,000 though,
using the 12,3,6,9 o'clock method which pushes out the old grease evenly.
So they had new grease for the last 50,000 miles.
Some feller with a 100k van could replace the grease in that manner and I bet the original bearings will last a LONG time.
Someone with a young van & pre-emptive tendencies could disassemble, clean & re-mount the (inner, ball) bearings with SKF LGAF 3E Anti-fretting agent on the contact area between the race and the bore.
LGAF 3E would prevent the erosion that 'deletes' the press-fit.
(------> trusting the experts at SKF Exclamation )
I don't think there's any way to know at what point (miles) this becomes ineffective (too late). But if your bearings still have 'press-fit' there's hope.
This could be done on "new" hubs too, if you're young enough to need 250,000 future miles.
The LGAF 3E elixir is described in the link above.
Page 2 of 3
