69 bug master cylinder missing center switch - help!
PJ_1600
PJ_1600 is offline
PostPosted: Thu Jun 13, 2013 12:20 pm    Post subject: 69 bug master cylinder missing center switch - help! Reply with quote
Hi - i am replacing the original master cylinder in my 69 Beetle and, as you can see from the photo the original mc has 3 brake switches where as the new one only has two. According to CIP1 this is the correct mc for this year so my question is, what do i do about having no where to hook the center wires to? I think the center wires are just for the red B light on the dashboard (a brake warning light?) and the outer two are for the rear brake tail lights. If I am correct is there any harm in leaving the center wires unconnected? Should I be looking for a different mc? Any help would be most appreciated!
djkeev
djkeev is offline
PostPosted: Thu Jun 13, 2013 12:36 pm    Post subject: Reply with quote
From M&T Manufacturing.......
"Note: If replacing the master cylinder for 67-69 cars
you will need to purchase a pair of three prong brake
switches (part 113-945-515G) in order to operate the brake warning light.
The original had three two prong switches; the replacement
has two three prong switches."
http://www.mtmfg.com/vw/1630/Volkswagen-Beetle-Brake-Master-Cylinders
Dave
Ghia
Vanagon
Beetle
Q-Dog
Q-Dog is offline
I haven't seen a 3 switch master in many years. I used to rebuild them, a long time ago. Now it seems we just replace them. I suppose you could try to rebuild the original.
If it is important to you, you can rewire the brake circuit to retain the brake warning light. It involves changing the switches from the 2 terminal type to the 3 terminal type.
If you are gonna throw out the old master, I would take it off your hands. MAYBE, it can be rebuilt.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
VDubNut
VDubNut is offline
PostPosted: Thu Jun 13, 2013 12:41 pm    Post subject: Reply with quote
You will need to replace the swithches. I cut this from Airhead Parts:
If replacing orig. master cyl. on 67-69, customer will need to buy 2 each three-prong brake switches 113-945-515 G to use brake warning light. (Orig. had 3 two-prong switches - replacement has 2 three-prong switches.)
Here is the add: http://www.airheadparts.com/vintage-vw-parts/brake...11015-bdgr
Looks like the same master as the one you purchased, just the switches have changed. Hope this helped!
Mike
Current VeeDub:
'69 Patina (0\_!_/0)
Previous VeeDubs:
'91 Jetta GL
'72 (0\_!_/0)
vernonc
vernonc is offline
PostPosted: Thu Jun 13, 2013 2:38 pm    Post subject: Reply with quote
Here's a link for wiring the 3 prong switches.
http://nls.net/mp/volks/schem/3brake.gif
Hope this helps..........it did me. Laughing
mort
"Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386
PJ_1600
PJ_1600 is offline
PostPosted: Thu Jun 13, 2013 4:42 pm    Post subject: Reply with quote
Thanks for the replies. So I need to buy two 3 prong switches. Hmm, would have been nice if CIP1 had told me that when I asked - oh well, now I know (and apparently they didn't).
Mort - thanks for the diagram. That will be a huge help. Now I just have to wait a week to get the right switches and I've got three brand new 2 prong switches I don't need. Such is life.
Thanks guys - once again The Samba answers that which no local parts counter can. (At least in my area). Laughing
gt1953
gt1953 is offline
PostPosted: Thu Jun 13, 2013 5:35 pm    Post subject: Reply with quote
Which ever master cylinder you purchase make sure it is a good one.
My 68 only has a 2 switch...
72 type 1
72 Squareback
djkeev
djkeev is offline
PostPosted: Thu Jun 13, 2013 5:39 pm    Post subject: Reply with quote
Well, you really don't need an idiot light to tell you that your brakes aren't working!
As soon as you depress that pedal you WILL know, the light only confirms what your leg muscles just told you.
It's not an active monitoring system telling you of trouble like an oil light or brake resivour indicator. It truly is an IDIOT light, only telling you of failure as you use the system......well Duh!
Dave
Ghia
Vanagon
Beetle
PJ_1600
PJ_1600 is offline
PostPosted: Thu Jun 13, 2013 5:51 pm    Post subject: Reply with quote
So Dave are you saying that I can use the two prong switches and just leave the center two wires (that used to go to the middle switch) disconnected? And this won't affect the operation of the brake lights? If ALL the center switch does is activate the idiot light, as you say, then I really don't care if it is operational. I'm not too swift when it comes to electrical systems so this question may sound silly. Embarassed
djkeev
djkeev is offline
PostPosted: Thu Jun 13, 2013 5:58 pm    Post subject: Reply with quote
That's exactly what I'm saying.......
J6 is your warning switch, J3 are your brake lights.......
Dave
Ghia
Vanagon
Beetle
PJ_1600
PJ_1600 is offline
PostPosted: Thu Jun 13, 2013 6:07 pm    Post subject: Reply with quote
Thanks Dave - now I can go ahead working on this tonight instead of having to wait for new switches. The switches are so much easier to put in the mc before it is installed so I was going to wait - now no need. Thanks again!
Q-Dog
Q-Dog is offline
PostPosted: Thu Jun 13, 2013 6:31 pm    Post subject: Reply with quote
I guess I should have been clearer.
Q-Dog wrote:
... If it is important to you, you can rewire the brake circuit to retain the brake warning light. It involves changing the switches from the 2 terminal type to the 3 terminal type. ...
And, yes, if you don't care about the brake warning circuit, reuse the switches you have.
Brian
'69 Dune Buggy
'70 Beetle
